Old 02-18-2012, 02:09 AM   #226
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Camshafts..
Ok capt fab.
I'll give it a shot. Everybody cross your fingers in hopes the gm dealer has a dipstick tube in stock
Whats one cost roughly from GM (I read that china chrome ones suck etc) And do I have to buy dipstick AND tube or what?
John
1999 Toyota Tacoma 4x4
Old 02-18-2012, 02:11 AM   #227
oldblue1968chevy
Re: Camshafts..
Im thinkin' bout puttin a new rear main in too (I put one in about a month ago but tore a little sliver off it while installing dont think it leaks but its sure easier now than under truck and for $10......lol)
John
Old 02-18-2012, 02:26 AM   #228
litew8
litew8's Avatar
Re: Camshafts..
or let the gf do it
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 02-18-2012, 08:20 AM   #229
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Re: Camshafts..
Originally Posted by oldblue1968chevy View Post
Ok. Just got timing chain cover on etc.
Cam dot is @ 6 o clock
Crank dot is at 12 o clock
This is right, isnt it? (Too late the cover is on and rtv'd and new felrpo gasket on lol
as prostreetc10 said, that's correct, just remember when you go to set the valves that that is firing position for # 6
Larry
fleetsidelarry is offline   Reply With Quote
Old 02-18-2012, 11:18 AM   #230
oldblue1968chevy
Re: Camshafts..
cant I turn it over X amount to get #1 firing?
John
Old 02-18-2012, 11:35 AM   #231
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Camshafts..
It doesn't matter when adjusting the valves. There is a sequence you can use so you only have to turn the motor over a bare minimum. For me, I like to start on #1 and go 3, 5, 7, then hit the pass side. That's Just so I don't forget. The only problem with that is you wipe off the maximum cam lube before firing due to turning over excessive amounts of time. Not a problem with roller cams though! ;o)
prostreetC-10 is offline   Reply With Quote
Old 02-18-2012, 01:23 PM   #232
oldblue1968chevy
Re: Camshafts..
Ok anyone wanna give me your # so I can call for stupid ?'s LOL
I just set the valves im pretty sure I was on the compression stroke when I started but im not sure? I did so many valves then turned it over 360* (crank) then adj some more valves
Was this right? What if I wasnt on copreesion stroke (timing covers on but the intake is off
HELP
John
Old 02-18-2012, 03:07 PM   #233
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Camshafts..
That's the way most repair manuals tell you to do it with a stock camshaft. Performance camshafts due to their duration and lift need to be done at each cylinder.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-18-2012, 03:16 PM   #234
prostreetC-10
My Carbon Footprint
Re: Camshafts..
Call Gary.....he just stares at planes all day!
Old 02-18-2012, 03:34 PM   #235
fleetsidelarry
Senior Car Nut
Re: Camshafts..
HELP
that was the purpose of my giving you the heads up about the marks on the gears. if you started setting your valves with the 12 o'clock-6 o'clock gear orientation, you would need to know that that was compression on #6. one complete revolution (360°) would put you on compression for #1.
Gary is, of course, right about using a different method than factory, but if you were to start in the wrong place (that is #6 when you thought you were on #1), not knowing exactly what you're doing, the adjustment would be wrong. it also helps when putting the distributor back in
there are several methods. I've marked my damper at 90° intervals corresponding to TDC for each pair of cylinders, if I know where I'm starting, I know which is firing next on the damper
Larry
Old 02-18-2012, 03:43 PM   #236
GASoline71
GASoline71's Avatar
Re: Camshafts..
I tell 'em where to go once in awhile...
That's how I do mine. Then follow the firing order.
Gary
Old 02-18-2012, 04:17 PM   #237
fleetsidelarry
Senior Car Nut
Re: Camshafts..
John, you may know this already, but just as a refresher:
http://www.chevytalk.org/fusionbb/sh...?post/2071722/
Larry
Old 02-18-2012, 05:35 PM   #238
oldblue1968chevy
Re: Camshafts..
Ok
Im going to wait till its in the truck to set the valves (re set) I'll find the compression stroke #1 with my finger over the hole and line the balaner up. The timing cover is on now so i dont wanna take it off
Waiting to put intake/dizzy on I need some thread sealer for the vortec intake bolts they go into the lifter valley
John
Old 02-18-2012, 09:44 PM   #239
crazy longhorn
Fabricate till you "puke"
Re: Camshafts..
Still lookin for that sound clip crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-18-2012, 10:57 PM   #240
oldblue1968chevy
Re: Camshafts..
Im never gonna let ya hear it longhorn lol im just gettin your hopes up
got a tube of black rtv and thread sealer today along with a $10 felpro rear main seal just to be sure.
John
Old 02-18-2012, 11:04 PM   #241
crazy longhorn
Re: Camshafts..
OUCH !...crazyL
Old 02-19-2012, 02:43 AM   #242
prostreetC-10
My Carbon Footprint
Re: Camshafts..
What the heck....can't leave you guys alone for even a minute! lol
I go and visit my sis who it in town and I come back to find CrazyL booooooted.
He's probably buying Ticker a beer!
Old 02-19-2012, 10:29 AM   #243
fleetsidelarry
Senior Car Nut
Re: Camshafts..
he was accused of "staff abuse" for responding to allegations about something I can't see that he did
http://67-72chevytrucks.com/vboard/s...d.php?t=508730
Larry
Old 02-19-2012, 10:48 AM   #244
prostreetC-10
My Carbon Footprint
Re: Camshafts..
Wonder if John is going to get this thing to run this weekend? I remember the butterflies in my tummy the first time I tried to light off something I went this deep into!!!
Old 02-19-2012, 12:19 PM   #245
oldblue1968chevy
Re: Camshafts..
Dang lol
longhorns gone huh
lol @ him and ticker
gonna put the rear main in this AM and button up the intake and im not sure if I wanna install with the trans in truck or pull the trans (dont think i'll be able to line it all up in truk)
John
Old 02-19-2012, 03:33 PM   #246
GASoline71
GASoline71's Avatar
Re: Camshafts..
You probably really didn't need to do the rear main. Unless you confirmed that it was leaking. SBC's leak... from the front and rear. When they stop leaking oil... it means they're out.
Gary
Old 02-19-2012, 05:17 PM   #247
oldblue1968chevy
Re: Camshafts..
Well I wanted to because its easier now than in the truck
Whats easier? pulling trans and lining everything up in the floor or trying to line everything up in truck? im ready to drop in but just not sure what i wanna try it was hard to get it out with trans in truck but i dont wanna leak all my gear oil out if i pull trans
maybe undo driveshaft u joint at trans?
John
Old 02-19-2012, 05:19 PM   #248
oldblue1968chevy
Re: Camshafts..
the insstructinos with the seal said to put in cocked ways with a dab of rtv on the outside bearing cap thats wat I did
I put some teflon tape on the drain plug threads and straiged oil pan
the dipstick..well i think i'll have to get a new one the dealer never caalled me back about it, he said they didnt have one in stock and to get a chrome one from orielly or somwere...
John
Old 02-19-2012, 08:40 PM   #249
oldblue1968chevy
Re: Camshafts..
Motors in truck needs buttoning up tightening mounts etc etc etc all the little stuff
hopefully i'll finish it up by tomorow
gonna order a new dipstick thru GM tomrorow if there open
John
Old 02-19-2012, 08:41 PM   #250
oldblue1968chevy
Re: Camshafts..
poor ol longhorn aint gonna be here to hear it run poor guy
John
