07-04-2012, 12:37 PM | #226 |
10/30/19
Re: the remains form swap meet 67-72 truck parts
Hey Randy, I am needing a 67-68 steering wheel and a 72 drivers side sport mirror, also I am needing an ochre 69-72 hood. Keep me in mind when you get your fleet in please.
Thanks. Posted via Mobile Device |
07-04-2012, 03:48 PM | #227 |
i could use a good antenna with coax? Price shipped to 50056?
07-05-2012, 12:34 PM | #228 |
Just like to part out trucks!!
Scott, I'll let you know if I get any of that in
tumbleweed68, I think I have a couple antennas out there, I will look this afternoon Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
07-05-2012, 12:47 PM | #229 |
07-05-2012, 11:00 PM | #230 |
Randy, if you have a clutch pedal, pedal sleeve, the bushings in the sleeve and clamp plus two decent pads, USPS to Canada, T2Y 1G1 can you PM me details?
07-07-2012, 04:16 PM | #231 |
I have a complete clutch pedal setup out there for $25 plus shipping. Thanks Randy
07-07-2012, 07:15 PM | #232 |
Randy, you had a slew of original engine bay hose clamps in one of the first pics. I am wanting all of them. Would you do $1 a piece? or just let me know how many you have and what price you have in mind. Thanks, Rich
07-09-2012, 12:23 PM | #233 |
randy, if you gt a 67 with a metallic green interior, i need the arm rest, and steering wheel.., also the core support if it's worth it..
07-09-2012, 09:14 PM | #234 |
cancel the clutch thanks
07-09-2012, 09:17 PM | #235 |
Rich, yes I have quite a few, I need to go through them and see what I need for my blazer first
jwadahl, sorry none of that right now swag, no problem Thanks Randy
11-04-2012, 12:39 PM | #236 |
I still have alot of these parts out there plus some more since this thread was started. Thanks Rady
11-04-2012, 02:32 PM | #237 |
have '69 C10, swb no power steering, need a steering column, have floor shift for auto. trans, just need turn signel arm, is that something you have, also would you have a power steering gear box and rest of set up for a small block engine.
11-04-2012, 02:52 PM | #238 |
Hey Randy... did you get a 67 in that has the side trim, ignition switch.door locks, Bright headlight trim rings
11-04-2012, 03:41 PM | #239 |
Randy will you price this list, 2 windshield wipers, air breather and carb spacer for 4 barrel, spare tire hanger and bolts,valve cover and oil fill tube, am radio and speaker. Thanks Carl
11-04-2012, 08:13 PM | #240 |
philB, I have a turn signal arm out there. Are you wanting a whole column? I have a PS box $25 and PS pump and brackets $40 but no motor pullies. Plus shipping
Dan, sorry none of those years yet Carl, no oil filler tube or radios right now, but I have the other stuff, I'll post pics here in a bit Thanks Randy
11-04-2012, 08:48 PM | #241 |
Cal, here is what I have, air cleaner and spacer is off a BB but are the same except you'll have to get a new rubber hose for spacer to go to PVC valve. Also on the spare tire holder, I have the nut but no bolts
11-04-2012, 10:21 PM | #242 |
GM ONLY BABY!!!
Got any horns? High and low note please.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
11-04-2012, 11:30 PM | #243 |
ok, you got my message on the doors, the g/box for 2wd and pump& brackets for a small block, ok, the column from yhe s/wheel thru the firewall, don't need the signel handle.
11-05-2012, 01:43 AM | #244 |
chevydogg66, sorry no horns
philB, I don't think you asked me about doors. PS stuff is for small block. I have columns, I'll get pics of best one, $70 shipped for one Thanks Randy
11-05-2012, 02:24 AM | #245 |
Hi Randy,
Do you have a window crank handle in good condition for a 67? I'm tired of these cheap repops leaving me with the knob in my hand and the window cranked half way up. :-) Thanks, -mike
Mike 67' GMC Fleetside |
11-05-2012, 05:53 AM | #246 |
Got any decent headlight bezels and light retainer rings for a 70 Chevy? price and shipping to 33578. Thank You
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
11-05-2012, 09:03 AM | #247 |
Mike, I have a few 67 handles out there
jjzepplin, I have quite of few of the steel painted bezels out there and also the the rings for headlights, I will get pics tonight Thanks Randy
11-05-2012, 10:05 AM | #248 |
just waiting on your total on parts,.
11-05-2012, 01:44 PM | #249 |
PhilB, it will be later today, I am at work right now. Thanks Randy
11-05-2012, 07:42 PM | #250 |
PhilB, here is the box and pump with brackets, it will probably need new hoses. Also pics of steering column. $110 shipped for the ps stuff and $70 shipped for the column $180 total, are you needing the linkage for tranny to column, if so another $25. Here are pics. Thanks Randy
