#226 |
Re: Blake's 67 GMC stepside build
Pics #1 and #2. Just different views, it is fairly low profile and should not be overly noticeable.
Pic #3. View from inside cab with primer on it. Pic #4. Shot of dash with primer. Pic #5. This is what you would see from out side truck. NOTE: The dash will painted the same color as interior (light tan, as will the transponder) so should kinda blend in.. ![]() Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#227 |
![]() Join Date: Jul 2012
I like the transponder housing. Really nice detail.
#228 |
Thank's Doug!
#229 |
Onto the next project...
Pic #1. The drivers side stack pocket being filled in. Pic #2. Passenger side. Pic #3. After I did some wire wheeling I found a small amount of rot. Pic #4.The bed being stripped with aircraft stripper. (will be wire wheeled as well)
#230 |
Pic #1. The bed all stripped down and ready for repairs etc.
Pic #2. Stripping revealed this....The stack pocket was badly damaged at some point in it's early life as a farm truck, So they mudded over it. Pic #3. a second view.
#231 |
Pic #1. When I first thought how I was going to fix the pocket I figured I would just cut it out and make new pieces for it, but after I removed the piece I wanted to try and Hammer it out.
Pic #2. View from backside. Pic #3. Another shot. Pic #4. After the hammering was done and welded back in place. Pic #5 2nd view
#232 |
I missed a few things in my downtime, Mark.
It's looking great, and you have some nice ideas to certain things!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#233 |
Nice work. How much time to strip the box?
Ryan. |
#234 |
Thank's Kees!! Welcome back!!
#235 |
YJ....It took probably most of the day.
The paint was giving me fits coming off! I started with aircraft stripper and followed by the wire wheel. I then switched gears and used a paint stripping wheel for my electric grinder and it seemed to work the best. Mark...
#236 |
Pic #1. This was after some filing was done and a bit of metal finish. Small amount of poly filler and she will look as good as new.
Pic #2. 2nd view.
#237 |
Very nice work, and used the original metal. Very cool.
Ryan. |
#238 |
Hey Guy's! Been awhile with posting, was pretty busy working on fixing up a house and finally got it to where I could move in.
Anyway here is some pics... Pic #1. Passenger side end cap tacked in place. Pic #2. After metal work was done. Pic #3. Hard to see in this shot but the Drivers side was badly distorted. Pic #4. The template showing the distortion. Mark...
#239 |
Good to see you back Mark! Nice detail on the end cap.
#240 |
Hey Mark, I was just thinking of asking if there was any updates. Looks good.
Ryan. |
#241 |
Thank's Guy's!!!
Pic #1. This is after the metal work was done. Pic #2. This is the Drivers side front and would require some Hammer/Dolly. Pic #3. After repairs and metal finish. Pic #4. Passenger side is badly warped, so will need some TLC... Pic #5. After the repairs were done and metal finished. Mark...
#242 |
Looking as good as ever, Mark!
Don't stop now ![]()
#243 |
![]() Join Date: Apr 2011
..subscribing
#244 |
Thank's guys..
Pic #1. This was a simple idea for the tailgate latch, nothing fancy but works great. Pic #2. The other side. Pic #3. This is the Drivers side lower stake pocket. I wanted to seal it up but add some shape to it ,so this was the starting point. Pic #4. This was the passenger side in progress. Till next time.. Mark...
#245 | |
#246 |
Great idea on the stake pocket!!
You've got a great eye for details!
#247 |
Another nice detail. Looks good!
#248 |
Jim-Bob, have at it my friend...
Kees and A.D. Thanks again guys Pic #1. This is the drivers side rear of bed. If you notice a piece is missing so it will need some attention. Pic #2. After cutting etc. Pic #3. New piece made up and ready to be welded in. Pic #4. The extension being added to match the front. Mark...
#249 |
Good modifications. Mark, hanging out here in this section has me wanting a 67 to 72.
#250 |
Thank's Doug!
They are a super popular truck right now and so many different styles and ideas. Pic #1. 2nd view of the extension being made. Pic #2. The metal work all done. Pic #3. Passenger side. Pic #4. A shot of the bed sides all done with the extensions. Mark...
