Old 01-13-2016, 09:15 PM   #2576
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
old and new window crank side by side, or top and bottom
Gregski is offline   Reply With Quote
Old 01-13-2016, 09:16 PM   #2577
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
close ups of the old stock original OEM door crank handle thingie
Old 01-13-2016, 09:19 PM   #2578
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and the new handle complements of TAIWAN
Old 01-13-2016, 09:23 PM   #2579
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Greg this is nauseating is there a point here somewhere?
~ Patience must we have ~ OBD-One Kenobi
so lets take a look at both of these cranks under our EyeCroScope
notice the meatier wall around the hole opening on the old crank, that is good for strengthtability but no so good for insertability, but notice the larger hole opening on the new crank that slides right on the new regulator, but I doubt it will last as long
in the second pic I try to show that the rataining clip goes on closer to the edge on the new handle (left) than on the old one (right)
Old 01-13-2016, 09:25 PM   #2580
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
WHATEVER MAN ~ did you get the new window handle on the new regulator or not?
Old 01-13-2016, 09:26 PM   #2581
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I sure did, slid/snapped right on! and it's as close of a match as can be
Old 01-14-2016, 09:50 PM   #2582
rusty76
rusty76's Avatar
Re: Restoring Rusty
Glad you got a handle on it. Lol
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-14-2016, 09:57 PM   #2583
daddyjeep
daddyjeep's Avatar
Re: Restoring Rusty
You and yourself sure do argue a lot. I think you two (one) need relationship counseling or something.
daddyjeep is offline   Reply With Quote
Old 01-16-2016, 04:37 PM   #2584
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Restoring Rusty
I love your writing style. It reflects the way a lot of us actually go about our thought process! And now, how do the windows roll up and down?! Lol
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 01-17-2016, 12:36 PM   #2585
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Thank you, I try to be entertaining and still send a message across or make some point. I hate dry monotone Videos or Posts / Lessons.
One thing I don't do is lie or BS, so get this, the darn window rolls up the same way, maybe a little easier, but definitely won't pass the Pinky Test. I am thinking all the new window molding I shoved in there a few months ago needs to get acqueinted proper first, that or the tracks are bent or misaligned, maybe I will look at both sides again some day, maybe when I rehang the doors. Any tips/advice?
Old 01-17-2016, 12:39 PM   #2586
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
LOL, I agree, but the other me doesn't wanna go!
Old 01-17-2016, 07:37 PM   #2587
hawkeyegold
Re: Restoring Rusty
Did a bunch of cleaning and salvaging on some 68 cougar interior pieces.. (I know not a Chevy.. but have a 79 K10 I'm working on as well) Normally probably would have just had it recovered.. but you inspired me to make the old new again!
1979 Scottsdale
hawkeyegold is offline   Reply With Quote
Old 01-17-2016, 10:19 PM   #2588
y5mgisi
y5mgisi's Avatar
Re: Restoring Rusty
On your window track seals, did you trim them around all the areas where the door support structure interferes with the strip?
Old 01-17-2016, 11:18 PM   #2589
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Talk to me Goose! I did not trim anything, so the short answer is no, but honestly I don't know which areas you are referring to, could you show a pic maybe.
Old 01-18-2016, 06:13 PM   #2590
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
LETS DANCE
Note: I am using Bakerfields finest 805 lubricant, but any bottled goodness should work you may want to avoid the Lite viscosity
Old 01-18-2016, 06:14 PM   #2591
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
here are some before and after close ups, after the 60 grit treatment (wanted 80 but 60 is all Harbor Freight had to offer)
Old 01-18-2016, 06:17 PM   #2592
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
remember the only people we is trying to impress is ourselves
Old 01-18-2016, 06:18 PM   #2593
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
well yes like a dummy The Greg piles this JB Weld on too thick, but hey first time for everything
Old 01-18-2016, 06:20 PM   #2594
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
we might could take another shot at these with more sand paper once its primered
Old 01-18-2016, 06:22 PM   #2595
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Dash Board
time to wipe... in a mad Dash to get it done before the sun goes down
Old 01-18-2016, 06:23 PM   #2596
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
in the spirit of Run what you Brong' we primered the belly with some left over primer over rust stuff, until we ran out of product
Old 01-18-2016, 06:24 PM   #2597
flashed
Re: Restoring Rusty
Looking good .
flashed is offline   Reply With Quote
Old 01-18-2016, 06:25 PM   #2598
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
the top got covered in some left over high temp engine primer, totally unnecessary but again that's what we had on hand, and I wasn't going to fork out any more $$$ (pronounced Duckets) on this "cheap" da$h board repair
Old 01-18-2016, 06:28 PM   #2599
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
some touch ups required, but remember it aint got to be perfect I don't recon cause its going to get covered in textured paint which I hope will mask / hide some imperfections
Textured Paint Makes Me The Body Man I Ain't!
Old 01-18-2016, 06:29 PM   #2600
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by flashed View Post
Looking good .
Dzienkuje Bardzo!
