Old 08-11-2014, 10:56 AM   #226
Carbajal
Carbajal's Avatar
Re: Old Yeller's new heart-5.3/4l60 swap!
Looking really good!! Can't wait to start my swap
Carbajal is offline   Reply With Quote
Old 08-11-2014, 12:51 PM   #227
Low Elco
Thanks Carb! Jump on in, it ain't too bad.
Low Elco is offline   Reply With Quote
Old 08-11-2014, 12:55 PM   #228
Low Elco
Originally Posted by sduckworth13 View Post
Your a machine Chip. I have maybe half a roll of EZ grind wire left on the spool if you'd like it, I won't be using the welder anytime soon.
Thanks Scott, but I literally pass the weld store on the way home, just gonna pick up a 2# of -6 to get me by. Here's a coincidence, Flyin' Ryan just bought an old coupe to build and we got hold of a buddy of his that works for Airgas and he's gonna order us 2 spools, as of an hour before your post. Ha! Besides, I'd hate to take it off you, that stuff ain't cheap! Hope you can make it to the Nats with us. We'll meet you at Vic's, jump in with Boppa!
Old 08-11-2014, 01:05 PM   #229
sduckworth13
sduckworth13's Avatar
Cool. I'll be there at the truck nationals for sure. I appreciate the offer to let me ride with Boppa. If Katina doesn't go with me I'd be happy to ride with Boppa. I think she is hooked now though, she wants a suburban like Leon's ( Loc Doc ) now
Scott
sduckworth13 is offline   Reply With Quote
Old 08-11-2014, 01:33 PM   #230
Low Elco
Bring her and hop in Big Black! Glad to hear you're planning on coming.
Old 08-11-2014, 02:38 PM   #231
sduckworth13
Thanks Chip, I appreciate the offer. I'll run it by her and I'll get back with you.
Scott
Old 08-11-2014, 03:00 PM   #232
NastyBuzzard
NastyBuzzard's Avatar
And, the fuel tank.
Yes, it's ghetto
Attachment 1285474
This the the top of the tank and the pumpassembly from the 2500HD.
Attachment 1285476
But, it clears, it works, I got all the factory wiring. Now to finish the plumbing!
Attachment 1285477
Thanks for playin' along, guys!
How exactly did you do this? I am trying to put my donors 01 pump assembly into my 87's saddle bag tank. I am all for if it works, it works.
NastyBuzzard is offline   Reply With Quote
Old 08-11-2014, 03:36 PM   #233
Low Elco
If you have an 87 with a v8 and 3/8 fuel line, you're in luck! Just use all the 87 stuff and upgrade to the ep381 pump. No mods needed! You have to get the line(s) from the donor truck and compression fit them dudes together, but thats it.
Old 08-11-2014, 03:39 PM   #234
NastyBuzzard
You'd think so.. However I am making it more complicating for myself. I am using almost the entire 01 donors wiring harness b/c I am bringing over the instrument cluster, steering column and a few other things.
I need the pump assy to send correct signal to the 01 cluster, also need pressure sensor and all that jazz.
Old 08-11-2014, 03:39 PM   #235
Low Elco
Also, I cut the top mount ring out of the donor truck tank and then cut my existing tank, dollied the top flat and made a thick mount ring (had it done, but you can do it at home) for the inside of the tank, then made a sheet rubber gasket for the top of the tank and bolted that sucker together. Easy peasy. Be mindful of your vertical clearance, I had lots.
Old 08-11-2014, 03:40 PM   #236
Low Elco
You should be able to put the sensor on the side of the feed tube, good to go!
Old 08-11-2014, 03:43 PM   #237
NastyBuzzard
Nice!! Sounds like the route I will be taking!! Just need a giant hole saw!!
Pressure sensor in feed tube? Interesting.
I still need my sending unit to send correct signal to the 01 cluster (90-240 ohms I think) instead of what the 87 sending unit sends (0-120 I think..)
Old 08-11-2014, 04:27 PM   #238
Low Elco
Ach, I meant the gas gauge sensor. My '02 had no tank pressure sensor. I cut my approx 4" hole with a common jigsaw blade in a body saw.
Old 08-11-2014, 04:35 PM   #239
NastyBuzzard
Oh nice! I'll try going real slow with my jigsaw then.
Old 08-12-2014, 08:21 AM   #240
Low Elco
Note: I drained the tank, then filled it with water, then sawed it. Leaving it full of water was a great help in dollying it.
Old 08-12-2014, 08:28 AM   #241
Low Elco
Update: Finished the airbox mount and painted it. This truck has not had backup lights since we put the van column in, 15 years ago. So after a bit of tutelage from Eric, I pulled the column and put a new pair of holes in, so we should have a neutral safety switch. Yes, there's one in the PRNDL, but Eric said I have to have some kind of relays and have to find some kinda wire and OY, that sounds complicated. I just fixed it from the truck end. Hopefully gonna start makin' some tracks you can see!
Old 08-12-2014, 11:38 AM   #242
KSWes
KSWes's Avatar
Sounds like you're getting it licked. Can't wait to see the reveal.
70 Chevy C10 LWB
My Build:http://67-72chevytrucks.com/vboard/s...d.php?t=513002
KSWes is offline   Reply With Quote
Old 08-12-2014, 12:43 PM   #243
Low Elco
Ha, me too!
Old 08-13-2014, 08:23 AM   #244
Low Elco
Update! Got the column repainted, and the battery box and hood latch repainted last night, and got the fitting to hook up the oil pressure gauge. Tried to get the oil pressure sensor out, but couldn't get a socket on it and I was tired. Oh, called CAA and got all the missing parts on the way. I promise, I'll try to take more pics.
Old 08-13-2014, 11:17 AM   #245
mcbassin
Still Learning
mcbassin's Avatar
sounds like very good progress but....pictures
mcbassin is offline   Reply With Quote
Old 08-13-2014, 12:55 PM   #246
Low Elco
I know.... Boppa's coming out tonight, hopefully I'll pick up a camera. Bad Elco!
Old 08-14-2014, 09:22 AM   #247
Low Elco
Off night, didn't pick up a camera. Got a bunch of small misc. spray bombed, got the oil sending unit pulled, drilled, tapped, and reinstalled, and got the column loosely reinstalled. We shove it right up to the cluster, so we have to wait till it's back in to lock the column down. I think I'm gonna wade into tranny lines tonight. Pray for me.
Old 08-14-2014, 11:13 PM   #248
Bomp
Bomp's Avatar
Sounds like you're all over/in/and under Yeller.
Rock On Chip
Bomp is offline   Reply With Quote
Old 08-14-2014, 11:52 PM   #249
Xeen
Xeen's Avatar
I can't wait to see what solution you come up with because mine is patched together and I'm going to have to buy something and rework it more than likely.
I found this thread today it might help you out.
http://67-72chevytrucks.com/vboard/s...d.php?t=639295
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-15-2014, 08:29 AM   #250
Low Elco
Thanks for the link Brian! Those are some good 'lil fittings. I have 4 sets of trans lines as of last night, and I took a minute and found the 5.3/4l60 set. They are too long, but they snake me up to the front of the motor very nicely, in all the factory clips I had to go back and find. Also figured out a trans cooler solution, I hope. Just gotta go get a better flare tool tonight and some tubing stock. Hopefully this is the last thing motor wise that's gotta be fabbed and briggled with. Assembly and a bit o'wiring from here on in, then time for the A/C mess. No pics, you all know what a fat moron lying on the floor going "Now what the hell am I gonna do?" looks like. Hoping for a good night and big win this weekend.
