Old 11-26-2014, 06:30 PM   #226
reaper71
reaper71's Avatar
Re: "Project Orangepeel" 52 A.D
Thank you very much...I am thankful for the support from you and everyone else on this forum. their are a Ton of talented people on this site and alot of really cool builds..
Mark...
Originally Posted by ear.shop View Post
I think lots of people are following this. Not all of us post but I will say you have more talent,skill and imagination in your finger tip than I have in my whole body. Your explinations make it easy to read and follow. Keep up the great work!
reaper71 is offline   Reply With Quote
Old 11-27-2014, 04:19 AM   #227
52'5window
I am impressed. I am new here and am working with my dad on a 52 p/u. Your talent and imagination are incredible. I am also subscribed to this thread.
Keep up the good work.
Aaron
52'5window is offline   Reply With Quote
Old 11-27-2014, 09:56 AM   #228
47 Fasttoys
47 Fasttoys's Avatar
Very nice work Mark, kinda reminds me of a Batman theme. What are you thinking for the lower part, any type of gauges or chubby holes in there?
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 11-27-2014, 02:32 PM   #229
reaper71
reaper71's Avatar
Thank's Aaron!! This was A long time coming for this project for me ,years ago me and Dad were going to build one together but never happened for us,hope your's goes as planned...
Mark...
Aaron
Old 11-27-2014, 02:35 PM   #230
reaper71
reaper71's Avatar
Thank's Rob!! My original idea was a bit different but so far it has come out pretty kick ass! Gauges etc, are coming soon so keep checking in for progress..
Mark...
Rob
Old 11-27-2014, 02:44 PM   #231
reaper71
reaper71's Avatar
Pic #1 is a shot of the drivers side panel in place and the transition to the dash being started..
Pic #2 A closer look.. same as I did on passenger side using round bar and bending it to get the curve I wanted then go back and make my cut for the gap..
Old 11-27-2014, 02:51 PM   #232
reaper71
reaper71's Avatar
Pic #1 This is the drivers side upper portion of the dash...looking closely you can see part of the stock dash still hanging around (the black portion with orange cut line) this needs to go away to make room for the new transition so the dash and panel flow together..
Pic #2 shows the (after) look of the new piece weld,grind etc.
Old 11-27-2014, 02:56 PM   #233
reaper71
reaper71's Avatar
Pic #1 using poster board (my go to product for templates ) making the cap to finish off this area.
Pic #2 after I welded and metal finished the cap...
The upper section (garnish molding will be addressed later)
Old 11-27-2014, 02:59 PM   #234
reaper71
reaper71's Avatar
Last pic for today simply shows what the transition looks like and the gap between the two pieces...
Till next time..
Mark...
Old 11-28-2014, 10:35 AM   #235
reaper71
reaper71's Avatar
Here I'm showing the panel with all round bar on and finished.. This also shows the garnish molding and what needs to be addressed back of it has been done and flows, the front is next.
Old 11-28-2014, 10:40 AM   #236
reaper71
reaper71's Avatar
Pic #1 garnish molding removed.
Pic #2 after getting a rough shape using poster board I transferred this to metal and cut it out as seen here..
Old 11-28-2014, 10:46 AM   #237
reaper71
reaper71's Avatar
Pic #1 looking at the shape it needs to take.
Pic #2 poster board template to get it close..
Old 11-28-2014, 10:50 AM   #238
reaper71
reaper71's Avatar
Pic #1 after trimming etc. this is the end result..
Pic #2 starting to cap off the end..
Old 11-28-2014, 10:54 AM   #239
reaper71
reaper71's Avatar
Pic #1 showing backside of garnish, I put this plate on the back to give it strength..
Pic #2 shows the gap that needs to be capped off on the panel.
Old 11-28-2014, 10:57 AM   #240
reaper71
reaper71's Avatar
Pic #1 fitting the cap..
Pic #2 all finished off..
next up the back of cab...
Mark...
Old 11-28-2014, 11:26 AM   #241
RockinKees
RockinKees's Avatar
Man, you're GOOD!!
And it looks very nice too
Makes me think what I shall do in the future....
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 11-29-2014, 06:22 PM   #242
rusty76
rusty76's Avatar
Killer work man. I really like what you are doing. Gives all of us ideas.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 11-29-2014, 09:17 PM   #243
tiddlar
yea that interior is stunning,,, you should of seen my face when i saw it..............awesome awesome awesome
tiddlar is offline   Reply With Quote
Old 11-30-2014, 12:50 PM   #244
Advanced Design
Advanced Design's Avatar
Awe inspiring...thanks for continuing to share.
Advanced Design is offline   Reply With Quote
Old 12-01-2014, 10:29 AM   #245
reaper71
reaper71's Avatar
Thank's again Kees!!
Originally Posted by RockinKees View Post
Man, you're GOOD!!
Old 12-01-2014, 10:31 AM   #246
reaper71
reaper71's Avatar
Rusty76 Thank you! and Thank's for checking out the build..
Old 12-01-2014, 10:33 AM   #247
reaper71
reaper71's Avatar
Tiddlar! Thanks for your comments..very kind!
Mark...
Old 12-01-2014, 10:35 AM   #248
reaper71
reaper71's Avatar
A.D. Thank's again! will keep sharing as much as I can. Mark...
Old 12-01-2014, 10:41 AM   #249
reaper71
reaper71's Avatar
So finally on to the back of the cab!!
What I was wanting was a wrap around look for the interior..
Pic #1 showing a seamstress tape so I would be able to get a precise measurement for the steel needed for this next step. (on the green tape the marks are of where the door panel will line up)
Pic #2 shows a shot of the entire cab with tape..
Old 12-01-2014, 10:47 AM   #250
reaper71
reaper71's Avatar
Pic #1 showing the piece of steel used for the rear panel. Had a friend shear me a piece 4 3/4 and about 6" longer than I needed.
Pic #2 the bottle I used for bending the steel (happened to be the same radius as the inside of cab) so it made it easy to bend it and a good shape..
