Closed Thread
Old 09-04-2016, 04:40 PM   #2476
goatless
goatless's Avatar
Re: What did you do to your truck today part III
Reassembled and reinstalled my Rochester 2G. Went on test drive. Got home successfully on truck power.
1964 C10 LWB->SWB, 283->454, SM420->200-4R
MECHANIC: "ME"
goatless is offline
Old 09-04-2016, 09:40 PM   #2477
phraza
phraza's Avatar
Dropped the car off at my father-in-laws place. He lives about an hour north of Auckland.
Car isn't road legal, but borrowed my neighbors "dealer" plate which allows me to drive it place to place even though it's not road legal.
Was good to get it out on the freeway, drove pretty good!
Father in law is going to replace all the brake lines, brake pipes, all 4 drum brakes and master cylinder.
Also going to install the driveshaft loop, radiator shroud (getting a custom one made), and hopefully my electrical issues.
Will update once done! So close to getting on the road legally!
Fraser - New Zealand
1964 Chevy C10 Stepside
350 V8
Build thread here
phraza is offline
Old 09-05-2016, 12:37 PM   #2478
61K10
61K10's Avatar
sounds good, on your way to driving it. (please call it a truck though lol.)
1961 chevy K10
my build is------------61K10 build
61K10 is offline
Old 09-05-2016, 03:53 PM   #2479
phraza
phraza's Avatar
hahaha, woops
350 V8
Build thread here
phraza is offline
Old 09-10-2016, 01:10 PM   #2480
62 Barnfind
62 Barnfind's Avatar
Started reassembly.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 09-17-2016, 06:35 PM   #2481
jbgroby
jbgroby's Avatar
Got the Drivers side door glass installed and wrote a how to, which I will post later.
jbgroby is offline
Old 09-17-2016, 09:21 PM   #2482
LT1 Burb
LT1 Burb's Avatar
Bled brakes after installing motor and trans for second time!
LT1 Burb is offline
Old 09-17-2016, 11:18 PM   #2483
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Routed one of the fuel lines.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 09-17-2016, 11:37 PM   #2484
automoto
tried installing a new turn signal switch in my 65, but it did not fit because the mounting holes were off. im thinking its a gmc column but not sure so i will have to return/order a different switch. coming home after a drive tonight the left front tire blew out, luckily i was able to limp home
automoto is offline
Old 09-18-2016, 05:27 PM   #2485
Jimal
Jimal's Avatar
I finally figured out that it was this ill placed washer:
was the cause of the intermittent drivetrain shudder and noise I've been chasing down since I got the truck running two years or so ago. Solving that without pulling the transmission back out makes me a happy boy.
Jimal is offline
Old 09-18-2016, 05:32 PM   #2486
Backpayne
TJ, are those Langdon's cast iron headers you are using? Or are they Clifford?
Backpayne is offline
Old 09-18-2016, 05:33 PM   #2487
Backpayne
Nevermind, they look to be Clifford.
Old 09-19-2016, 12:36 AM   #2488
66Submarine
66Submarine's Avatar
Removed the 307 yesterday and today installed the 350 I put together for my car. Wanted to swap some stuff on the 307 and figured I'd drop this one in for fun/testing. 10.3:1 compression, Vortec heads, $100 Perf RPM copy intake, 214/224 white box cam. Basically a cheap clone of the 350HP GMPP circle track crate engine with another point of compression.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline
Old 09-19-2016, 10:10 AM   #2489
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
You got it.
Old 09-20-2016, 12:53 AM   #2490
66Submarine
Hey, it actually runs
Old 09-23-2016, 03:05 AM   #2491
nimrod
nimrod's Avatar
Replaced the bulbs in my autometer gauges with LEDs. What a difference!
Before:
Now:
nimrod is offline
Old 09-23-2016, 09:46 AM   #2492
verdell
verdell's Avatar
Before:
Now:
That really looks great! What size led bulbs did you use?
verdell is offline
Old 09-23-2016, 01:00 PM   #2493
nimrod
nimrod's Avatar
Thanks! I used these. Perfect fit!:
https://www.superbrightleds.com/more...rofit-car/206/
nimrod is offline
Old 09-23-2016, 03:42 PM   #2494
drmatera
drmatera's Avatar
I ordered this stuff for this truck.
1981 K10 (4.8 / 4L60E swap)
1982 C10 (5.3 / 4L80E swap)
1985 C20 Suburban (454 / 4L80E)
drmatera is offline
Old 09-25-2016, 09:45 AM   #2495
62 Barnfind
Mounted the bed and started to install the new wood!
John Z
62 Barnfind
Old 09-25-2016, 01:53 PM   #2496
goatless
goatless's Avatar
Test fit new fenders.
MECHANIC: "ME"
goatless is offline
Old 09-26-2016, 12:10 PM   #2497
drmatera
drmatera's Avatar
Finished pulling all the wiring, switches and misc stuff from the firewall and under the dash. Next stop the media blaster..
drmatera is offline
Old 09-28-2016, 01:19 AM   #2498
Vincenthdfan
Curious about the fenders:
What brand and how well did they fit for you??
Vincenthdfan is offline
Old 09-28-2016, 06:05 PM   #2499
goatless
goatless's Avatar
They are TriPlus, which I purchased through JC Whitney (they had 20% off and free shipping). I wanted to mount them this morning and take pictures, but time wasn't on my side.
I snapped a picture of the driver's side. One shows that the construction isn't very good, as you can see through to the ground in two spots. They both show that the blend from the front of the fender to grille support is off. I don't know if that's because of the fender or the grille/truck.
The truck ran into, or had been hit by, some horizontally fixed object just above the bumper on the passenger side, which smashed in the fender, grille support, and grille, and I attempted to pull the grille support back into place. It wouldn't be fair to judge the passenger side.
I'll know better once I bolt everything in place.
MECHANIC: "ME"
goatless is offline
Old 09-28-2016, 07:26 PM   #2500
jb9281
jb9281's Avatar
I had the tailgate letters and the area between the the chome on both sides of the truck handpainted in metallic silver today. I think it compliments my chevy tahoe grey interior seats.
jb9281 is offline
Closed Thread
