Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-25-2006, 09:55 PM   #251
71chevytruckguy
71chevytruckguy's Avatar
Re: Its Mine the World Famous 67 Dragtruck
oh yeah, i was seeing the trailer, thought it was some kinda wieght box or something. bada$$ truck. chris.
Originally Posted by djracer
It has a steel roll pan! You maybe seeing the trailer in a couple of the pics!
Thanks for the props!
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 04-25-2006, 11:23 PM   #252
ultimate stroke
Re: Look what I got back yesterday!
Its a 60 over 454 with merlin heads and intake 14 to 1 Wiseco domes Lunati pro mod rods steel crank roller cam. I ran this same motor in a pretty heavy 67 camaro injected on alcohol without Nos and it ran 9.20 at 143mph! I hope to run close to that in my truck on the motor but well into the 8's on the spray!
BigJim If it doesn't run 9's I build a bigger one! I want to put this motor in the truck I was building already and build a 565!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
14 to 1 compression 468 with merlin heads, merlin intake a dominator and a fogger! It will be backed up with a really nice powerglide with 1.80 straight cut gears an ultrabell and ultracase! I hope to run in the eights in the quarter and fives in the eighth!
I'll keep you guys and gals posted! I'll probably just run it on the motor first to get the bugs out. I will probably have to have wheelie bars! The ones I want are 629.00!
How did that go?
Not too good!
ultimate stroke is offline   Reply With Quote
Old 04-25-2006, 11:47 PM   #253
djracer
djracer's Avatar
Originally Posted by ultimate stroke
How did that go?
Not too good!
No nitrous yet buddy!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-26-2006, 06:19 AM   #254
Javy
Javy's Avatar
Hello DJ,
I noticed you used the gauge bezel ring I sent you.
It was a gift to you,I PAID FOR SHIPPING,and not even a pat on the back.
That's cold.
It's been so long,I think I even offered for you to build and market them for
yourself because I was too busy-which I still am.
This might be the wrong forum but oh well,ban me.
Maybe I should have PM'ed you but it's 3:25 AM in So Cal and after an 18 hour day working,this seems the easy way.
Sorry,
Javy
Javy is offline   Reply With Quote
Old 04-26-2006, 07:26 AM   #255
djracer
djracer's Avatar
Javy
I had a full set of bezels made I have been really busy trying to get the truck together! The bezel you sent me was a 2 1/16 size and unfortunately it was lost my the machinist! I planned to make a post on the the bezels when I had time to put them all together! I really appreciate you sending me the sample I would have been more than happy to buy them from you if you could have had time to make them! You didn't here me say that it was my idea I just hadn't got around to send out props for the idea! You will see a post about them when I finish my dash! I haven't even gotten my tach or speedo installed at all! I dj'd 4 party's last weekend!
Kevin
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-26-2006, 07:55 AM   #256
Javy
Javy's Avatar
Dj,
If you would like to use my complete dash bezel,I will donate one for your project if you would use it.All the holes are in them but I could customize one for you like I did for Bill @ Wuebbels Repair(hope he didn't mind mentioning his name)
Old 04-26-2006, 08:06 AM   #257
djracer
djracer's Avatar
Javy that is a very nice offer I'd like to try finishing the bezel route but its really tight to get them all in there! If it doesn't work out I will definatly take you up on that offer!
Thanks a bunch,
Kevin
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-26-2006, 11:09 AM   #258
ultimate stroke
So how much spray does it take to pick up a second?
Just wondering
Old 04-26-2006, 03:51 PM   #259
bigjimzlll
bigjimzlll's Avatar
on a mid 12 second truck a 150 shot hit right at the line will give you 1 seconde reduction...the faster you go the mire N20 it will take to acheive the same goal
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 04-26-2006, 04:37 PM   #260
djracer
djracer's Avatar
it also depends on if you are running a nitrous convertor and a rear gear for nos! If I was running all motor I would have a 4.88 rear but I only have a 4.30 gear to help lug the motor which makes it much faster on the spray! I'm gonna try to spray it this weekend or next! I'm gonna start with 200 then go to 300 once the tune up is done! I'll post times and scan the slips if need be!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-26-2006, 05:41 PM   #261
ultimate stroke
Oh don't worry, my spy will be in the tower and will know the et before you do even if there is an "X" on the window.
Old 04-26-2006, 08:23 PM   #262
djracer
djracer's Avatar
Good luck I won't spray it here first!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-27-2006, 07:31 PM   #263
Primed67
Primed67's Avatar
ok, it's been a while since i have spent enough time on the site to actually read something. Man I read all 11 pages and it was worth it. I have got to get the 67 put back together. She is still running but can't go anywhere because i trashed the gears. I never thought i would break a set of richmonds with a small block. Looking at your truck has definately lit the fire under my butt again and hopefully i can start working on i again soon. It does not help that during the week I'm 140 miles from it but i will just have to start making time on the weekends. Thanks for the inspiration to get me started again! Do you have any more pics of how the rear suspension is set up? Any info on it like was it a kit or a custom job? I'm not happy with my current set-up and hell it would be easier to change while she is down. Man I'm so freakin jealous, that truck is just sweet!!!!
1969 Chevrolet SWB Stepside
1959 Chevrolet apache * Sold
1967 Prostreet Chevy SWB Fleetside *Sold
2014 1/2 ton Crew Cab Chevrolet 4x4
Primed67 is offline   Reply With Quote
Old 04-27-2006, 08:55 PM   #264
djracer
djracer's Avatar
Thanks for the compliments!
It has stock trailing arms on the rear with coilover shocks and an antiroll! It was not a kit but the coilover part is real easy to do and you can get a kit for that part!
Kevin
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-27-2006, 09:14 PM   #265
71chevytruckguy
Kevin
wouldn't have thing you could have gotten that much to hook with a factory trialin arms with just some coilovers. or got that much rubber back there. thats nice to know. i think classic performance sells a kit to put coils in these trucks. still tryin to get a posi here, my dad can be a in the a$$. good luck with the spray. chris.
Old 04-27-2006, 09:15 PM   #266
Primed67
Primed67's Avatar
i've got the stock trailing arms as well with coilover shocks. The antiroll bar is pretty trick, i had not seen them on a 67 before.
Old 04-27-2006, 09:21 PM   #267
Primed67
Primed67's Avatar
I was always told that the longer the ladder bars or 4-link the better the suspension would hook. Well the trailing arms are sort of like ladder bars. As far as getting meat under it, you can run a 12" wheel, i believe 7" backspace on it and all you have to do it cut the fenderwells out of the bed. You have plenty of room if done right. As far as your dad you will learn this later when you are older, listen to him because they do know what they are talking about. My dad used to tell me if it wasn't broke don't fix it. On several occasions I wish I would have listened, it would have saved me lots of cash!!!!
Sorry DJRACER i hope i didn't stray your post!
Old 04-27-2006, 09:23 PM   #268
djracer
djracer's Avatar
I would buy a Qa1 kit! I have pics of my coilover setup I had on my 71 street truck if you want to see them PM me an email address!
Kevin
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-27-2006, 09:26 PM   #269
djracer
djracer's Avatar
Tom that I bought my truck from raced againest trucks with custom 40 inch ladder bars and 4 links and he could out 60ft all of them with this setup!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-27-2006, 09:40 PM   #270
bigjimzlll
bigjimzlll's Avatar
heres mine...
Anderson,CA
Old 04-27-2006, 10:33 PM   #271
71Dragtruck
71Dragtruck's Avatar
Here's mine, a little dirty, time to clean it up this weekend I guess nothing like a camera flash to show all the crap after a weekend in the burnout box. LOL.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 04-27-2006, 11:25 PM   #272
djracer
djracer's Avatar
cool lookin trucks guys! I hope to help put on an all truck show and drag race in Montgomery Al in the fall! Yall up for a serious road trip?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-29-2006, 06:35 PM   #273
TugOwar
Read this whole post. Gratz on the truck DJ and good luck with her.
Some videos from you drag truck guys really would be cool!
TugOwar is offline   Reply With Quote
Old 05-02-2006, 09:43 AM   #274
Moostifer
a fool with no money
Moostifer's Avatar
keep us posted on this... I know a few that would make the drive from East Texas
638ci
3800# With Driver
5.71 at 122mph in the 1/8
8.93 at 151mph in the 1/4
ALL MOTOR!
I know, I know... it's a S-10, but it's a truck, and it's fast
BTW... both are street legal
maybe I'll have mine ready by then
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 05-02-2006, 06:43 PM   #275
Primed67
Primed67's Avatar
Moostifer you forgot pics of your ride! It's good to see more representation from East Texas on here especially from Old West.
