Old 05-25-2015, 09:24 PM   #226
GAc10boy
GAc10boy's Avatar
Re: Project: LS1ick68
Wow! Just gorgeous. Both color schemes. Well done! On the all silver motor, is the breather on the passenger v/c an Earl's breather? Did you use the matching pcv valve as well?
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 05-26-2015, 12:01 AM   #227
jessemthompson
Just read your entire thread. Great build. Did you get your downshifting issues taken care of?
jessemthompson is offline   Reply With Quote
Old 06-01-2017, 07:37 AM   #228
68Stepbed
68Stepbed's Avatar
Version 2.0 will be coming soon!! Here's a sneak peek of part of the new version.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-11-2017, 09:11 AM   #229
68Stepbed
68Stepbed's Avatar
OK, the engine guy didn't want to push it past 6000 on the dyno, but she still made 521hp at 5900 rpm 472 tq at 5400 rpm!!
Matt
Old 07-11-2017, 09:38 AM   #230
solidaxel
solidaxel's Avatar
What it wasn't fast enough !
How does all that torque hook up ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-11-2017, 03:39 PM   #231
ajgriffin
ajgriffin's Avatar
Did you dyno it before you added the heads? Any other changes while you were swapping out the heads (e.g. - rockers)? I'm curious to know how much power you added! I've always been a fan of AFR and 521hp/472 tq is awesome!
Standing by for the pics
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 07-11-2017, 05:43 PM   #232
68Stepbed
68Stepbed's Avatar
Actually, it was for the stock suspension. However, since I've installed all new TCI suspension, the torque arm should supply more grip!!
No before dyno, but it was estimated about 450ish with the stock 241 heads and same cam, since that's typical numbers for a cam only LS1. The only change in the valvetrain was the trunion upgrade in the rocker arms. The trunion upgrade really doesn't do anything for power, they just make the rockers more stable and less prone to high rpm failure.
Also keep in mind the hp/tq numbers are only what's recorded since we didn't take the engine to its 6500rpm potential. If you look at the chart with numbers, the power was still climbing rapidly. I would confidently say it would've hit 540hp, but since no numbers to prove it, I won't claim it.
Matt
Old 07-14-2017, 11:21 PM   #233
Steve Cole
Awesome build! I read the whole thread, great job! One question, what instrument gauges did you use?
Thanks.
Steve Cole is offline   Reply With Quote
Old 07-15-2017, 09:20 AM   #234
68Stepbed
68Stepbed's Avatar
Thanks.
Thanks for the compliment. As for gauges, that's the one area that I've never been able to do right. It seems like every time I go to upgrade, something else gets the attention. As of now, I still have a factory cluster, with the fuel gauge being the only thing working in it. I was never able to get the speedo working with the correct fittings in the transmission, the tach died shortly after getting it installed, the oil pressure was always pegged, I never got the correct sending unit for the coolant temp, and the volt meter just doesn't work. For now, I'm using one of those inexpensive 3 gauge clusters mounted at the bottom of the dash.
Yes, for all the other stuff I've done, this seems strange to overlook something so simple. I've actually started to build a cluster out of an old glove box door, but it stalled out when the suspension upgrade began. Hopefully, once it's back up and running, I'll get back to it.
Matt
Old 01-27-2021, 02:06 PM   #235
68Stepbed
68Stepbed's Avatar
2021 update!
I haven't been updating this thread like I had intended. The engine has been through a couple changes since my last update.
In June 2018, I ended up burning up the #2 piston because, like an idiot, I took internet advice and capped off my steam lines. That caused a hot steam pocket that burnt the edge of the stock cast piston. It went back to the machine shop.
Version 2.1 received +.010 forged pistons, and we opted for a custom ground cam. The cam from before ran great, but it revved very quick, too quick actually. Most of the time on an autocross course, the engine would run out of rpms and be bouncing the rev limiter. The machine shop picked a cam that would rev slower, but still maintain good torque throughout the rpm curve.
This combo was good for 530hp/475tq. Now, that's not a huge difference from the previous numbers, but....it certainly felt much different! The engine made over 400 lb/ft from 2800 to 6000 rpm. It's pretty much always in optimal torque range.
Version 2.2 was the swap from carburetor to EFI. Since I'm still running the 700R4, I had to use the 4150 style throttle body to utilize the TV cable bracket without any custom bracketry required for standard LS style EFI throttle bodies/intakes. It still uses the factory style 0411 PCM, Holley single plane intake/fuel rails/throttle body, and all hooked together with a PSI Conversions harness.
This setup worked very well until August 2020 when the engine called an audible at an event. That turned out to be a spun rod bearing!! The crank was damaged slightly and it got the oil pump. The crank is still useable, but the machine shop wasn't comfortable using an undersized crank for a "race" engine.
So...version 2.3 is now sporting a new forged crank, new forged rods, and still using the forged pistons from the last go-round, and a new Melling high pressure oil pump. The only valvetrain change was a new double roller timing chain since the previous chain was showing signs of excessive stretch. This combo should be much reliable seeing the constant high rpms.
I decided a new paint combo was in order. I'm still using the VHT Cast Iron engine paint color, but covered the whole engine for a more uniform look. I've also painted the accessory brackets black. The engine isn't installed yet, so I'll get photos of it assembled later.
Matt
Old 01-28-2021, 04:47 PM   #236
MySons68C20
MySons68C20's Avatar
Great update with all the info and videos.....appreciate it!
MySons68C20 is offline   Reply With Quote
Old 01-30-2021, 01:08 PM   #237
gringoloco
A guy with a truck
gringoloco's Avatar
Care to share your cam specs? Would be nice to get some torque back after the swap to the carb style intake. Engine looks great
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-01-2021, 10:53 AM   #238
68Stepbed
68Stepbed's Avatar
Matt
Old 02-02-2021, 10:43 AM   #239
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks! Any issues tuning idle with that 109° LSA? I bet she chops really nicely
-Chris
Old 02-02-2021, 12:46 PM   #240
68Stepbed
68Stepbed's Avatar
It does have a slightly rich idle that's almost impossible to tune out due to the overlap, so it's a compromise. It still tends to load up when sitting in traffic for long periods which can be cured with a couple neutral revs. But, it works well with my 2800 stall converter, and it's designed to run hard.
Yeah, it has a healthy chop!!
Matt
Old 02-04-2021, 12:00 AM   #241
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
phew, that dyno video confirmed my suspicion on belt tensioner routing. when i designed my L83 belt drive, it was looking awesome, tensioner where you have it, driver side between p/s pump and crank.... and just like i researched, scrapped the setup and put it on the passenger side similar to a factory setup.
no manufacturer has on the driver side right before the crank for a good reason, crank is pulling on the belt and its just flapping in the wind on the opposite side (just like your video) as the tension is being pulled on the driver side and just letting it loose on the other... i'd recommend re-configuring it to prevent a towtruck ride home
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 02-15-2021, 10:10 AM   #242
68Stepbed
68Stepbed's Avatar
clint
I've had this accessory drive setup for about 4 years, now. I've not had any major belt issues, but the company does offer an improved idler/tensioner setup on the passenger side of the engine. so, it's on the way.
https://www.ictbillet.com/ls-truck-l...tensioner.html
Matt
Old 02-15-2021, 11:06 AM   #243
68Stepbed
68Stepbed's Avatar
Engine/trans are back in!!
I decided to put them in together rather than benchpress the transmission while aligning the dowel pins and bolt holes.
I was kinda busy not to scratch anything to get "in progress" photos, but got these just after setting it all in.
Got the water pump, accessory drive setup bolted on, and got part of the steam line plumbed in, but need to get a steam collection manifold and tie in the rear ports. Also cleaned up some of the wiring. since it was all done in a rush last time.
I'm currently waiting on more parts to show up before I can move much further.
Matt
Old 02-21-2021, 08:38 AM   #244
jjzepplin
jjzepplin's Avatar
Very nice work. I am going to have to read the whole thread.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 03-16-2021, 09:20 AM   #245
68Stepbed
68Stepbed's Avatar
Some more progress. The transmission was giving me some fits the past couple years, so I had it gone through to make sure of any issues. The builder said it had signs of overheated fluid. So, I decided to bypass the the cooler system in the radiator and install both a trans cooler and a deep trans pan from Derale.
It only took me about 4 attempts, but I was finally able to get the cooler lines bent correctly. Here's the end result.
So, for the past several years, I've been able to run only a single 16" fan mounted directly to the radiator with no issues. However, with the added trans cooler, and power steering cooler, I figured a fan shroud was a good upgrade to make sure air was being pulled across the entire area. I had a local fab shop bend it up for me.
Matt
Old 03-16-2021, 09:35 AM   #246
68Stepbed
68Stepbed's Avatar
After some nip & tuck detailing, I've got everything hooked up and looking pretty nice. Hopefully, a few parts and gaskets will get here this week so I can get the headers and exhaust hooked up.
Matt
Old 03-30-2021, 07:38 PM   #247
68Stepbed
68Stepbed's Avatar
Slick lives again!!!
Matt
Old 03-31-2021, 10:30 AM   #248
Wgesnerjr
Wgesnerjr's Avatar
Great Job!! Love the look with the air cleaner on top. Nice color choice too.
I noticed that you have the heater hoses blocked off. I remember seeing something that LS engines did not like the heater lines capped off. (Someone correct me if I'm wrong) I think you had to loop them to solve the issue.
It was suggested to run a u-hose to solve. Like this: https://www.amazon.com/BLACKHORSE-RA...31773043&psc=1
I think this was where I read it:
https://67-72chevytrucks.com/vboard/...ht=heater+hose
Thanks for the write up!
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 03-31-2021, 02:47 PM   #249
68Stepbed
68Stepbed's Avatar
I've had the ports blocked off since I did the swap several years ago. I've never had an issue with overheating or cooling.
Matt
