Old 05-16-2014, 10:54 AM   #226
shearjs
shearjs's Avatar
Re: Project: Rufus Restoration
A while back I had a leaky hydroboost booster and made the decision to switch to manual brakes with the Wilwood m/c. I've never really been happy with the feel of the brakes since making the switch. I've had a spare booster laying around that I pulled from the local yard, so I decided to clean it up and make the switch back to power brakes. My m/c is a 1" bore, which I had for manual brakes, so I'm curious how well it's going to work with a booster. Since I have it, and it is still plumbed in, I might as well give it a shot and see how it performs. Should be getting in a couple more fittings today for the booster, and hopefully get it back together sometime this weekend. I also decided to print my own SPID sheet, just for my own reference, with old RPO codes as well as a few newer ones for upgrades. It's not perfect, but it'll do for now.
shearjs is offline   Reply With Quote
Old 05-16-2014, 10:55 AM   #227
shearjs
shearjs's Avatar
Old 05-16-2014, 11:13 AM   #228
JRANGER
JRANGER's Avatar
awesome!
JRANGER is offline   Reply With Quote
Old 05-16-2014, 01:44 PM   #229
mcbassin
Still Learning
mcbassin's Avatar
Awesome work on the spid! I'm going to need more info on that thing
I like the booster too. I kind of wished I would have used one on mine.
mcbassin is offline   Reply With Quote
Old 05-16-2014, 01:58 PM   #230
shearjs
shearjs's Avatar
Originally Posted by JRANGER View Post
awesome!
Thanks buddy. How are things coming with the Mustang? Are you driving it regularly yet??
Thanks Mike. The SPID sticker is some cheap repro I picked up from one of the big stores...LMC or Classic Parts...I can't even remember. I just referenced a list of RPO codes from here (he is a member on the forum) and googled some newer codes for engine, trans, paint, etc., then compared them to spid pictures on the forum, and went for it. I have an excel template that you're welcome to, if you'd like to make one yourself. The font isn't correct, but then again, I don't even think it really exists. It's close enough for me though. You can always add the brake booster later. I find myself doing all the things now that I wish I would have done initially.
Old 05-16-2014, 02:24 PM   #231
JRANGER
JRANGER's Avatar
Disabled...Lol Getting ready to work on the cowls and front suspension so fenders are off and its just sitting under the carport. Plus now i have the 68 C20 to work on as well
Old 05-16-2014, 03:44 PM   #232
shearjs
shearjs's Avatar
Looks like another package just showed up! This is something I should have planned on doing from the beginning. Thanks Kyle and Sarah. If you're looking for some a/c at a good price, check out Kyle and Sarah at Laid Back Recreations.
Old 05-29-2014, 08:18 AM   #233
shearjs
shearjs's Avatar
I finally got the lines ran, and the majority of the air bled out of my power steering lines. The pedal rod needs just a bit of adjusting, buts this thing will stop on a dime now. The past few weeks I've been pulling a code for a knock sensor, so I decided to investigate. These sensors were definitely ready for a replacement. I also thought this would be a good time to go ahead and get started with some engine upgrades I have planned. Let the fun begin!
Old 05-29-2014, 07:58 PM   #234
Rusbuilt
Rusbuilt's Avatar
Cant wait to see the progress!!
Rusbuilt is offline   Reply With Quote
Old 05-30-2014, 05:55 AM   #235
Bennett68C10
Bennett68C10's Avatar
Jason what year is that hydroboost setup out of, looks really good. Also if you don't mind me asking what was leaking on your original setup? I have the captain fab brackets too but haven't purchased a hydroboost yet, I also have a Wilwood master cylinder but with a 1.125 bore. Did you have to make any modifications to get your Wilwood master to bolt up? Can't wait to see a video of this puppy running once your done with the upgrades.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-30-2014, 07:25 AM   #236
shearjs
shearjs's Avatar
Thanks buddy. Y'all getting settled in back in Knoxville yet? Has the wifey taken either of her exams yet?
The original hydro boost I had came out of the 2004 truck that the engine and trans came from. The booster I am using now was from an 03 I think. IIRC, after a particular year, they're essentially all the same, with metric fittings. If you need any of the part numbers for the adapters and fittings later, just let me know and I'll be happy to dig them up for you. The original leak I had was around the seal where the pushrod enters the back side of the booster. We ending up cutting the booster push rod and welding on a longer push rod with a clevis for adjustability. I think the O-rings likely got a little too hot and caused them to fail. The Wilwood that I have bolted right on with no issues. I think I would have bought the 1.125 bore like you did if I had ordered my m/c with the intentions of using power brakes. I'm pretty pumped to get this thing back on the road. After a cam/heads swap, it should be pretty healthy!
Old 05-30-2014, 08:19 AM   #237
Bennett68C10
Thanks for the info Jason, I'm just trying to figure out what I'll need for the swap. If you could PM me the fittings and adapters you used I would be grateful. I have to adapt mine to the power steering rack that came with my dropmember so I'm guessing yours is a little different.
Keith
66 Suburban
IG: bennett68c10
Old 05-30-2014, 10:51 AM   #238
Rusbuilt
Rusbuilt's Avatar
She takes them Thursday! We are starting to get settled in!
Old 05-30-2014, 12:31 PM   #239
shearjs
shearjs's Avatar
I figured I'd just post the part numbers here in case any one else might need them. On the booster itself, I used two AN adapters (RUS-670531 AND RUS-670541) and left the low pressure return line as a regular rubber hose nipple. On my LS power steering pump, the pressure line was also a (RUS-670531). On the OE power steering box inlet I used (RUS-648060). All adapters are -6 AN. For the hose, I used Powerflex hose #6 - 10' (RUS-632620). All of my -6 hose ends are (RUS-620421) 90 degrees. The 45 degree hose end is (RUS-620411) if you wanted to go that route on any of them. All part numbers are for Russell Performance, which I ordered from Summit. If there's anything I left out, or any other info you may need, please let me know. For what it's worth, I did see an auction on ebay from Tallon Hydraulics that included all 3 fittings for the hydroboost if you wanted to change the return lines to stainless braided as well. http://www.ebay.com/itm/like/251130424878?lpid=82 Hope this helps.
Awesome! Best of luck to her!
Old 05-31-2014, 08:24 AM   #240
cubber
I like the brake set up. I need to do something like that. My brakes are weak sometimes. Too much cam, I guess. Can you have too much cam?? lol
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 06-01-2014, 07:25 PM   #241
shearjs
shearjs's Avatar
Haha, no such thing as too much cam. Bout to swap in a new cam myself, so figured the hydroboost couldn't hurt.
Old 06-01-2014, 08:13 PM   #242
shearjs
shearjs's Avatar
Accumulating quite the stack of new parts. Time to get some of these under the hood.
Old 06-01-2014, 09:27 PM   #243
Rusbuilt
Rusbuilt's Avatar
Sweet!!!
Old 06-01-2014, 10:31 PM   #244
Bennett68C10
Thanks for the part numbers Jason, nice bench full of parts you have, your truck is going to be a beast
Keith
66 Suburban
IG: bennett68c10
Old 06-01-2014, 11:47 PM   #245
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Looking good Jason!! Lots of nice upgrades.. Thanks for the business also!!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 06-02-2014, 11:26 AM   #246
mcbassin
Still Learning
mcbassin's Avatar
Awesome progress and some really nice looking parts!
Old 06-02-2014, 05:07 PM   #247
shearjs
shearjs's Avatar
Sweet!!!
Thanks buddy! Have you had any luck selling your 6.0?
No problem, hope the part numbers were a bit of help. If I don't get to work, I'm going to have the entire dining room table covered with parts. It does make a pretty good solid work bench though. Can't wait to hear the engine with the new cam.
Thanks Kyle. Business was a pleasure. This a/c kit sure looks nice.
Thanks Mike. I wish I'd done a lot of this stuff in the correct order, like you are, but what would be the fun in that?
Old 06-02-2014, 08:58 PM   #248
Rusbuilt
Rusbuilt's Avatar
No sir. I'm in no hurry to sell it! Lol
Old 06-04-2014, 09:14 AM   #249
shearjs
shearjs's Avatar
Can't blame ya for that!
Made a little progress last night. Got the old heater stuff removed to make room for a new Vintage A/C unit. I need to rent a pulley puller now to remove the crank pulley, to access the timing cover, and the cam will be ready to swap. After removing a couple grounds wires and the alternator bracket, the heads will be ready to come off as well. I'm not looking forward to finding a new location to mount the computer and all those wires though. On the bright side, this does at least give me a chance to clean up a little of the wiring mess that I was lazy with before.
Old 06-04-2014, 02:13 PM   #250
mcbassin
Still Learning
mcbassin's Avatar
Killer progress. I would love to have the funds for a cam swap on my lil 4.8. Keep the pics coming.
