Old 05-31-2016, 08:47 PM   #226
rip2174
Re: 83/84 swb stepside long time build
tested the panels. Just need to drill holes for the steering, brakes and and the AC hose bulkhead.
rip2174 is offline   Reply With Quote
Old 05-31-2016, 08:50 PM   #227
rip2174
couple small goodies came today. Both look like pretty good quality stuff. Going to the the Lokar shifting sensor and indicator later when I figure out where in the dash i'm mounting the indicator. (vert or hort)
Old 06-04-2016, 08:56 PM   #228
rip2174
got the firewall all welded up today. just need to do a little clean up.
Old 06-18-2016, 05:10 PM   #229
rip2174
Friend from working taking his burb to the Blueberry festival. Cool trailer.
Old 06-18-2016, 05:14 PM   #230
rip2174
Finally got all the welding done on cab floor and firewall. Really hate welding sheet metal. No patience for it. Ugly work, but its all getting covered up. Also got my buckets in and brackets welding in for mounting. Welding some angle to the tunnels for later to mount boards for the electronics in the console.
Size:  84.2 KBName:  IMG_1160.JPG
Size:  89.0 KBName:  IMG_1164.jpg
Old 06-18-2016, 05:16 PM   #231
rip2174
I should put some new floor pans in, But i feel Id really mess it up with my current welding skills. So for now going to clean it up real good and coat the floor with chassis saver. It will give me a reason to tear it apart in 5-10 years. LOL
Old 06-18-2016, 05:18 PM   #232
rip2174
So got the under side all cleaned up. Cheap oven cleaner and a pressure washer works awesome on the grease and grime under there. I know. ugly welding. But you will never see it unless I run you over.
Old 06-18-2016, 05:21 PM   #233
rip2174
Didnt read the directions on Chassis Save on dry time and second coat, just assumed an hour for second coat. Nope!! 3-6 hours. Will be tomorrow before 2nd coat.
Size:  63.1 KBName:  IMG_1170.jpg
Old 06-18-2016, 05:23 PM   #234
rip2174
Going to scuff this tomorrow and apply a 2nd coat. Let cure 2 days and scuff and cover with a Wurth product that is for undercarriages. Supposed to seal, slight sound deadening and be chip resist. Then cover that with a coat of satin black.
Old 06-20-2016, 09:41 AM   #235
rip2174
I managed to get back out in the garage the other night and apply a 2nd coat. Let it cure for a day then scuffed it and sprayed it with Name:  IMG_1174.JPG
Size:  109.0 KB Name:  IMG_1173.JPG
Old 06-24-2016, 06:37 AM   #236
rip2174
Underside done. Turned out pretty descent.
Old 06-24-2016, 06:41 AM   #237
rip2174
Started on cab floor. Going to sandblast the door jams. A little rust in there then primer. Ordering some lizard skin to spray everything below windows and the ceiling.
Old 06-24-2016, 06:15 PM   #238
tinydb84
tinydb84's Avatar
Looking good man. I love those firewall panels! I saw that burb on Instagram. Very cool!
David
Instagram: myfabguy
Old 06-26-2016, 09:05 PM   #239
rip2174
Thank you. Starting to make some head way.
That burb is a pretty cool ride.
Old 07-05-2016, 02:53 PM   #240
rip2174
I think I got all the frame stuff done. Got the sway bar, rack and pinion and motor back in and all bolted up. Everything seems to look pretty good. Hopefully no more big hiccups.
Size:  108.0 KBName:  IMG_1251.JPG
Old 07-06-2016, 07:40 PM   #241
Vega_67C10
Vega_67C10's Avatar
Great work, truck looks really good.
I Saw Elvis at 1000 Feet - John Force
Vega_67C10 is offline   Reply With Quote
Old 07-06-2016, 07:55 PM   #242
rip2174
Thank you
Old 07-06-2016, 07:59 PM   #243
rip2174
So Ive been thinking about installing a third brake light to help been seen. Been looking at LED flush mount lights when a bell went off in my head today. I was staring at a light and said that sure looks familiar. I bought a set of lights for the original truck like 16-17 years ago. I decided to look for them. I said theres now way that they are LED. Then i found two sets of tails lights and one third brake light. Holy cow they where LED and still in the original packaging.That saves my like 350 bucks. LOL
Old 07-06-2016, 08:05 PM   #244
rip2174
Installing light wont be too bad. But all the welding and body work to make that seam go away? That will be hard . Sure will look cool I think.
Old 07-08-2016, 11:27 PM   #245
Alex41
From experience...use a cut off wheel on your grinder and cut into the seam a few inches at a time to remove the factory seam sealer. You may cut through the two panels but by only doing a few inches, you can stop and weld it up before you separate the roof. This makes welding it back together much less messy. That sealer burns and splatters something horrible.
Alex41 is offline   Reply With Quote
Old 07-09-2016, 12:29 PM   #246
rip2174
Thank you for the advice.
Old 07-16-2016, 04:29 PM   #247
rip2174
I want to get this thing back together and drive it. So going to hold off on brake light and shaving the cab seam for now. Focus work on getting it together. So I sanded the ext of cab done and applied some epoxy primer. This way I can finish the firewall and then put cab on frame and work on ext bodywork later.
Size:  99.2 KBName:  IMG_1280.JPG
Old 07-16-2016, 04:33 PM   #248
rip2174
I learned the basic paint and body stuff from my dad when i was younger. Been awhile since I messed with any of this stuff. Bought this little cheap LVLP gun and have to say my little compressor does well with it and its a pretty easy gun to learn. Only 70 bucks and comes with 3 nozzles and needles.
Old 07-26-2016, 06:43 AM   #249
rip2174
slowly working on fire wall. I remember know that I hated filler work. It's going to take me longer than the normal person to get it smooth, but I'll get there.
Old 07-26-2016, 06:44 AM   #250
rip2174
New steering wheel from LMC. Really nice for the price.
