02-07-2016, 06:35 PM | #1 |
Re: What did you do to your truck today? Chapter II
I finally installed my front fender that I bought two years ago.Gotta love vintage rust free GM sheet metal!
02-07-2016, 10:06 PM | #2 |
Degreaser and pressure washed bed frame rails, splash pans and inner fenders prior to stripping and painting. Also cleaned up the back half of the frame for the same. Will probably paint the inner fenders body color and POR 15 and top coat everything else. Also scored a nice, clean stock diff cover to replace the rusty chrome one currently installed.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
02-08-2016, 05:33 PM | #3 |
Just hung the driver door back in place after replacing the bottom and also the top hinge along with the bottom bushings and pin... and then pulled the passenger side and replaced the upper hinge and put new bushings and pin in the lower hinge and re-hung it. They will both be coming back off a few more times, but those new hinges and the new pin kits sure make em nice and stiff again... just like new.
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
02-08-2016, 05:47 PM | #4 |
More buffing/waxing. Removed clear glass, cleaned 45 years of crud off the rubber gasket and reinstalled w/factory "Soft Ray" glass. That Hugger Orange is sooooo pretty and just pops!! Wow.
02-08-2016, 08:28 PM | #5 |
Installed the B&M shifter cable and my Lokar LED shift indicator cable and sender..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
02-08-2016, 08:32 PM | #6 |
I had to put a couple of spacers at the trans cover mount bolts to get the mount away from the lip of the cover... how was yours at that spot? I see you have an aluminum cover that offers a better flat surface..
02-08-2016, 09:26 PM | #7 |
The Lokar cable mount fit ok because it ended up under the B&M cable mount. The LED sending unit did not fit at all on the trans pan, so i just mounted it on the trans crossmember. I only used about 17 inches of cable from 5' that they send with the kit..
02-14-2016, 12:25 AM | #8 |
Put some new tires on her finally. Long over due.
Also installed a bluetooth stereo. Next on the list is brakes. |
02-17-2016, 07:41 PM | #9 |
added another quart of oil
02-18-2016, 12:42 AM | #10 |
02-18-2016, 12:47 AM | #11 |
Today I touched up some paint on a few parts waiting to be installed
02-18-2016, 12:50 AM | #12 |
Also got my new lifters and pushrods installed with the new PRW rocker arms
02-18-2016, 01:55 AM | #13 |
70+ ( Old Skool Club )
Went to the garage where I have my Highlander stored for the Winter and stood looking at the exterior for 5 minutes. I then opened the door and looked at the interior for another 3 or 4 minutes. Can't wait for Spring...
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-17-2016, 11:27 PM | #14 |
I went from stock to not..should I go back?
02-18-2016, 12:31 AM | #15 |
Yes, but you already knew that.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-21-2016, 11:55 PM | #16 |
02-18-2016, 12:24 AM | #17 |
Just removing parts. I've come to the realization I can remove a TON of parts and still maintain start and stop. SSTIM suggestion and it finally clicked. Next up is the hood, for which I'll build a bench on wheels (need the room), then the grille, outer cowl, windows (gee can't wait). My mechanical experience is limited, and of course this is my first tear down, but I'm enjoying the heck out of this. Not doing the suspension by myself however, nor much of the steering. NEED SOME HELP.
Also came to the realization I "need" to lift the engine (only 40K on rebuild). Ha ha haaa.........Took long enough. Everything else is going to be removed, how hard can it possibly be to lift an engine with nothing on it for painting the frame? Exactly................Very expensive, let me tell you what I paid for NOS wiper blades and three sets of refills today. It's worth it.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 02-18-2016 at 12:34 AM. |
02-19-2016, 08:01 PM | #18 |
Ordered a fuel psi regulator and fuel line and filter kit for the Edelbrock carb. Will try to remember to post pics when I get it installed. Gotta make a bracket for the regulator and figure out the plumbing first.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
02-19-2016, 08:15 PM | #19 |
Took the original rear bumper to the local welder/fabricator today for a new look and function. Will post pics after. I replaced the original a few months ago with a newer "step-bumper" and really dont like it.
Tom
1972 GMC C1500 350/350 1965 Mustang 2+2 289 4spd, show-car 1965 Mustang Coupe 289 4spd, stoplight racer 1/2 dozen Wheelhorse Tractors |
02-19-2016, 11:52 PM | #20 |
Well, It was yesterday, but I got my windshield and back glass put in, now to go over my electrical system, and get ready to fire it up!!!
Ben |
02-20-2016, 12:36 AM | #21 |
02-20-2016, 01:30 AM | #22 |
Scoped out what I need to do to switch floor shifter from B&M to Lokar
02-20-2016, 08:41 AM | #23 |
Organized the work area to have room to work on the truck....does that count?
1970 C10 Short Stepper with 71/72 front clip. |
02-20-2016, 07:57 PM | #24 |
Almost finished up the 68 fender I converted to a 67 and did lower front and rear patches on...
02-20-2016, 08:21 PM | #25 |
got some parts for the dash today so I started to clean it up and repaint the rusty tins painted the needles so I can see em too
