Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-12-2015, 03:32 PM   #2601
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Kitchen just about done
Cabinets-check
Floor-check
refrig.-check
Microwave exhaust-check
cooktop oven-check
Sink garbage disposal faucets drain
Dishwasher
Granite countertop Saturday install
Almost outta kitchen prison. My only request was a new backdoor
WIN_20150904_103842 by [url=https://www.flickr.com/photos/97391199@N06/]
1985 ONLY
Air temp. Sensor getting wired w/ map sensor
WIN_20151112_102335 by [url=https://www.flickr.com/photos/97391199@N06/]
WIN_20151112_104755 by [url=https://www.flickr.com/photos/97391199@N06/]
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-13-2015, 10:37 AM   #2602
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
Originally Posted by Big J View Post
The camaro is awesome, eta on the completion of the blazer?
Yeah what he said...
Kinda thought we had a date for Rausch Creek coming up -
Persistent you certainly are my friend!
vtblazer is offline   Reply With Quote
Old 11-13-2015, 06:14 PM   #2603
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
VTBlazer with a yota, what has this world come to have to take a rain check, my calendar is booked solid, maybe spring
I'll give you a call to see how life is treating you, thanks for looking
Working on your induction system
SAFETY FIRST
AS usual, off topic
Jim
Old 11-17-2015, 10:03 AM   #2604
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
The engineers at GM, in their infinite wisdom, decided to put one bolt diagonally inside. Sure makes it easy to install runners. I'm thinking 15-20 Ft/ lb. to install
WIN_20151117_085722 by [url=https://www.flickr.com/photos/97391199@N06/]
SAFETY FIRST
AS usual, off topic
Jim
Old 01-14-2016, 11:55 AM   #2605
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Sorry for the delay, but kitchen is almost done, and wanted to start ordering parts for my hydro boost system. First step is to determine which M/C you have, mine is considered deep early, as per pic on top of plenum
Disc/drum
WIN_20160114_085905 by [url=https://www.flickr.com/photos/131936700@N05/]
SAFETY FIRST
AS usual, off topic
Jim
Old 01-15-2016, 02:24 AM   #2606
Captainfab
60-66 Nut
Re: PO has me PO'd
Let me know if you need a booster bracket and hydroboost mounting plate.
Old 01-15-2016, 08:25 AM   #2607
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
You were my first thought captain, but the one from Hydratech comes with an aluminum bracket included. Sorry I couldn't buy one from you
SAFETY FIRST
AS usual, off topic
Jim
Old 01-16-2016, 12:44 AM   #2608
Captainfab
60-66 Nut
Re: PO has me PO'd
Understood. I did not realize that you had already bought a unit from Hydratech.
My brackets are mainly intended for those that purchase either good used components or simply go to their local auto parts store and pickup new or rebuilt components.
Old 01-16-2016, 08:02 PM   #2609
skorpioskorpio
Re: PO has me PO'd
Jim, are you going to run drums in the rear? I guess I'm just trying to figure out why you care about the original master cylinder. My Hydrotech came with a repro Corvette master from CPP on it.
Also if you are running a Saginaw type power steering pump and original style power steering you should be OK, but if you are running the newer style pumps and rack and pinion it gets a little more complicated. Rack and pinion needs lower pressure levels than the hydroboost needs to be effective, so if you make the hydroboost happy, you over pressurize the rack. I had my pump rebuilt (newer LS, Corvette type pump) by Lees to put out hydroboost flow rates, and am planning on using the Heidt's power steering valve to balance out the pressures so both are happy.
skorpioskorpio is offline   Reply With Quote
Old 01-17-2016, 12:09 PM   #2610
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Scorpio, thanks for the advice. I wish I could run a rack and pinion, but have yet to see anything for 4wd, so that will not be a problem. I have a new master so to save a hundred bucks, I will use my new m/c, and yes I have drums on the back
Captain, guess my pockets are to deep at the moment, and thought it less of a hassle to buy from a company that has experience with hydro boost. We'll see if it was the right choice.....
Thanks guys for following along, and keeping me on the right path, always enjoy hearing peoples thoughts
SAFETY FIRST
AS usual, off topic
Jim
Old 01-18-2016, 10:56 AM   #2611
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Forgot to mention I want to use my prebent stainless steel brake lines for master cylinder, prop valve, unless they give me sealing problems
We'll see how the system bolts up, but have to wait 4 week lead time
Anything new on your build?
SAFETY FIRST
AS usual, off topic
Jim
Old 01-18-2016, 06:27 PM   #2612
skorpioskorpio
Re: PO has me PO'd
Chassis still in Arizona, but because of the *long* delay, Nathan over at Porterbuilt has agreed to do the engine mounts and all, so that's good.
Had renders done, I posted a lot of them in my build thread, a member did them for me and was really happy with his work, he really worked with me and did a good job of representing my kooky ideas. His handle on here is Hellaflush3d, and just so you know, because of my render he has already done a halftop Jimmy/Blazer.
Old 01-18-2016, 07:20 PM   #2613
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Re: PO has me PO'd
Attachment 1488633[/QUOTE]
Hey Jaro - I was looking into the hydratech Hydro Bosst system to use on mine as well. I picked up a rebuilt an original saginaw style style power steering pump from the local auto part store and installed a new AGR direct replacement gear box. Do you think I'd be ok without the Heidt's power steering valve? Also, a friend of mine was telling me they make a lot of noise.. Do you know of any truth to this?
Thanks,
Mike
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 01-18-2016, 11:04 PM   #2614
skorpioskorpio
Re: PO has me PO'd
you're actually quoting me not Jim, but you should be fine with the Saginaw type pumps, particularly if you are running a reticulating ball steering. The problem is really about using the ubiquitous Mustang type rack and pinion which doesn't require (or tolerate) the pressure levels that the hydroboost requires. Even the newer type mini pump can keep a hydroboost happy. The only time you need to really think about the Heidt's pressure control valve is when you are trying to run a low pressure rack with a high pressure hydroboost.
I haven't run mine yet, and while I do understand the hydroboost does make noise they were also used in various Cadillac models so I can't see where it would be some crazy noise level, the caddy crowd would never tolerate such a thing. Even if you search for "hydroboost noise" on youtube what comes up is what sounds like power steering pump noise and happens when the driver hits the brakes *OR* steers.
Old 01-19-2016, 09:57 AM   #2615
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Yeah, saw his work, and they look great. Do you send a pic of your idea, and he does it in ink. What if you don't like his rendering, do you still have to buy it?
Thanks for addressing Mike's concerns, I had no idea how to reply
SAFETY FIRST
AS usual, off topic
Jim
Old 01-19-2016, 07:10 PM   #2616
skorpioskorpio
Re: PO has me PO'd
No ink, it's all CAD, computer renders. So he can pretty much keep tweaking it until you get what you want. Mine was, needless to say, complicated, just about every body part tweaked. But it's good to give you an idea of stance and color. He doesn't have an interior done though, like for mine he did the seat backs and so there aren't any topless renders above the horizon.
Anyway, not trying to sell you on it, just figured you have some of the same issues as me in that your project has a lot of unique features that you represent in your thread but get lost in context because your thread is long in length and time, like mine, and some times you have to go digging through your own thread just to remember where you're going with things.
For me these 2 renders alone were worth what I paid him.
Name:  Ken Final 13.jpg
Name:  Ken Final 20.jpg
The first let me see the truck from all flat angles and the second kind of made me feel like, I don't know, like there is an actual plan to work from, like I'm building something that's there, somewhere, and not just in my head.
Old 01-19-2016, 07:48 PM   #2617
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Wow, that is amazingly lifelike... thanks for taking the time. I've really never had a vision of what this truck will look like, when and if I ever get it done. But I keep throwing money at it to keep me motivated.
It was nice to have one of my sons to stop by over Christmas to hang the intake. That is a massive amount of weight that I'm not sure I could have put on.
Did you buy that 3D printer?
I've toyed with the idea of having twin tank fills on mine, since my tank is new now is the time
SAFETY FIRST
AS usual, off topic
Jim
Old 01-19-2016, 10:14 PM   #2618
72K5CSTDarkOlive
Re: PO has me PO'd
sorry about the confusing. I sit in front of a computer screen all day so my eyes become blurred at times. Appreciate the info about the Hydroboost.
Old 01-20-2016, 01:30 AM   #2619
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
No problem, just glad you find something interesting to read on my thread, you've got a great build going, always enjoy getting up to date there
SAFETY FIRST
AS usual, off topic
Jim
Old 01-20-2016, 10:28 PM   #2620
skorpioskorpio
Re: PO has me PO'd
My finances are less than liquid right now, so no, I didn't get the printer yet, although frankly the longer I wait the better and cheaper they get, so there is that.
Old 02-09-2016, 09:41 PM   #2621
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
7-9-11in/pds torque
2 stepsback 1 step forward
Seems the intake bolts fall under the runners of the vortec/ tpi,in some instances, so pulled the wheel well so I could stand in the engine bay and work
Seemed like it was a good time to pull booster as well, since the parts should be in in a couple weeks, also yanked cruise control and coil packs
Seems spell check doesn't like the word vortex, ok fixed it, or not
WIN_20160209_161001 by [url=https://www.flickr.com/photos/131936700@N05/]
SAFETY FIRST
AS usual, off topic
Jim
Old 02-10-2016, 09:16 PM   #2622
Sacramento70
Blazer Fanatic
Sacramento70's Avatar
Re: PO has me PO'd
"Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST"....Why? I thought thats why we came here...to learn and share our experiences and build off of each other ???? Not being rude i'm just curious if is was a joke or real?
1970 Chevy blazer
Sacramento70 is offline   Reply With Quote
Old 02-10-2016, 09:19 PM   #2623
Sacramento70
Blazer Fanatic
Re: PO has me PO'd
BTW..blazer is coming along VERY nicely, and let me tell you that you do some incredible work
1970 Chevy blazer
Old 02-10-2016, 11:47 PM   #2624
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
First off thanks for looking, I just wanted to stress the importance of safety and understanding ones abilities. I don't think all people are created equal in their ability to restore trucks and cars
I've had several incidents over the years, where I wouldn't want someone to get hurt, because they weren't pay attention. A lot can and will go wrong, when you use the degree of tools used in restoration
I hope I didn't put you off, but, yes it is as real AS LIFE. I do want people to look and learn, I just don't want anyone TO GET HURT
SAFETY FIRST
AS usual, off topic
Jim
Old 02-10-2016, 11:51 PM   #2625
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
SUCCESS, last intake bolt in, now I have to gasket the runners. New found respect, for this old truck, much more room to work, since I pulled the inner fenders
WIN_20160210_133653 by [url=https://www.flickr.com/photos/131936700@N05/]
SAFETY FIRST
AS usual, off topic
Jim
