03-15-2014, 02:34 AM | #226 |
Re: 1971 K20- project just get driveable!!
This is a great thread! Good looking old farm truck!
03-17-2014, 12:32 AM | #227 | |
Vintage 4x4s
You would be better off with a set of brackets like I've got since they bolt to a longer section of frame. The load on the frame is directly proportional to distance between the front and rear set of bolts. Thanks, I am having fun and not sweating scratches with this truck!
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
03-17-2014, 12:39 AM | #228 |
Vintage 4x4s
Belts and seat in. I like the belts but the hardware kit didn't have the coarse thread 1/2-13 bolts. also I should post pics of the driver side retractor position for some opinions. the tank forces it out and not in the best spot. I may just drill and mount it to match passenger side angle.
03-17-2014, 12:49 AM | #229 |
Great looking truck!
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
03-17-2014, 04:09 AM | #230 | |
I get what your saying tho, the breaking forces on a drop hitch would transfer to the hitch and frame so a longer hitch flange would help distribute the force along the frame. with my rear fuel cell i was having doubts about drilling thru and sandwiching the tank flange with the rear bolt of my old hitch, still thinking about possibly adding some kind of bracing to the new one. Maybe after I'm finished struggling with my rear quarter damage I'll spend a little time rethinking the issue.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
03-18-2014, 10:12 PM | #231 | |
Vintage 4x4s
03-26-2014, 08:00 PM | #232 |
Vintage 4x4s
Swapped the rebuilt carb on the truck and took it for a spin. Got insurance on it now too! Nice to have a seat in it Pulls to the right still, need to work on front brakes and tune the engine, she stumbles a bit on accel but then pulls pretty good so should just be a matter of tuning.
03-26-2014, 08:06 PM | #233 |
Vintage 4x4s
Picked this diesel truck up on Saturday, Not sure what truck the parts will be used in. Its got a gearvendors setup, overdrive (getrag 5spd), dana 60 front and 3.55 gears.. so you can idle at a cool 50mph! Shes rusty and the Dana 70 rear is junk.
I think for now I'll swap in a Dana 60 3.55 rear I have to see how good the driveline is and how I like the gearvendors.
03-26-2014, 08:22 PM | #234 |
Crusty Old Dodge... but it might make a good winter rat... u have all summer to seal it up, then beat it like the rented mule it is...
67/68 K/20 "The BEAST" 68 K15 V6 LWB. 73 K20 GMC Burb "The Bomber" 74 K/5 74 K20 Custom Deluxe 86 K10 Shorty 92 K2500 Burb 95 K2500 GMC Life is what you make it Live each day like it was your last Old GM Trucks never go out of style |
03-26-2014, 10:53 PM | #235 |
6>8 Plugless........
Nice score on the 1st gen Dodge. Is the GV before the Tcase or after on that truck?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
03-26-2014, 11:38 PM | #236 | |
Vintage 4x4s
Thanks Ryan. I'm still looking for the parts for the other cummins at some point. This one has the overdrive after the np205, per Gearvendors install instructions. Does this np205 have the same output shaft as the one in my ochre truck? Trying to figure out how easy it would be to swap in the K20. Still surprised this truck had one with the 3.55 gears.
03-27-2014, 07:16 AM | #237 |
the 205 in the dodge is a 29 spline. it is specific to dodge manuals of that vintage. not a bad piece to have laying around. you can use it with any dodge manual(that i know of, the newest stuff i dont know the specs on) that came behind a diesel. so if you want to swap a cummins into an old chevy and use a 205 that is the case to have.
03-27-2014, 03:51 PM | #238 | |
03-27-2014, 09:20 PM | #239 |
wow, i totally missread that... haha
the rear output on the dodge and gm are the same... i think. i do think the dodge diesel varient had a different PN, but it was dimensionally the same as any gm fixed rear 205 with a plastic gear. the difference was in the machining process to make it a bit beefier. there is a difference in the rear outputs with metal speedo gear, but i dont know how it would affect the GV. the front output will be a bigger version. the dodge was 32 spl where gm was 30 spl. |
03-27-2014, 09:59 PM | #240 |
Vintage 4x4s
Thanks guys, I could have been more clear. I am thinking on just removing the gearvendors by itself and mounting in my ochre truck if it will bolt right up. Then drive the dodge w/o a gearvendors for a year or so until I'm ready to transplant the cummins, trans, and dodge tcase.
04-09-2014, 08:24 PM | #241 |
Vintage 4x4s
Time for an update, scrubbed the hood and it cleaned up really well. Also fixing up an old topper to go on. Needs different rear hatch glass that I had out back on another truck.
04-09-2014, 08:43 PM | #242 |
Looking 100 times better than when you started this.
Erik 1969 Chevy K20 6.0L/4L80E/NP205 1971 Chevy C30 Cheyenne Longhorn 454/TH400 1979 Chevy K30 dually currently in pieces |
04-09-2014, 09:32 PM | #243 |
Looking great.
More pics please .
Tom 71 K2500 71 K5 Jimmy |
04-09-2014, 10:00 PM | #244 |
nice
04-09-2014, 10:02 PM | #245 |
I agree! I hope you saved the locker hubs off that C10 too, there hard to come by..
04-10-2014, 08:58 AM | #246 |
Proprietor of Dale's Corner
I like it, it has come a long way
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
04-10-2014, 04:03 PM | #247 |
Very nice! It sure has came a long way!
04-15-2014, 12:57 AM | #248 |
Looking great!
04-18-2014, 10:03 PM | #249 |
Great build! Subscribed.
1971 K20 Suburban 2012 LS1500 4WD Suburban 2003 Honda Accord LX V6 (don't tell anyone) MY 'BUILD' THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=618915 |
04-19-2014, 12:41 AM | #250 |
Carpe manana
Nice work!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
