Old 08-09-2013, 11:04 PM   #226
6BT 56
6BT 56's Avatar
Re: My 56 6bt 4X4 build.
So I got my speedo working now. I got a cable extension just as Orrie did . worked sweet. It reads abt 10 mph slow. I have a adapter that gears up by %13 so I will install that as well that should get me real close to where I need to b.
I will post the p n for you if you like Luther . Got it at NAPA,
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 08-12-2013, 11:14 PM   #227
Luther Grimace
Luther Grimace's Avatar
Awesome! Can't wait to see the pics! Did you just remove the electric part?
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
Old 08-17-2013, 01:57 PM   #228
6BT 56
6BT 56's Avatar
Hi Luther
Yep just ditched the electric thing . When I un did it there was just a normal 7/8 speedo cable end under it .
I went to Napa and got a 30 in extension cable
Pn 615-1618
Worked good .
My speedo is abt 10 mph slow . Your speed may be closer with the 36's
As the truck is actually going faster than it will say it is . I have this cool little adaptor that goes inline and speeds things up by 13% but it needs small keyed speedo cable parts that im missing . I guess I will have to hunt around to see what else i can find .
Im driving the truck lots tho . A new steering box is next on the things to do list . Just got to do some shoppong for one I can afford .
Old 09-29-2013, 10:03 PM   #229
6BT 56
6BT 56's Avatar
So I have a up date. After a super summer cruzen aroud in the old truck I m so glad
I did this swap. It still needs lots of little tweaks but these old trucks always do . It never needs fuel it just keeps going and going I took it to the local truck pull last nite . The truck weighed in at 5275 lbs with me in it . The guys at the track said because it was a diesel truck I had to run in the 6500 to 8500 lb class. I was a a disadvantage to say the least . The average truck was a common rail cummins or a turned up d max . All running nice beefy tires and weighted up to be just under 8500lbs The winner pulled 277 ft . When the dust settelled the old gmc still pulled off a 187 with a top speed of 13 mph lol. Not bad for her first pull with a almost bald set of good year wranglers . I may have been able to muster a few more feet but I had to pedal it a few times as the front axle was wheel hopping badly. Once it found it's groove I was able to keep it pinned till we came to a hault at 187 . This winter will be all abt the tweaks . I cant wate till next year . We actually have 3 pulls within half a hour of home . Looking forward to some fun !
Old 09-30-2013, 12:51 AM   #230
Luther Grimace
That is pretty awesome! What gear did you run in when you pulled? I have never pulled. kinda wonderin the technique. I was talking with someone last night about taking my truck to some pulls in southern middle TN.
Old 09-30-2013, 10:02 AM   #231
6lcummins
That depends on power you think you have, the gears you have, and tire size. I'm not sure what you have done to your engine but I would probably run 2nd gear if you have taller gears and taller tires. Otherwise 3rd gear but that will take more slipping and you can warp/fry a single disc clutch easlily starting the sled. And of course LOW side.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 09-30-2013, 10:22 AM   #232
6lcummins
Weight isn't always your friend. It's more about transfer of said weight and your hitch design. I know my old 88 Chevy CCLB DRW weighed in at 6800 and I usually pulled that, my 96 Dodge, and my little brothers F350 ECLB DRW all at 7200 pounds.
Granted our friends 2.6 truck weighs in at 5700 lbs and he hangs enough to be barely shy of 8000#. He also has a purpose built hitch and weight box.
"STOCK"
ASSEMBLY THREAD
Old 09-30-2013, 04:11 PM   #233
Luther Grimace
So that is in 2 hi? My truck is 3.54s and 37" tires with just the pump turned up. I don't think my truck could pull the 180' or so that the 56 6bt pulled. He has the non intercooled first gen with the bigger stock injectors.
Old 09-30-2013, 09:54 PM   #234
6BT 56
6BT 56's Avatar
Hi Luther. I pulled in low range 2nd gear . It was just rite to get moving Im glad I had a little spin at first to get the thing spooled up . Once I got into it it was on the stock rev limiter , 2200 ??? all the way . Once the weight moved up the sled it parked me in a hurry. Pulled the rev's down a bit but promptly broke traction. I think with the fuel pin and govinor spring installed it would be just rite . I had them in the glove box but they didnt seem to do much Im trying to get the vid on here but my wifes phone dosent seem to be able to make it happen .
I have the same eng you did at first. 92 inercooled . I ditched the inercooler on install tho due to fitment . I dont have to tell you how tight these engines fit tho !
Does anyone know how, or if I can move my thread to the diesel swaps section ? I seem to spend all my time there now seeing what everyone is up to .
Old 10-01-2013, 11:51 AM   #235
6lcummins
LOW side, you don't have the 1300HP it'd take to succesfully run 2nd High. If you put smaller tires on it would help a lot for pulling but that is a pita. And all 1st gen Dodge Engines started off as 160HP. Launch is the biggest determiner of how far you will go in all honesty.
As far as gear ratio goes, NV4500 gear selection from low to high:
2nd Low
3rd Low
2nd High
4 Low
You have to get one of the admin or mods to move the thread.
As far as rpm you are right about the defuel point, but the GSK will help along with the Fuel Pin.
I know on my 1988 Chevy I just had a set of "90HP" injectors, HX35, and single sceramic disc clutch and it owuld get 250-310ft back in the day. It was also a non IC ag VE setup.
"STOCK"
ASSEMBLY THREAD
Old 10-02-2013, 08:07 PM   #236
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
"I had them in the glove box but they didn't seem to help" LMAO! That's hilarious! I'm glad you had fun! Yes, the tires and gears weren't your friend on the pulling track. But at least you tried it!!!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-16-2013, 08:08 PM   #237
6BT 56
6BT 56's Avatar
Hi guys . Ya the pull was a riot . I will get some new rubber this winter and turn up the fuel a bit and have some fun next year for sure . I bet those parts are real effective when you actually install them in the pump . Lol. Rite now my weak link is the coupler between the t c and the trans . The teeth on it are quite sharp . On it way out for sure . I went for a tour this wknd to a old local marina and snapped a few pics . Think they look kinda cool .
Old 10-17-2013, 08:34 PM   #238
Dieselwrencher
It looks awesome man!!! I think PATC might sell the coupler but I'll have to recheck that.
Ryan
Old 10-17-2013, 08:44 PM   #239
ryanroo
ryanroo's Avatar
it certainly does look cool! i think, but dont quote me, that there are a few places around that you can get a hardened beefcake version of the spud coupler.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 10-17-2013, 10:25 PM   #240
6BT 56
6BT 56's Avatar
Hi guys . Thanks for the replies . I asked abt the coupler a while ago and a ton of people replied with links and such. Thats deffinately on my to do list . The shafts look like new but I dont need to spin it as im certan they would not look new after that . Im looking forward to getting my 70's hub cabs painted up and installed as well. I think they will really suit the old girl. Thanks again for the comments .
Old 11-03-2013, 10:40 PM   #241
6BT 56
6BT 56's Avatar
So if this works here is the vid of my truck at the pull. You can hear in the vid I had to pedal it bit becouse the front end was starting to wheel hop
Old 11-03-2013, 10:44 PM   #242
6BT 56
6BT 56's Avatar
Holly crap that worked !! I guess a 13 year ols is good for something after all . Lol..
I want to do a good walk around vid now that im a you tube wiz .... or al least I have one in the house .
Old 11-04-2013, 12:03 AM   #243
Luther Grimace
Great pull! Truck looks awesome. How many feet did it pull? Or meters? :p I know how you crazy Canadians are with the Metric system.
Old 11-04-2013, 12:24 AM   #244
6BT 56
6BT 56's Avatar
We still measure the pulls in the same way yall do . lol. I pulled 180 -190 sumtin feet. not bad considdering the winning truck was a 94 twinturbo truck done rite up for pulls . Still a street truck tho. He pulled 277 ft . Sure was fun.
How is your truck doing ?
Old 11-04-2013, 01:08 AM   #245
OrrieG
OrrieG's Avatar
Fun to watch. I know all about having the teen grandkids taking care of the modern technology for me.
OrrieG is offline   Reply With Quote
Old 11-04-2013, 09:26 AM   #246
brimc
brimc's Avatar
Great looking pull for the first time in the New truck! Was that at Oro? I try to go there every year but didn't make it this year cuz I had to work.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 11-04-2013, 12:21 PM   #247
Luther Grimace
I think that is a very respectable pull for basically a stock engine. I bet folks were shocked when an almost 60 year old truck was out there owning that sled.
My truck is doing good. I have got the 37s figured out. I was having balance problems with them. I just need to finish up the floors and all the insulation. I definetely need a heater if I plan on driving it this winter. I'm hoping we get a good snow so I can play around in it :p
Old 11-05-2013, 08:30 PM   #248
mud.man.rj
mud.man.rj's Avatar
Just watched the video, very nice pull, wow.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 11-06-2013, 07:49 AM   #249
longbike
longbike's Avatar
Great truck love the weathered paint!
And great pull, you did it in style with ol-blue!
longbike is offline   Reply With Quote
Old 11-06-2013, 10:35 AM   #250
Dieselwrencher
Your pull looked very nice! I can help you get that truck going twice as fast going down the track over the winter if you want?
Ryan
4x4, cummins, napco
