#226 |
Re: LT1 Burbs 65 Stock SW Build
#227 |
#228 |
#229 |
#230 |
![]() Join Date: Aug 2013
#231 |
Don't be a bonehead like me and check to make sure your fender extensions or cowls, whatever they are called, are not the same side. I got my original Harrison rad recored also.
#232 | |
Hope those new bed sides are up to spec. Looking really great. |
#233 |
Cleaning up some odds and sods, went to put the driveshaft in but found it was 1" to long. I bought it from a member on here but I guess it was never installed. I also had to weld up some holes on the inner fender that had been drilled in to move the voltage regulator. Fenders and grille surround should be installed for the last time. I am going to build a better more permanent paint booth in my garage so that I can get this thing painted.
#234 |
Very nice build
1964 Chevy Factory K10 Short Bed Mitchell Sampson |
#235 | |
#236 |
My bedsides showed up from FredsTruckParts and I sanded them down and worked on them. They were pretty decent and much better then the 4 I have spent over 1500.00 on.
#237 |
I then put the bed together and marked out the trim holes and drilled all of them.
#238 |
I probably put 8 coats of 2k on these sides and now at 600 with wax degreaser they really shine. I spent hours with paper wrapped around items as small as a pencil trying to get into hard to sand spaces, hopefully it shows when color is on.
#239 |
I am in the middle of hood surgery, the sandblasted hood I had stored inside for 2 years was junked and the old hood I had outside for 2 years was used. The sandblasted one was heavily pitted from what I don't know and it had a large in-dent in it, but I needed the inner structure out of it. I ordered a new lower panel so got back to drilling spot welds. I used this time to POR15 the inner structure so I will never have to worry about it, also ground of the original paint on the next known bad spots but found no rust.
#240 |
New panel installed.
#241 |
Looks like it is coming along fine.
Great work as always. I bet you can't wait for the sanding to be done with. |
#242 |
Nice work
#243 |
Good job on the hood panel
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
#244 |
Your build sucks, can you tell im jealous cuz mine is still in pieces? great work sir!!!
#245 |
Had to swap garages last weekend to do maintenance on the kids cars, I booted the wife's car out.
#246 |
Thanks guys, sanding and bodywork sucks. Did get my seat recovered and my front bumper and guards rechromed.
#247 |
In between sanding I have been doing other things like rebuilding my evaporator.
#248 |
Rollin' Old Skool
Nice progress! Been keeping up with you on Facebook as well.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#249 |
Great Job. Top quality work bar none.
Will you make it to PIR? |
#250 |
Pm your shipping info, i got a little somethin for ya!!!
