Closed Thread
Old 01-09-2017, 12:52 PM   #2576
forestb
forestb's Avatar
Re: What did you do to your truck today part III
Working on a set of custom tail light brackets for my step side. So that the wires will run inside them. It was raining so I could not finish installing the bed wood.
forestb is offline
Old 01-09-2017, 06:22 PM   #2577
lowslow64
lowslow64's Avatar
Added braided brake lines from INLINE TUBE last night.
lowslow64 is offline
Old 01-09-2017, 06:46 PM   #2578
shp4man
shp4man's Avatar
Drove around and fine tuned stuff, Found the clutch fork return spring missing and damn it, may have to replace the old Harrison radiator after all.
But all in all, not a bad ride!
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline
Old 01-09-2017, 07:01 PM   #2579
schpeen
schpeen's Avatar
this is coolio
1991 K5 Blazer 4x4 "9 ball"
2019 Chevy Silverado Trail Boss 4x4
2018 Chevy Colorado 2 door ZR2 4x4
1988 23' Mako Marine
2005 Harley Davidson Road King
schpeen is offline
Old 01-14-2017, 01:57 AM   #2580
rvrfoot
Got my custom tail gate today.Name:  20161205_112843.jpg
rvrfoot is offline
Old 01-14-2017, 10:09 AM   #2581
Blue666(2)
Smile Re: What did you do to your truck today part III
Originally Posted by rvrfoot View Post
Got my custom tail gate today.Attachment 1610576
Wow that looks good. Where did you get it?
Blue666(2) is offline
Old 01-14-2017, 11:56 AM   #2582
rvrfoot
mar k
rvrfoot is offline
Old 01-14-2017, 12:02 PM   #2583
rvrfoot
Getting all of my bed parts.Name:  20161022_161943.jpg
rvrfoot is offline
Old 01-15-2017, 04:04 PM   #2584
shp4man
shp4man's Avatar
I cleaned the old 6 banger to try and determine where all the oil leaks are. This exposed some casting numbers which after consulting the database on here, told me this isn't a 230 like I thought, it's in fact a 250 produced from 68 to 84. Holy crap, learn something new every day!
shp4man is offline
Old 01-15-2017, 04:08 PM   #2585
Backpayne
Last night I installed the front bumper after painting. My truck was black with gray scallops but I've given her a makeover. I may add red scallops.
Backpayne is offline
Old 01-15-2017, 04:26 PM   #2586
steveb64
Active Member
steveb64's Avatar
Reversed my rear bumper, will have to see if it grows on me. I do like the nice straight line on top now.
steveb64 is offline
Old 01-15-2017, 06:06 PM   #2587
idbeast
mar k
I was impressed by the fit and bolt hole locations on the bed from Mar K for my '56!
idbeast is offline
Old 01-15-2017, 06:30 PM   #2588
idbeast
Took my '56 out of the garage so I could see how the 1.5 inch drop springs and 2in drop spindles look, also decided to sweep the floor before I put back inside!
idbeast is offline
Old 01-15-2017, 08:01 PM   #2589
Backpayne
Well, I tried to install my rear back window but I, apparently, am an idiot. Couldn't get past the corners without tearing the seal, which I did. Going to have the local glass shop. They did a great job on my windshield.
Old 01-17-2017, 06:08 PM   #2590
Northwest Outlaw
Northwest Outlaw's Avatar
built new throttle linkage from the stock pedal mechanism to the Rochester Quadrajet. Ended up being really simple which was nice for my first engine swap
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline
Old 01-17-2017, 06:48 PM   #2591
forestb
forestb's Avatar
Make sure you are getting full throttle. I had the same set up and could not get full throttle out of it.
forestb is offline
Old 01-18-2017, 10:43 AM   #2592
aggie91
I'm just glad to be here!
aggie91's Avatar
I decided to add some color to the firewall while I'm doing my LS swap.
Before:
During:
After:
It needs one more coat to make it look even all the way across but I ran out of the paint that I was using, I pick up some more on the way home. Should be able to get another coat on in the 24 hour recoat window.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline
Old 01-20-2017, 10:57 PM   #2593
66Submarine
66Submarine's Avatar
Replaced the shocks...too soon?
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline
Old 01-20-2017, 11:31 PM   #2594
Blue666(2)
Too soon. You could have driven another 1/4 mile on those.
Old 01-26-2017, 11:15 PM   #2595
RKS0069
RKS0069's Avatar
Was finally able to push her out of the garage.
http://67-72chevytrucks.com/vboard/s...d.php?t=675881
1972 C-10 SWB
1962 3/4 ton LWB
2011 GMC Sierra LML Z71 crewcab shortbed
RKS0069 is offline
Old 02-04-2017, 10:32 PM   #2596
forestb
forestb's Avatar
Built a pvc structure to keep my bed from becoming a bath tub
forestb is offline
Old 02-04-2017, 10:34 PM   #2597
forestb
forestb's Avatar
Structure
forestb is offline
Old 02-04-2017, 10:35 PM   #2598
forestb
forestb's Avatar
Bath tub
forestb is offline
Old 02-05-2017, 12:23 AM   #2599
Blue666(2)
Just finished a center mount hand brake lever on my A833
Old 02-05-2017, 12:25 AM   #2600
Blue666(2)
Another look
Closed Thread
