Old 04-17-2015, 02:30 PM   #226
naphtali5725
naphtali5725's Avatar
Re: Project Mr. Green Jeans (now 5.3 LS turbo build!)
Originally Posted by bnoon View Post
Well then why not a 472/500 caddy???
hehehe, cause I already had the 455, and all the rebuild parts, and i'm familiar with them
but that 472 sounds like fun!
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 04-18-2015, 09:19 AM   #227
bnoon
Well, the headers will need some work. Driver's side fits fine, but the passenger's side the EGR and number 6 tube hit the frame. Bogus.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 04-18-2015, 09:34 AM   #228
bnoon
Too bad I'm not ready for the turbo (not enough funds). The manifolds fit fine like this...
Old 04-18-2015, 05:12 PM   #229
jott_06
Camaro Club
jott_06's Avatar
why not mount the headers like that now and build your y pipe and turbo flange. then just run the exhaust down from the turbo flange. Then when you get a turbo the header work is done.
jott_06 is offline   Reply With Quote
Old 04-18-2015, 11:26 PM   #230
mattcrp1
mattcrp1's Avatar
That's not a bad idea. You could buy a core turbo for mock up for almost nothing and get it plumbed and make a "jumper" pipe till your ready. Then you could always send the core out to be built.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 04-20-2015, 08:33 AM   #231
bnoon
I've got the piping coming already, so that's most likely what will be done. I will trim off the EGR tubes and patch them up, then start with the routing.
Old 04-20-2015, 06:22 PM   #232
king-918
king-918's Avatar
Looks good
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 04-23-2015, 12:28 PM   #233
bnoon
I got the EGR tubes cut off and patched. I got my flanges and mandrel bends in stock now too.
Old 04-23-2015, 07:41 PM   #234
Hankster
Hankster's Avatar
Sweet! Man I'm so excited about this build!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 04-24-2015, 08:37 AM   #235
bnoon
I started piecing a few things together for the exhaust. If I were to try to do the hot pipes right now, I'm just not confident about placement without having the turbo in my hands, so a temporary conventional duals will be used until the turbo install starts later this year.
I had to clearance the passenger frame rail with a few small arcs. Driver's side was close, but no cuts.
Old 04-27-2015, 08:41 AM   #236
bnoon
Fuel pump bolted to the frame, grounded, power wire ran to the front. New gas lines bent, bolted to the frame, ran up the firewall. Starter installed. Rerunning many many wires...
Old 04-27-2015, 06:18 PM   #237
Hankster
Hankster's Avatar
It'll get there, just keep at it.
Current Build
Old 04-28-2015, 08:54 AM   #238
bnoon
Keeping at it. Wired the fuel pump up to the battery for a quick test to make sure fuel was getting to the front (success!). Fixed the broken vacuum port for the power brakes and T'ed over to the vent control ball for the HVAC control. Rewired the feed to the starter/alternator/ground and tested turning it over (success!). Next is connecting the fuel rails and throwing the ECU/harness into the engine bay and start connecting things.
Old 04-28-2015, 10:32 PM   #239
bnoon
ECU and harness about 80 percent installed.
Old 04-30-2015, 05:59 PM   #240
Hankster
Hankster's Avatar
Sweet man, so when do you think you will be driving this thing?
Current Build
Old 04-30-2015, 09:36 PM   #241
NewType72
NewType72's Avatar
Coming along real well
NewType72 is offline   Reply With Quote
Old 05-01-2015, 12:27 PM   #242
bnoon
In the next week or two in naturally aspirated form. With turbo about 2 to 3 months from now.
Custom throttle cable installed and temporary intake idea thrown in place. I'll shorten up one leg of the 90 degree bend and lengthen the other to move it away from the radiator to clear the fans.
Old 05-01-2015, 07:18 PM   #243
Hankster
Hankster's Avatar
Cool man! I bet you will be glad to be driving Mr.Green Jeans again..
Current Build
Old 05-02-2015, 09:26 PM   #244
bnoon
OK, so technically the engine would run right now, but I can't start it until I fill it up with fluids and put an oil filter on it. I need to form one more transmission line to the radiator... I still need to wire up the fans and mount them as well. I will need to rewire 2 injectors as I must have pulled on them too hard while doing the fuel lines and the wires came right out of the clips...
Fuel lines went in today and pressure tests good at key on position. Finished up the cooling system hose routing for the steam line return to the old radiator heater return spot. He's getting there!!! The next day or two I should have an initial test drive under my belt and be working out any bugs.
Old 05-03-2015, 10:30 AM   #245
Hankster
Hankster's Avatar
Hell yeah, your close now!
Current Build
Old 05-03-2015, 11:24 PM   #246
mattcrp1
mattcrp1's Avatar
Looking good, keep at it. I know how it feels to be so close to driving it. I just need gas and to get my drive way clear of side jobs, LOL.
IG mattcrp1
Old 05-04-2015, 08:29 AM   #247
bnoon
Well I went and bought all of the little things to finish it up in the morning, but we went to Furious 7 and then to a car show with the Bad Boyz Mustang Club of Iowa and then I had to mow which pretty much killed off the day. This week looks like rain with bad thunderstorms and possibly tornadoes this afternoon. Hope I get to finish it this week and it doesn't blow away!!!
Old 05-04-2015, 10:46 AM   #248
Justin@EntropyRad
Justin@EntropyRad's Avatar
coming along nicely
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 05-09-2015, 11:39 PM   #249
bnoon
First little "pop" of a test fire. Once exhaust and wiring is all tidy, I'll take it for a test drive.
https://youtu.be/tdRV9wJUk7M
Old 05-09-2015, 11:50 PM   #250
68Timber
I know the pieces fit
68Timber's Avatar
Clicked on the link but the video came up as private and wouldn't play? Tease!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
