11-14-2021, 09:35 AM | #226 |
Post Whore
Re: My Dusty 71 GMCe Electruck
so then I went out and dropped $250 on the Lexus GS450h hybrid transmission wiring harness, and I'm glad I did as it comes with two connectors that are very complex to build, they connect something called the resolvers to the inverter
the resolvers are essentially sensors and there is one per motor, as as you recall there are two electric motors in this transmission often times when these harnesses are listed there are no pics of them at all or they are useless low resolution like this one Last edited by Gregski; 11-14-2021 at 09:55 AM. |
11-14-2021, 09:39 AM | #227 |
Post Whore
once I picked up the Lexus GS450h engine\transmission harness, the seller happened to be local (another reason why I got this one, knowing I may have overpaid was that I could pick it up for FREE and return/exchange it much easier if things did not work out for me)
it was time to thin it out, as you will see we do not use 90% of it, oh well the small harness was a sub harness for fuel injectors that was just zipped tied to it essentially Last edited by Gregski; 11-14-2021 at 09:55 AM. |
11-14-2021, 09:45 AM | #228 |
Post Whore
I tell you what doing LS Swaps has sure prepared me for this.
so let's saddle up this horse, shall we here we have those two resolver plugs, followed by the shift solenoid plug, and the last one closest to the tail shaft is the VSS Vehicle Speed Sensor The orange high voltage AC wires are capable of handling upwards of 600 volts there are two of them, each one goes to a separate electric motor inside of that Lexus GS450h transmission Last edited by Gregski; 11-14-2021 at 09:56 AM. |
11-14-2021, 09:52 AM | #229 |
Post Whore
and on the other side, aka the driver side we have only one plug this is the Safety Neutral Switch
we will need three signals from this one 1. Park 2. Reverse 3. Drive The orange high voltage AC wires are capable of handling upwards of 600 volts there are two of them, each one goes to a separate electric motor inside of that Lexus GS450h transmission |
11-15-2021, 04:03 AM | #230 |
Very cool build. Will follow along for this one.
11-15-2021, 10:15 AM | #231 |
Always enjoy reading your threads for the humor and the wizardry. Looking forward to seeing this in the truck!
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
11-15-2021, 10:35 AM | #232 |
Post Whore
11-16-2021, 09:39 AM | #233 |
Post Whore
thank you so much that made me laff, when can I swing by and shove one of these in your '68 GMC450h ?
11-16-2021, 09:44 AM | #234 |
Post Whore
the engine bay wiring harness was next as you can clearly see from this Lexus wiring diagram
11-16-2021, 09:47 AM | #235 |
Post Whore
and since apparently I don't like money, I paid $300...
11-16-2021, 09:50 AM | #236 |
Post Whore
for a $235 dollar harness
11-16-2021, 09:53 AM | #237 |
Post Whore
fortunately mine came with a handsome, organic, fully biodegradable [think 450 years] carrying case
11-16-2021, 10:02 AM | #238 |
It's going to be awhile before I go electric. I'm waiting for GM to start manufacturing crate setups that could drop in place of an LS.
11-16-2021, 10:03 AM | #239 |
Post Whore
so most guys buy this Lexus GS450h engine bay main wiring harness for this Inverter plug, part num...
11-16-2021, 10:04 AM | #240 |
Post Whore
30 minutes later...
11-16-2021, 10:05 AM | #241 |
Post Whore
... part number
11-16-2021, 10:07 AM | #242 |
Post Whore
second verse, same as the first...
11-16-2021, 10:10 AM | #243 |
Post Whore
here is the Lexus GS450h Engine Room Main Wire harness all laid out
Part number: 82111-30K62 fits 2008-2009 (this is the used one that I just bought) costs $7,144 new 82111-30K64 fits 2010 costs $6,341 new |
11-16-2021, 10:14 AM | #244 |
Post Whore
I did not know this prior to purchasing it, but learned later on that in addition to getting that Inverter plug we also get the two resolver plugs which will allow us to directly plug in our transmission harness into this Inverter harness, Bonus!
11-16-2021, 10:17 AM | #245 |
Post Whore
I actually enjoying wiring, especially unwrapping bulky harnesses and seeing where the wires actually run to
Note: second pic shows the unwrapped Inverter plug section, this is where most junk yards will cut off the pig tail for this connector, HUGE MISTAKE as you can see if you keep scrolling down because they lop off the two Resolver connectors which are only about 8" further down Last edited by Gregski; 11-16-2021 at 12:54 PM. |
11-16-2021, 10:19 AM | #246 |
Post Whore
and separating the strands into more logical branches instead of bundling them all together
11-16-2021, 10:20 AM | #247 |
Post Whore
... and 7 beers later, here's all we really need, so about $3 bucks worth of that $300 harness, ha ha
11-16-2021, 10:21 AM | #248 |
Post Whore
here it is all separated into different component runs for dramatic effect
11-16-2021, 10:27 AM | #249 |
Post Whore
so having acquired all of the components it was time to start building things, so although I bought a VCU kit it does not come fully built, you have to solder on the connector and a few gizmos like this voltage regulator yourself
and being a minimalist I only soldered on one of the two 20 pin connectors as that's all it takes to get the motors to spin, the other connector and the little red WiFi card are for temp sensors and gauges and such, we won't need them till later |
11-16-2021, 10:30 AM | #250 |
Post Whore
as I attempt to wire this truck up let's count together the few components we need in a 100% electric vehicle
1. VCU - Vehicle Control Unit (the brain, the controller)so I like to build up my electronics starting with the basics, and most need the ground and power leads first, this VCU Vehicle Control Unit aka PCM/ECU/ECM what ever you want to call it, aka "Brain" is no different glowing red LED = Success! Last edited by Gregski; 11-16-2021 at 10:53 AM. |
