Old 06-01-2018, 09:25 PM   #2676
thelonerife
thelonerife's Avatar
Re: Chucks SWB Fleetside
Well I got the radiator today. I wasn't too pleased with the packaging but I think it will be alright. There was some styrofoam broken and the box was taped up even though there were staples in it. The staples weren't holding it shut at all so someone taped it. Kinda looks like its a returned item so they just shipped it out again. Some of the fins have been touched also. We'll see.
thelonerife is offline   Reply With Quote
Old 06-03-2018, 02:01 PM   #2677
nds1968
nds1968's Avatar
Yeah I'd call and asked for a discount but that's me...
Do you plan on painting it? I was planning on painting an aluminum radiator for my truck but I kinda like the way this one looks.
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 06-08-2018, 10:11 PM   #2678
thelonerife
side by side comp
Old 06-08-2018, 10:20 PM   #2679
thelonerife
I think when they (cold case) says direct replacement, they mean a 3 core radiator. My 4 core brackets are kinda big for their radiator. but I can live with it if it works. And I had a helper.
Old 06-08-2018, 10:49 PM   #2680
thelonerife
Yes. I painted the front of it. I didn't want to see and silver/aluminum from the front of the truck even though it would be just the sides showing on either side of the A/C stuff. I know what you mean by asking for a discount but I figured I would see if it works okay first. I'm not being picky on it because it has a lifetime warranty so I feel thats a good thing if I were to have a real problem they'd take care of it.
Old 06-22-2018, 12:19 AM   #2681
thelonerife
So I got the new radiator in and filled with coolant. I ran the motor with the a/c on and it cooled well. I didn't road test it as it was raining and Choncho don't like no rain. It's more that I don't like to clean it after the rain.lol But I'll do that soon enough.
Old 06-22-2018, 12:36 AM   #2682
thelonerife
Oh did I mention I love my truck Well I do...lol
Old 07-17-2018, 12:39 AM   #2683
thelonerife
I have bought some 8'' wheels and tires and thought I would try and see if they felt different than the 20's. I think I need to have my driveshaft balanced as I have a lot of bouncing action going on. Same as with the 20's..
Old 07-18-2018, 06:02 PM   #2684
knomadd
knomadd's Avatar
Hey Chuck, you haven't asked for opinions or help, but I figured I'd toss this out there in case you hadn't thought of it. Ignore this if you don't think it applies.
I don't know the symptoms, so I can't really tell what's going on, but if it feels like it could be the wheels and tires (the reason you went with a smaller wheel than the 20s), you might look at your shocks, ball joints, wheel bearings, control arm bushings, etc. Basically check out the soft and wear parts of your suspension. They can amplify any minor vibrations from small road imperfections, which make a low profile tire ride like garbage. Sometimes just adding grease to the greasable parts like ball joints will improve the ride a bit.
Definitely check out your drive shaft if you feel like it needs some attention.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 07-19-2018, 01:32 AM   #2685
thelonerife
Thanks Duane, I know I have flat spots on my 20's so I wanted to try some other wheels/tires to see how it felt. The front got better so I attribute the front shakes to the flat spotted tires. The rear got a little better but not a lot. I moves up and down and a little up to the right shake like something is out of balance. If that makes any sense. And I still think my driveshaft needs to be shortened about an inch. Its all the way in there almost.
Old 07-24-2018, 01:27 PM   #2686
thelonerife
Trying some safari van caps. I think I like them.
Old 07-24-2018, 08:33 PM   #2687
cornerstone
cornerstone's Avatar
Looks fantastic man. How about some black enamel on that bright wheel weight?
cornerstone is offline   Reply With Quote
Old 07-25-2018, 01:20 PM   #2688
knomadd
knomadd's Avatar
Or some trim rings to add a bit more pop and cover them pesky weights.
-Duane
Old 07-26-2018, 05:02 PM   #2689
thelonerife
Yeah I have to do something about those. There are some spots that need touching up so I may just do a light sand and spray on them.
Old 07-26-2018, 05:04 PM   #2690
thelonerife
If I do I'll get some off of an Astro van. I had those on some rallies before and I like them. They're not real deep.
Old 07-26-2018, 05:14 PM   #2691
thelonerife
I got my new driveshaft in. The old one had tubes that were bent a little and I just had Dave do the whole thing new. The only parts that were savable were my yoke and carrier bearing. I had him go ahead and put new u joints in too although mine didn't have many miles on them. He uses Spicer brand. Mine were Taiwan I think. He also shortened the new one for me too. The vibration is a lot better now.
But as you know, whenever you get something fixed something else will pop up. Or off. While I was shutting my drivers door to go test drive it my sport mirror head popped out of the mirror arm and hit the ground and broke. Tiawan strikes again. Old truck, new problems.. I think I'll try to find a NOS one this time.
Old 07-29-2018, 08:53 PM   #2692
thelonerife
I've got a NOS mirror replacement coming from Down South Truckin (Mike)
Old 08-16-2018, 02:14 AM   #2693
thelonerife
I got the NOS mirror on and the door panel all back together. I know you've never seen a mirror before so here ya go . lol
Old 09-28-2018, 05:05 PM   #2694
MDPotter
MDPotter's Avatar
Awesome truck Chuck, you did a great job. I bought a 68 GMC LWB fleetside a couple weeks ago and it's mostly original and it's the same blue. I've scrolled through all 108 pages of your build - I'm just finishing up a 64 Chevy C10 with my dad so I remember all the stages and the struggles and wins with these projects.
I don't have the time or money to do a restomod, so I'll probably just repair the rust, give it a decent paint job, and make a few upgrades over time and drive it for awhile since it's only got 34,000 miles on it and runs great. Besides, I don't know if I can take not being able to drive it for years!
P.S. - my uncle restores and customizes VW's (mostly pre-1967) here in Grand Junction. I've seen a lot of VW's come out of his shop with the same wheels you have on your bug.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 10-04-2018, 07:37 AM   #2695
mcbassin
Still Learning
mcbassin's Avatar
Nice wheels Chuck! How do you like the new radiator? Looks like a very nice piece.
mcbassin is offline   Reply With Quote
Old 02-12-2019, 06:07 PM   #2696
thelonerife
Sorry its been a while since I've been on here. Thanks! Yeah the wheels on my bug are Empi's.
Old 02-12-2019, 06:09 PM   #2697
thelonerife
Thanks Mike. The new radiator works great! One of the best things on the truck. Its expensive but the lifetime warranty is good tho.
Old 02-24-2019, 09:02 PM   #2698
nds1968
nds1968's Avatar
Looking good as always. Here is a thread of mine http://67-72chevytrucks.com/vboard/s...d.php?t=301160 I have these trim rings I may run. I still can't decide on wheel color. They are currently white but thinking about black or the interior blue color which is a darker poly blue than the exterior baby blue.
Nate
Old 04-09-2019, 08:25 PM   #2699
thelonerife
Thanks. I like the black ones.
Old 04-19-2019, 10:18 AM   #2700
Chuck Pryce
Here is another Chuck that loves your truck.
Chuck Pryce is offline   Reply With Quote
