Old 07-13-2015, 08:55 PM   #226
LVPhotos
LVPhotos's Avatar
Re: LVPhotos 1962 Build
And back together.... next transmission crossmember.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 07-14-2015, 01:58 PM   #227
Vincenthdfan
Hey there...couple of questions for you.
I too, have a 62 and love your grill.
I take it that it's chromed steel, yes? Did you have it chromed?
If so, who and how much? I have a spare steel one that I need to get chromed.
Also, your front fenders, it would appear you bought aftermarket replacements.
Who from and how did they fit??
Thanks in advance...love your truck!
Vincenthdfan is offline   Reply With Quote
Old 07-14-2015, 02:41 PM   #228
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Cool build
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 07-14-2015, 05:41 PM   #229
LVPhotos
LVPhotos's Avatar
That is my original grill, originally white. Was chromed years ago, assuming it was sent to CA, top notch job cost was $350 then there was a dent driver side that was fixed only tool mark is inside the L. The fenders were bought years ago, I would suggest Goodmark or any other OER dealers. Tuckers Classic Truck here in Las Vegas is normally my goto, now they changed vender and I started a broken budget I go to who has the better product.
Old 07-14-2015, 05:50 PM   #230
LVPhotos
LVPhotos's Avatar
Pic.
Old 07-17-2015, 05:23 PM   #231
LVPhotos
LVPhotos's Avatar
Transmission crossmember welded up and smoothed out, ready for some paint.
Old 07-17-2015, 06:58 PM   #232
LVPhotos
LVPhotos's Avatar
Bam! And used up the last of the paint.
Old 07-18-2015, 01:47 PM   #233
LVPhotos
LVPhotos's Avatar
All in and on ground. Why would you fully polish stainless steel and then put a sticker on it that won't come off?
Old 07-28-2015, 11:24 AM   #234
rpone605
Nice looking 62. On the cab mounting did you mount it without the factory square brackets or did you channel the cab?
rpone605 is offline   Reply With Quote
Old 07-28-2015, 11:45 AM   #235
LVPhotos
LVPhotos's Avatar
The cab is the only thing that has not been off frame. It still sits on factory mounts.
Old 07-29-2015, 07:59 PM   #236
LVPhotos
LVPhotos's Avatar
That's all she got. Bumper on ground. That is not dog slobber under the headlight, but a tear for not being driven!
Old 07-29-2015, 10:36 PM   #237
joedoh
joedoh's Avatar
looks great!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 08-02-2015, 02:25 PM   #238
LVPhotos
LVPhotos's Avatar
Box of wire and fan control from Speedway Motors. Small 12 circuit mini fuse block.
Old 08-02-2015, 02:28 PM   #239
LVPhotos
LVPhotos's Avatar
Block
Old 08-19-2015, 08:15 AM   #240
verdell
verdell's Avatar
Originally Posted by LVPhotos View Post
Still on jack but tucked all the way. No bump stops or pipe notch. Yet.
Hey, do the 295's fit without rubbing the rear wheel tubs on the inside? I'm looking at the same size for the rear but was wondering if I would have to modify by stock wheel tubs. I have a 1965 12 bolt rear. Also, your project looks great..
verdell is offline   Reply With Quote
Old 08-19-2015, 12:07 PM   #241
LVPhotos
LVPhotos's Avatar
There is a 1/4" rub each side dead center of my aftermarket tubs bulge. That's from side to side movement. My rims are "4.5 inch backspace " Rims can set different with same backspace. No need to trim outer, plenty up travel as well. If your not hitting turns hard or use something other than panhard bar... triangle or watts link.
Old 08-19-2015, 01:03 PM   #242
verdell
verdell's Avatar
My wheels are 5 inch backspace so it looks like I'll be doing the tubs. Thanks for your help, LV...
Old 09-04-2015, 10:19 PM   #243
LVPhotos
LVPhotos's Avatar
Working again so here it sits once again.
Old 05-05-2016, 08:05 PM   #244
LVPhotos
LVPhotos's Avatar
Been awhile since I been home. Parts on order and shop time reserved. Dirty but looking good!
Old 05-10-2016, 02:57 PM   #245
ebaby35
How do the new PB trailing arms attach to old crossmember do you have a pic?
ebaby35 is offline   Reply With Quote
Old 05-10-2016, 04:46 PM   #246
LVPhotos
LVPhotos's Avatar
I don't have a good picture. It bolts in like stock. The rod ends have a "cone" spacer on ech side to center it.
Old 05-12-2016, 07:37 PM   #247
LVPhotos
LVPhotos's Avatar
Chrome plated IDIDIT column in.
Old 09-12-2016, 08:09 PM   #248
LVPhotos
LVPhotos's Avatar
New 2 piece driveshaft, new exhaust. Ebrake cables and brake lines. And of course the pictures will be sideways!
Old 09-17-2016, 10:01 AM   #249
LVPhotos
LVPhotos's Avatar
Trying to right pic.
Old 10-19-2016, 06:21 PM   #250
LVPhotos
LVPhotos's Avatar
Back in action! All new parts in and testing. Don't like the power brakes(too squishy) so the vacuum line is caped. The quick ratio manual rack is a bit ruff. Fast and sensitive. Going to get some cleaning done and have it out for the weekend.
1962 chevy, bagged c10, manual transmission, short bed c 10
