#251 |
![]() Join Date: Oct 2009
Re: 1969 Chevy Stepside Restoration/Build up
WOW!! Thats one sharp looking setup. I know you can't wait to get it installed. Awesome.
Justin
Justin 71' C10 SWB 00' Dakota R/T 05' Z-71 Silverado 16' Z-71 Silverado Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904 |
#252 |
69' Chevy Stepside
![]() Join Date: Mar 2008
Thanks, your right I can't wait to get it in, but I want the 5.3L to sell first.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
#253 |
69' Chevy Stepside
The 5.3L is out of the truck! Came out really easy!
#254 |
69' Chevy Stepside
What do you guys think of these valve covers?
![]() I'm liking the ones that say GM Peformance Parts LSX (even though it's not the LSX block its still LS based) I ended up ordering the GM Performance Parts LSX valve covers!!! Can't wait to get them in!
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 11-11-2010 at 05:57 PM. |
#255 |
Still Learning
I like the chevy one at the bottom. Nice job pulling the engine.
#256 |
69' Chevy Stepside
The new Circle-D Stall converter came in the mail yesterday so I installed it into the trans and started putting the new 6.0L in!
![]() ![]() ![]() ![]() ![]() Engine is all bolted up the the transmission bellhousing and I got the converter bolted up to the flex plate! Then I started on the motor mounts and got one side in but somehow the other side stripped out even though it was a new mount when I put in the 5.3L??? So I had to go buy a new motor mount. I'm going to lift the motor up and slip in the new one today and hopefully get some more stuff hooked up!
#257 |
Very sweet on the new engine combo.....didn't see if you mentioned it, how much cam you stick in the 6.0L ?
you doing relocate on the coil packs with those covers, where to? I'd like to hide mine inside the firewall but not sure how that would look
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear Last edited by 71cadc10; 11-16-2010 at 06:52 PM. |
#258 |
Still Learning
Looks like a super clean install,,sorry to hear you had the stripped mount.
#259 | |
69' Chevy Stepside
~As for the coil packs.... that's yet to be determined any ideas? I was thinking of mounting them down in the frame rails and then building a spark plug wire set and nicely running them to each plug. But I'm not sure yet. ![]()
#260 |
69' Chevy Stepside
Thanks, lol at least the new motor mount at car quest was only $7.99 haha!
#261 | |
also in a G8 GT it made 420rwhp thru the 6spd auto and untouched heads coils in the frame rails would probably be decent...behind the firewall with some slots to bring them thru....on the inner fenders, lots of options
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear Last edited by 71cadc10; 11-17-2010 at 02:30 PM. |
#262 | |
69' Chevy Stepside
![]() ........................ FIRST TEST START!!! ![]() Everything sounded good, I need, new plugs and wires. The problem is I need one of those special custom make your own plug wire kit that will work with LS engines. So I can mount the coils down in the frame rails hidden away and run the wires back up to the plugs. Anyways here's some pics of it after I had just started putting the intake back on. I also got many harness modifications done and cleaned up a lot more wiring. ![]() ![]() ![]() I've got a video of the first start up I'll post that later.
#263 |
69' Chevy Stepside
#264 |
Still Learning
Wow! that was a fast swap out! I'm very impressed
#265 |
69' Chevy Stepside
I built my own custom throttle bracket out of some nice steel and painted it to match. The LS3 intake didn't have anyway to mount one so it's mounted to the top (5th) bolt of the throttle body that is not used. Works great!
#266 |
lookin good!
R.I.P. Killer 71 10/26/07 |
#267 | |
Still Learning
#268 | |
69' Chevy Stepside
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 11-24-2010 at 04:39 AM. |
#269 |
69' Chevy Stepside
- - - - - - - - UPDATE!!!! - - - - - - - - - - - - - - - -
Lots of new parts!!! Got the GMPP Valve Covers!!, Harmonic Balencer, New HB Bolt, 96-99 Vortec Plug Wires, New ACdelco Irridum Plugs at .040, 2 Gallons of Antifreeze and some ATF. -Relocated the coils to the frame rails on either side of the engine, back. Ran the 96-99 Vortec truck wires that I got from the cheap parts store for 29.99. Somehow they work fine with the LS1 coils, I'll buy the MSD Universal wire kit (32079) later. It was a trick using the 90 degree plug boots with the headers, but with carefull routing and zip ties it worked out. -Installed the new GM Peformance Parts LSX Valve Covers, they even came with new chrome bolts and chome oil fill cap which was super nice. They really set off the engine!!! -Installed the new Crank Pulley/Harmonic Balencer and new bolt. -Reinstalled radiator and antifreeze. -Installed new Polished Stainless Steel Radiator cover, looks really good I never had anything to cover the radiator before and it looked really bad. > Finally I got to test start it again and let it run for a bit although it was a bit late...so I only ran it for a couple minutes but everything sounded great and the sqeel and clicking was non existent... I'll get a video up when I start it up again tomorrow. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Things I need to do is buy a proper cold air intake pipe of some kind and get a new upper radiator hose so I can run the intake over to the drivers side, maybe use some type of aftermarket air box or open filter.
#270 |
Still Learning
Man that new bling looks great on there! You know you're going to have get some pics of where and how you mounted the coilpacks. I like how you knocked this install out. I remember when I was full of Pi** and vinegar(smile).
#271 |
69' Chevy Stepside
Well after restoring my truck it never had the correct "vehicle information sheet" that goes in the glove box that lists the options the truck originally came with. Since my original was long gone I ordered a new one from LMC but it comes as just a sticker. This is a problem, I used some handy photoshop tricks and tapped the new sheet to a piece of printer paper and printed all of the options I wanted to list and my VIN. These are the results:
Sheet: ![]() Finished Product! I found some special fonts that look completely original! ![]() ![]() ![]() ![]()
#272 |
Still Learning
I love the new SPID sheet! It turned out great and I love how you put all the actual options on there.
#273 |
spirit rider66
![]() Join Date: Oct 2008
Location: pahrump, nevada, in the bowels of the Mojave desert
Matthew; classic parts and lmc have a new clear lens now for the inside cab light ,,check it out when you get a chance
:Chevy: If you don't run your own life,, some one else will. ![]() ![]() ![]() Last edited by seldomseen65; 11-27-2010 at 12:18 AM. |
#274 | |
Spike ![]()
68 stepside http://67-72chevytrucks.com/vboard/s...0&goto=newpost |
#275 |
![]() Join Date: Jul 2010
nice work
