08-25-2008, 03:49 PM | #251 |
Re: project INCREDIBLE HULK 6.2L with 6L80E
nope....better
09-21-2008, 08:47 PM | #252 |
ok, getting this thread back to the top.......the vettes dash was gonna be modded to fit this dash, but after looking at it and measureing the curved peices look good on the vette dash cause its small.....put the same curved peices on a truck dash, and they look small.....so keeping with that look im gonna make my own dash outta metal......so after cutting the dash appart, i welded in a filler peice for the whole dash, then bent up some tube stock round bar......to get the skelaton on the dash.....
09-22-2008, 12:03 AM | #253 | |
09-22-2008, 01:08 AM | #254 |
Restoring a 68 SWB
I always look forward to the updates on this build. Cool mods going on!
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
09-23-2008, 11:31 PM | #255 |
09-25-2008, 08:15 PM | #256 |
Quality work being done here. Keep it up.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
09-28-2008, 02:29 PM | #257 |
got some loose ends wraped up, completed the capped wire gutter, and also started to shave the drip rail.....
09-28-2008, 04:03 PM | #258 |
After looking at the picts i don't think we need the round stock...
looks sweet to me! |
10-25-2008, 10:55 PM | #259 |
anything new?
Travis
travis_moffatt@hotmail.com 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
10-25-2008, 11:23 PM | #260 |
little bit of progress......working on the dash still here are a few pics, they are a bit dark, but you get the idea.....
i bent the hoop on the end of the center console, then braced the center section, rough cut a peice of metal for the center, and worked myself around useing clekos to hold everything in place......i then plug welded everything, and cut to shape.....ill get some better pics of everything up tomorrow |
10-26-2008, 09:27 PM | #261 |
here are some more dash progress pics..
made a templet out of cardboard, transfer it to metal, rough cut it out, trimed it a bit, then clekoed it in place.......and the same for the pass. side.....here are the pics |
10-26-2008, 09:28 PM | #262 |
10-26-2008, 09:32 PM | #263 |
very interesting concept... are the window defrost holes not centered on the original dashes? Are you gonna fill them in too?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
10-26-2008, 09:51 PM | #264 |
not sure bout the defrost vents being sysmetrical, but they will be filled in and smoothed.....if you look carefully in the center of the dash i have a center line (in red) for my reffrence...
10-26-2008, 10:26 PM | #265 |
Phone's ringin Dude.
Looking nice.
I pitty the fool with only two headlights!! 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
10-26-2008, 10:39 PM | #266 |
that is gonna look amazing
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
10-27-2008, 01:55 AM | #267 |
Restoring a 68 SWB
Pretty fancy looking. I wanna see more.
10-27-2008, 03:34 AM | #268 |
That is bada$$ That's what I had in mind for my 61.
10-27-2008, 10:54 PM | #269 |
x2
10-28-2008, 12:53 AM | #270 |
Looks great!
Travis
11-02-2008, 10:00 PM | #271 |
got the steering column in, its a ididit tilt, column shift, chrome, one... the mounting positon had to be slighly moved over, do to the underdashed brake setup... to do away with the bungy cord, the upper part of the column mounting bracket was made from a portion of exhaust tubeing..... here is the pics...
11-02-2008, 10:13 PM | #272 |
Ooooh.....It's soooo shiny.......
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
11-03-2008, 10:34 AM | #273 |
PROJECT 7DEUCE
I have a question about the mount on the fire wall side of the column. Where did ya get it and can it be used on a regular stock column?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-03-2008, 07:32 PM | #274 |
i got it from summit racing....they are called a steering column bulkhead, the one i got is 2.25" round... but you can get them in 2" diamater too (stock column OD size).
11-03-2008, 07:35 PM | #275 |
Looks like it's coming along nicely.
I'm diggin the dash too.
