Old 12-05-2012, 08:09 PM   #226
gdavis
gdavis's Avatar
Re: 1968
I also sanded the drivers side inter fender and painted it black
gdavis is offline   Reply With Quote
Old 12-05-2012, 08:14 PM   #227
gdavis
gdavis's Avatar
Re: 1968
This is all the sheet metal I have to do. all is on the drivers side. Tomorrow i am going to dry fit the pass side door. I hope it turns out as easy. something tell me it want. anyway keep your fingers crossed. I also want to install the outer rocker on pass side. and maybe if I have enough time I will tackle the damage uner the rain gutter on drivers side. That is my plan for tomorrow.
Old 12-05-2012, 09:21 PM   #228
Xeen
Xeen's Avatar
Re: 1968
Man I wish I could be there in person to help you out with this you have a ton of metal work that isnt exactly easy when you dont know the tips and tricks for making it easy, unfortunately I'm half a country away.
The right way to do what your doing is to weld in a brace between the A&B-Pillar to keep it from moving before hand if you feel you absolutely must remove the inner rocker and floor at the same time, I dont know if you ever plan on doing another one but now you know for the future.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 12-07-2012, 11:49 PM   #229
gdavis
gdavis's Avatar
Re: 1968
thanks for offering to help. But as you said it is a long way to comute. As far as the brace for the pillars are. their was now difference in the expance of the pillars. Due to the rotten metal where the bolts are. the bolt heads were rusted all the way thru. But you are right about the braces the next time I will have all my metal patches on hand before i do any cutting and braces installed.
Old 12-07-2012, 11:58 PM   #230
gdavis
gdavis's Avatar
Re: 1968
day, i finshed the pass door outer rocker. It wanot as easy as the drivers side. I had t cut the inter rocker lose and fit it to the door. But it works good now. I hop etheir is no difference between the old door and the new ones I am buying.
Old 12-08-2012, 12:02 AM   #231
gdavis
gdavis's Avatar
Re: 1968
also I applyed some bondo on the fire wall where the welds were and now they are not as easy seen. and i manage to tackle the rain gutter and I cut the old damage out and I will weld it up tomorrow.
Old 12-08-2012, 12:05 AM   #232
Bomp
Bomp's Avatar
Re: 1968
When ever I check your build I sit, look, stare, and am totally amazed at your progress.
Bomp is offline   Reply With Quote
Old 12-08-2012, 12:52 AM   #233
Xeen
Xeen's Avatar
Re: 1968
Nice job on the rockers and the floor.
Do you plan on doing an aftermarket Air Conditioning unit like Vintage Air?
Old 12-08-2012, 11:30 PM   #234
gdavis
gdavis's Avatar
Re: 1968
Yes I am planing on air conditioning. here in Florida it is a must have. But it will have to come later.
Old 12-08-2012, 11:44 PM   #235
gdavis
gdavis's Avatar
Re: 1968
thank you very much. I take my time and try to fix everything at least two or three times. only kidding. But thanks again. it means a lot to me to hear from you.
Old 12-08-2012, 11:47 PM   #236
gdavis
gdavis's Avatar
Re: 1968
Today I played hookie from my build.Instead of working on my truck I hung Christmas light on the house.But it was for a good cause. Thee boys like it. I hope.My two adophed boys are 7 and 5 And I am 63 they keep me going around in circles.
Old 12-09-2012, 10:01 PM   #237
gdavis
gdavis's Avatar
Re: 1968
Today, I just applied some bondo on the rear of the cab. I will sand it tomorrow if and when I get to it. First, I am going to finish the welding on the rain gutter. I got it cut out and the metal cut and ready to be welded back in. Need to put something in the bad area. such as a sealer so the rust will slow down. I know I want be able to stop it. At least it will be slower.
Old 12-09-2012, 10:14 PM   #238
Shaun1162
Shaun1162's Avatar
Re: 1968
Boy, you don't waste time! Great looking build, glad to see it staying pretty much stock! Are you new wheels going to fit though? I thought all 1/2 tons with drums in the front had 6 lug pattern..
- 2010 Silverado
- 1984 Chevy M1028 (K-30)
- 1969 Chevy C-30
- 1933 Ford Stock Car
Shaun1162 is offline   Reply With Quote
Old 12-09-2012, 11:48 PM   #239
jonny..2008
Re: 1968
mr davis i am still following along and am happy to get an email everyday with the update.
i dont envy the amount of work you have, i envy the fact you get to work on tour truck every day though.
i love every machine. even the ones i hate.
Current project (1959) fifty niner gmc fleetside:
http://67-72chevytrucks.com/vboard/s...70#post6514670
MY daily driver truck thread : http://67-72chevytrucks.com/vboard/s...d.php?t=544460
jonny..2008 is offline   Reply With Quote
Old 12-10-2012, 12:08 PM   #240
67cheby
67cheby
67cheby's Avatar
Re: 1968
nice progress
67cheby is offline   Reply With Quote
Old 12-10-2012, 09:14 PM   #241
gdavis
gdavis's Avatar
Re: 1968
No the wheels did not fix. they were off a 90's pickup. I am installing a 1972 front and rear sup. that way i can get the advantages of a 5 lug systems.and disk brakes. I only paid 200 for the rollin chassis and I already got my money worth off the frame without the sup.
Old 12-10-2012, 09:16 PM   #242
gdavis
gdavis's Avatar
Re: 1968
thank you. I like working on my truck. It keeps me out of the house and from under my wifes heels
Old 12-10-2012, 09:17 PM   #243
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by 67cheby View Post
nice progress
thanks I try
Old 12-10-2012, 09:28 PM   #244
gdavis
gdavis's Avatar
Re: 1968
Today, it is as good as it gets. Today i was watching my Grand daughter while I was working on my truck. She looks a lot le me don't you think. I finshed welding. Before I started watching her of course. She came out later. Like I said I finshed welding the cut out damage under the rain gutter on the drivers side.
the first picture is te cut out damage and the restis the repair.
Old 12-10-2012, 09:31 PM   #245
gdavis
gdavis's Avatar
Re: 1968
And here is my helper I think I will give her a raise. She works like I do. work a little and plays a little. But she is my pride and joy.
Old 12-10-2012, 11:53 PM   #246
Xeen
Xeen's Avatar
Re: 1968
I dont know how far you are into the 72 brake retrofit plans but you will also need one of the rear crossmembers from the 72 frame where the brake hose attaches. Its not too horribly bad to remove, just a couple rivets. If you are like me you would rather have your fingernails torn off with pliars than remove frame rivets
Good job on the door frame rust repair.
Old 12-11-2012, 07:51 PM   #247
gdavis
gdavis's Avatar
Re: 1968
when was taking the brake lines off the rear I notice the cross member. So you say that I need that also. good I will take it off and install it on the 67 frame. Thanks for the information on that cross member. and thank for the that a boy on the rust on the rain gutter.
Old 12-11-2012, 08:25 PM   #248
gdavis
gdavis's Avatar
Re: 1968
So, today I just about finshed droing the front end on the 1972 frame. here are some of the pictures of the 72 frame. Tomorrow I will finshed dropping the front end and then start cleaning the cross member.
Old 12-11-2012, 08:30 PM   #249
gdavis
gdavis's Avatar
Re: 1968
the first three pictures are the mistake I made on the front fenders. I must of have had a brane freeze. I sanded two fenders and primed them 1969 and a 1967. so i am fixing the 67 fender i have a good 69 but i want then to match.
Old 12-11-2012, 08:32 PM   #250
gdavis
gdavis's Avatar
Re: 1968
here is the rest of the frame not going to use.
