Old 12-09-2016, 02:08 PM   #226
daddyjeep
daddyjeep's Avatar
Re: Daddyjeep Hauler - 85 K30 crew cab short bed
I finally got all my welds ground down and seam sealed all the welds on the floor and basically everywhere inside the cab. Hopefully this weekend i can get all the body work done on the rockers and corner.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 12-09-2016, 03:31 PM   #227
MTCK
MTCK's Avatar
Nice work. I can't recall are you going to paint the whole thing or just repaired sections?
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 12-09-2016, 03:58 PM   #228
daddyjeep
daddyjeep's Avatar
Um....I'm going to do both. Right now I need to get it together and functional. Things will get repaired and rattle canned. My fenders are nice on the outside, but some of the inner structure is bad. My doors are pretty bad on the bottoms as well. Before I paint it I want to get some better doors and fenders. Hopefully That won't take me too long, but with my lack of both time and money who knows. Once I have all good panels it will get a nice custom paint job. I am still kicking around ideas for that. Right now I am thinking a white and grey two tone with a bright orange separation line between the colors.
04 1500 crew cab
Old 12-09-2016, 04:09 PM   #229
daddyjeep
daddyjeep's Avatar
This is a quick photoshop of a random white truck I found.
[IMG][/IMG]
04 1500 crew cab
Old 01-01-2017, 05:14 PM   #230
made2drag
made2drag's Avatar
nice metal work! the flashlight pic was funny!
made2drag is offline   Reply With Quote
Old 01-03-2017, 01:49 PM   #231
daddyjeep
daddyjeep's Avatar
I finally finished my rendering showing all the custom things I want to build for the truck. I am building the bumpers, making some sort of custom grill, and making a custom hood. The rendering also will be my final paint scheme.
[IMG][/IMG]
I picked up another hood to start building my newer HD inspired hood for my favorite price...free. It had a little dent in the middle with some old bondo that was chipping off. I ended up cutting the bad section out anyway so that is not an issue.
[IMG][/IMG]
I took off all the paint to see how the hood was overall and aside from a couple small dings it is pretty good. It is hard to see, but I laid out some lines on where the different levels are going to end up.
[IMG][/IMG]
I am following the angle of the outer body line on the hood for all of the steps and will be raising the center 4" overall and the first step 2"...I think. I will mock things up to see how it looks before I make the side panels. I at least got the center piece cut out. I cut 10" out of the center of that to shorten it up front to back. This will create the opening for the ram air.
[IMG][/IMG]
[IMG][/IMG]
The center is sitting on a couple 2x4's in the pic. Again, I am not sure on the overall height yet.
Does anyone have any experience with ram air? I am wondering about driving in the rain. Is there typically anything done to prevent the water from getting to the air cleaner?
04 1500 crew cab
Old 01-03-2017, 04:23 PM   #232
MTCK
MTCK's Avatar
Love the rendering. I'm sure that hood will turn out awesome.
-Marcus
Project Plow Truck
Old 01-03-2017, 04:33 PM   #233
tinydb84
tinydb84's Avatar
Very cool hood idea. Cant wait to see what it turns out like.
David
Instagram: myfabguy
Old 01-03-2017, 07:44 PM   #234
COS399
COS399's Avatar
I like the direction you are headed with your project. I have no clue on your ram air question but I'm sure someone will chime in.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 01-03-2017, 08:35 PM   #235
87max
87max's Avatar
Great project, nice work.
87max is offline   Reply With Quote
Old 01-03-2017, 09:59 PM   #236
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I used to have a Cervinni's ram air hood on my 97 powerstroke. The very first bad rain I drove it in after I got all the ram air functional, nearly hydro locked the engine. I ended up drilling drain holes in the ducts I had built. That wasn't enough, I had to angle the "floor" of the ducts toward the drain holes and that helped. That still wasn't enough and I had to put some screen over the duct. I used some from a lund grill I took off a wrecked truck. All of that finally kept it happy.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-03-2017, 10:14 PM   #237
daddyjeep
daddyjeep's Avatar
Thanks Diesel, that is the info I was looking for. I have some thoughts with some baffles of some kind and a drain.
04 1500 crew cab
Old 01-04-2017, 04:21 PM   #238
daddyjeep
daddyjeep's Avatar
One more rendering showing a straight on front view. I wasn't real busy at work today so I threw this together.
[IMG][/IMG]
04 1500 crew cab
Old 01-05-2017, 11:04 AM   #239
Hewfil1
Hewfil1's Avatar
[IMG][/IMG]
New profile picture material?
Hewfil1 is offline   Reply With Quote
Old 01-05-2017, 12:26 PM   #240
daddyjeep
daddyjeep's Avatar
Done...good idea
04 1500 crew cab
Old 01-05-2017, 01:36 PM   #241
NastyBuzzard
NastyBuzzard's Avatar
I love the hood idea...
I really wish I could make one like this for my crew cab I am building.
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 01-05-2017, 01:48 PM   #242
daddyjeep
daddyjeep's Avatar
Go ahead then. I really don't know if I have the welding and body work skills to pull this off, but I'm going for it. This type of large flat panel welding will separate the men from the boys and we will see where I fall in that category.
04 1500 crew cab
Old 01-05-2017, 01:59 PM   #243
NastyBuzzard
I know my welding skills are no where near good enough. My friend has the skills though. However, it is quite a job to get him motivated to come weld anything. Maybe when I get closer to that point, we shall see.
Old 01-05-2017, 11:21 PM   #244
Hewfil1
Hewfil1's Avatar
Done...good idea
It's perfect!
Old 01-06-2017, 02:07 PM   #245
daddyjeep
daddyjeep's Avatar
I got a little more done on the hood. Still a long way to go.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
Old 01-08-2017, 08:06 PM   #246
Hewfil1
Hewfil1's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I love how it's looking so far!
Old 01-09-2017, 02:21 PM   #247
daddyjeep
daddyjeep's Avatar
I got some side panels started for the hood and finalized the height. This is going to take me some hours to get this thing right. I already have some low spots where I need to cut my welds and try again. This thin material is every bit as challenging as I expected.
[IMG][/IMG]
[IMG][/IMG]
The corners are going to be a bit of a challenge too, but I will worry about that later after I get the main structure of things done.
04 1500 crew cab
Old 01-10-2017, 04:07 PM   #248
daddyjeep
daddyjeep's Avatar
I'm going to post this here so I can reference it later. It appears to be a pretty good cheap sound deadener/insulation.
http://www.lobucrod.com/index.html
04 1500 crew cab
Old 01-11-2017, 02:33 PM   #249
daddyjeep
daddyjeep's Avatar
More welding and grinding last night. I got the second side panel trimmed and tacked in. I fixed one of the low spots in the first level only to develop two more as I was filling in tacks. The second level is much easier because I cut the sub structure out of the donor hood and tacked it to the bottom to support it. I may have to add some structure to the first level, of course I will have to do that from the hole in the hood now.
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
Old 01-11-2017, 02:47 PM   #250
moregrip
moregrip's Avatar
[IMG][/IMG]
[IMG][/IMG]
whoa!
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
