Old 09-24-2009, 04:41 PM   #251
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
its a new one from lmc truck
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=25
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 09-25-2009, 01:56 AM   #252
flamingbig10
6.0 powered square
Re: my 80 build
I fixed my wipers now they turn off when there supposed two and my headlight switch is loose causing a bad ground or the switch is already worn out
Aaron
Old 09-25-2009, 02:18 AM   #253
flamingbig10
6.0 powered square
Re: my 80 build
New improved Video
Aaron
Old 09-25-2009, 07:59 AM   #254
0331grunt
Now what??
0331grunt's Avatar
Re: my 80 build
I really am impressed with what you are doing. It does motivate me to get a move on and work on mine more. Keep up the great work. I really like the interior. Sounds good, too!
69 Long Fleet - Project
06 Ram 1ton Cummins 4x4-DD
01 Tahoe- wifes
"The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi
"A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell
my, um, build
USMC OIF Veteran SEMPER FI!
0331grunt is offline   Reply With Quote
Old 09-25-2009, 11:35 PM   #255
flamingbig10
6.0 powered square
Re: my 80 build
thanks Grunt
Aaron
Old 09-26-2009, 12:17 AM   #256
fire120ball
fire120ball's Avatar
Re: my 80 build
WOW! that is all I have to say i was so intrested in this build. I am also sixteen and me and my dad started by 73 k10 almost a year ago I thought i have done a lot. you have blew me away. I read every post on this thread it is amazing! great job man keep up the good work
fire120ball is offline   Reply With Quote
Old 09-26-2009, 12:41 AM   #257
flamingbig10
6.0 powered square
Re: my 80 build
thanks fireball for the kind words, now I'm 19 now
Aaron
Old 09-26-2009, 01:39 AM   #258
menace121978
menace121978's Avatar
Re: my 80 build
Aaron, pm sent...
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-28-2009, 02:08 AM   #259
flamingbig10
6.0 powered square
Re: my 80 build
found a few more photos
Aaron
Old 09-28-2009, 11:06 AM   #260
0331grunt
Now what??
0331grunt's Avatar
Re: my 80 build
Just want say it looks great. Question- is that Mojave heater hard to install? I like the shaved firewall look and also can't afford the Vintage Air set up yet... Also, would you recomend the EZ Wire harness? Comments or suggestions on it.. Thanks.
Craig
01 Tahoe- wifes
my, um, build
Old 09-28-2009, 08:49 PM   #261
flamingbig10
6.0 powered square
Re: my 80 build
thanks Craig to the way Mounted the heater was on one side its mounted to the engine hump on the firewall and the other side is spaced with square tubing, I haven't hooked up the hoses yet the ez2 to wire is a good product
http://stores.homestead.com/ez2wire/...ick/Detail.bok
Aaron
Old 09-29-2009, 08:03 AM   #262
0331grunt
Now what??
0331grunt's Avatar
Re: my 80 build
Thanks for the info. I think I'm gonna clean my firewall up a little too. Got a long way to go, but at least I am doing something, a little at a time... Keep up the good work!
Craig
01 Tahoe- wifes
my, um, build
Old 10-02-2009, 11:37 PM   #263
flamingbig10
6.0 powered square
Re: my 80 build
no problem, I doing the same on my truck a little at a time and thanks
Aaron
Old 10-03-2009, 12:04 AM   #264
80chevyshortbox
80chevyshortbox's Avatar
Re: my 80 build
truck looks amazing man. when i need a good kick to get me going on my truck i always come and look at this thread. keep up the good work.
80chevyshortbox is offline   Reply With Quote
Old 10-03-2009, 12:10 AM   #265
flamingbig10
6.0 powered square
Re: my 80 build
thanks for the kind words
Aaron
Old 10-03-2009, 05:49 PM   #266
GMC Guy
GMC Guy's Avatar
Re: my 80 build
i really like those peddles you have, where'd you get em?
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 10-03-2009, 05:55 PM   #267
flamingbig10
6.0 powered square
Re: my 80 build
thanks there from Walmart
Aaron
Old 10-03-2009, 06:07 PM   #268
GMC Guy
GMC Guy's Avatar
Re: my 80 build
haha right on, i guess wal-mart is good for something
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 10-06-2009, 01:00 AM   #269
flamingbig10
6.0 powered square
Re: my 80 build
that's wright.
after I find another gauge bezel then I'll will get the materials to fiber glass the dash I plan on getting it done before the years over
and I might swap my euro tail lights and turn signals for stock ones
Aaron
Old 10-20-2009, 01:09 PM   #270
GMC Guy
GMC Guy's Avatar
Re: my 80 build
hey what kind of radiator did you go with?
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 10-20-2009, 03:17 PM   #271
flamingbig10
6.0 powered square
Re: my 80 build
its a afco racing radiator
Aaron
Old 10-20-2009, 03:23 PM   #272
GMC Guy
GMC Guy's Avatar
Re: my 80 build
do you like it? and did it fit in there without modification? the truck looks amazing btw, are you near done?
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 10-20-2009, 03:32 PM   #273
flamingbig10
6.0 powered square
Re: my 80 build
I like I got it at a speed shop that deals with mostly dirt track stuff, I got fairly cheap when they were having moving sale, I could of used the factory radiator brackets but my dad friend build parts for home conditioners and made me some, and thanks on the complement I'm not completely done but once I get a good paying job and buy a driver then I going start over on my truck but I will be leaving the interior and paint alone
Aaron
Old 10-21-2009, 04:12 AM   #274
GMC Guy
GMC Guy's Avatar
Re: my 80 build
i'm literally in the same boat. i just do what i can with what i have lol but hopefully one of these jobs i've applied for will work out and i'll have money for paint and body work and re-doing the drive train. but for now i just love cruising around downtown and turnin heads
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 10-22-2009, 02:08 PM   #275
v502
v502's Avatar
Re: my 80 build
Very nice build i love the interior
v502 is offline   Reply With Quote
