Old 09-29-2012, 04:03 PM   #226
67cheby
67cheby
67cheby's Avatar
Re: Project#2 67-72 Restoration's Shop truck
great progress!
67cheby is offline   Reply With Quote
Old 09-29-2012, 06:12 PM   #227
2manyprojects
2manyprojects's Avatar
I just saw this one, very cool. I think it's my favorite of all your projects. I plan to be in Richmond the next 2 weekends if you need any misc parts. I've been lazy and haven't got rid of any 67 stuff yet.
Did you get a chance to check the ratio on that rear if you still have it?
65 Chevy C10 Panel http://67-72chevytrucks.com/vboard/s....php?p=7148391
42 Chevy 3100http://67-72chevytrucks.com/vboard/s...92#post7184392
96 GMC K2500 Diesel Suburban
89 GTA Trans Am Convertible.
2manyprojects is offline   Reply With Quote
Old 09-29-2012, 09:22 PM   #228
brn agn
brn agn's Avatar
Bye bye crossmember! Those things can be a pain, can't they? Keep up the hard work. You are making great progress. I think we should set up a photo shoot with our "shop trucks" once yours is done.
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 09-30-2012, 01:22 AM   #229
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by NewType72 View Post
Looks awesome lovin the progress and those caps are awesome perfect patina match too!
Thanks, I really like them! My wife....not so much good news is she wants me to get 20's asap....bad news is... $$$
Originally Posted by 67cheby View Post
great progress!
Thanks....trying to buy, start and finish my build before you finish your wiring
J/k
Thanks. It's my favorite too! I checked and found a code but haven't found it listed anywhere...need to look at it again and will let you know the code so maybe you can confirm its' ratio...
It took way too long and injured me...so yes...a pain
And a big 10-4 on the photo shoot....I'll bring the red and white....you bring the blue
Trying to get pics uploaded now...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-30-2012, 01:54 AM   #230
VA72C10
VA72C10
VA72C10's Avatar
Still working on pics...but progress today consisted of: removing the clutch pedals, column, and intermediate shaft. Also got the gas tank re-installed and connected other than sending unit wire. Still have to bolt it down and put my NOS filler neck grommet on I emptied the tank being used (from my 70) and no sediment or rust inside
Got the repairs skim coated and will sand and paint tomorrow. Found a rattle can of gloss red paint on my shelf. Test sprayed a spot behind where the bed will be and sanded down witbh 2000 wet/dry (dry) and was pleasantly surprised by the closeness of the color match. Will help in areas I have to cut out sheetmetal...especially the cab corner and lower door on pass side.
Drilled out and collapsed another intermediate shaft I had to use with the van tilt.
Sprayed my new rag joint and the int. shaft and need to remember to paint one of my ps boxes tomorrow... also painted thepower brake booster brackets. Booster has been painted
Old 09-30-2012, 01:56 AM   #231
VA72C10
VA72C10
VA72C10's Avatar
Pics
Old 09-30-2012, 02:04 AM   #232
VA72C10
VA72C10
VA72C10's Avatar
Good, they worked I used the smallest hole saw I had, then used my copper spoon to fill the hole the center bit makes, put the patch in my vice and ground down to size. Patches came out very well considering I still am using flux core at home.
More pics
Old 09-30-2012, 02:06 AM   #233
VA72C10
VA72C10
VA72C10's Avatar
First pic shows the driver's rocker opened up and rust converter sprayed liberally all inside
Then the second pic is a light skim coat on the driver' s upper channel patch.
Old 09-30-2012, 10:46 AM   #234
VA72C10
VA72C10
VA72C10's Avatar
Here's a picture of the gas tank in place with the fuel line connected (I blew air through the lines first and they were surprisingly clean).
I wouldn't have painted the tank but it had some overspray on it and since my bench tilts forward...I wanted it to look good back there
Old 09-30-2012, 03:06 PM   #235
BMERDOC
BMERDOC's Avatar
Nice job! Things are going quickly. I hope you have some more of those panels. The Old Man may need some of them!
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 09-30-2012, 04:41 PM   #236
VA72C10
VA72C10
VA72C10's Avatar
Thanks, I have a few more of the panels....fit isn't very good but I only use them sparingly and save the leftovers for small patches...
Especially with this being a patina truck I'm trying to cut out as little as possible...
Out to work on it some more....
On the way home from Church I bought the rest of the fluids needed to fire up the engine..... that stuff adds up quick....priced it at auto zone and bought for around 20 cheaper at walmart...
Old 10-01-2012, 02:50 PM   #237
VA72C10
VA72C10
VA72C10's Avatar
Progress yesterday...not as much as i'd like and after another dr visit this morning and my wife's bday this evening....trying to fit in a few hours work on the truck....
Old 10-01-2012, 02:52 PM   #238
VA72C10
VA72C10
VA72C10's Avatar
Old 10-01-2012, 03:10 PM   #239
shawno72
C/10 junkie
shawno72's Avatar
Looking real good as usual..
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 10-01-2012, 03:50 PM   #240
Bennett68C10
Bennett68C10's Avatar
Nice progress
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 10-01-2012, 05:07 PM   #241
Xeen
Xeen's Avatar
Looking good, How long untill we get to see a video of the engine running?
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-01-2012, 06:03 PM   #242
68 Four on the Floor
68 Four on the Floor's Avatar
Wheres the air dash at?
68 Four on the Floor is offline   Reply With Quote
Old 10-01-2012, 10:07 PM   #243
Rusbuilt
Rusbuilt's Avatar
Nice work!
Rusbuilt is offline   Reply With Quote
Old 10-01-2012, 10:09 PM   #244
VA72C10
VA72C10
VA72C10's Avatar
Thanks!
Originally Posted by Bennett--G4L View Post
Nice progress
Thank you...a few things took longer than the last time I did them and had to repaint my steering wheel due to humidity and now I'm completely stripping it...
Hopefully by the weekend
In my house need to put my locks in first
Old 10-01-2012, 10:31 PM   #245
VA72C10
VA72C10
VA72C10's Avatar
Got the wiring harness in....forgot my 70 was floor shift so have to figure out the nss wiring. No cuts or splices on it though as I remembered and as mentioned...everything worked on my last truck using this harness...
Got the brake rod hooked up to the pedal....forgot I had to drop the column for that...doing things a little out of order as I rush...had to take the ebrake
Got the driver's rocker repaired (patch cut and welded) and skim coat on it. Also re-skim coated the rear patch a final time.
Got my gmc pauls weatherstrip installed on the passenger side...very nice! They do need extra force to shut the door but not absolutely slamming the door.
Painted the frame of my bench seat so it'll have time to dry before it gets re-covered
And installed my painted jack and the jack sticker...
Better pictures tomorrow pending weather (supposed to rain)
Old 10-01-2012, 10:33 PM   #246
VA72C10
VA72C10
VA72C10's Avatar
Sorry, keep forgetting to take pictures....the ones above show the patch panel I cut down for the rocker and the wheel with horn cap...you can see the paint looks weird...it started cracking
Old 10-01-2012, 11:25 PM   #247
Xeen
Xeen's Avatar
I looked and couldnt find any paint specialy formulated for steering wheels, im wondering if its just a matter of getting the surface rough enough so it isnt slicker than snot so the paint will bond to it, im guessing its a super tight pore plastic so the paint is having trouble adhering to it, but there has to be a product or combination of prep and product that will make it so that primer will stick.
Old 10-01-2012, 11:31 PM   #248
VA72C10
VA72C10
VA72C10's Avatar
It's actually just impatience by me....it was looking pretty good but I sprayed one more coat today (not waiting the 24hrs) and then an engine clear coat with a light rain outside (100% humidity) and you're not supposed to use if over 60%...it cracked right up....
Old 10-01-2012, 11:36 PM   #249
Xeen
Xeen's Avatar
Oh ok thats what I get for assuming it was'nt user error hahaha!
Old 10-02-2012, 03:18 AM   #250
ZUBZ
ZUBZ's Avatar
Dremel comes in handy....
ZUBZ - C10 "GUS" - JOHANNESBURG, South Africa
My 1970 C10 Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542560
ZUBZ is offline   Reply With Quote
