Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 07-27-2017, 05:38 PM   #251
70custom20
70custom20's Avatar
Re: Power Brake Booster Adapter Bracket
I saw in another thread, someone had posted a whole sheet of GM PRO numbers for brake boosters. The JM3 reads booster, brake, 240mm high flow, while the JM5 reads booster, brake, 200mm high flow. I'm not sure what difference the milometer size has to do with anything. Also, would it be better to grab one of these boosters off of a early 2000's S-10 at the junk yard, or would it be better to buy one at a local parts store like NAPA, etc??
70custom20 is offline   Reply With Quote
Old 07-27-2017, 05:46 PM   #252
70custom20
70custom20's Avatar
I looked for an edit feature, couldn't find one. Anyway, RPO not PRO. I saw quite a few of the JM3 boosters in a local hard in early 2000's S-10 blazers. How much of a PITA are they to pull out of the truck?
Old 07-27-2017, 05:47 PM   #253
MASTERBrian
I can't answer the other questions, but if you're asking if better to buy used or new....I'd think everyone would say New. Unless your funds don't allow. Mine is from a c1500, forget the year.
MASTERBrian is offline   Reply With Quote
Old 07-27-2017, 11:54 PM   #254
Captainfab
60-66 Nut
Which is better, new or used, depends on your preference and budget. With a rebuilt one, you will need a core or pay the core charge. Pulling a used booster can take some time as there is quite a bit that needs to be removed before you can get to the nuts on the studs and the pushrod on the brake pedal. You will need a long extension or two and a swivel socket or a universal joint.
Old 07-28-2017, 09:26 PM   #255
70custom20
70custom20's Avatar
The money doesn't bother me either way. I just wasn't sure if buying one from NAPA or another parts store was better or worse, based on it seems like replacement parts are sometimes pretty ****ty these days.
Old 07-28-2017, 09:39 PM   #256
MASTERBrian
Personally I'd worry about how long the thing say and if the diagram is therefore cracked on used.
Old 07-28-2017, 11:48 PM   #257
Captainfab
60-66 Nut
In my experience the original GM boosters can last a long time. Hook one up to engine vacuum and see if it holds vacuum. If so, the diaphram is good.
Old 08-09-2017, 03:03 AM   #258
n3xb360
I was wondering if you ship internationally? And how much it is for the 67-72 booster bracket with hydraulic clutch conversation
n3xb360 is offline   Reply With Quote
Old 08-09-2017, 11:13 PM   #259
Captainfab
60-66 Nut
Yes I ship worldwide. The price for the '67-'68 or '69-'72 booster bracket with the hydraulic clutch conversion is exactly the same as in post #1 of the for sale thread seen here.
http://www.67-72chevytrucks.com/vboa...d.php?t=652871
Shipping that large box to Canada is quite expensive. The shipping alone is about $64.00 USD. Many of my Canadian customers have a delivery address just this side of the border.
Old 08-23-2017, 08:28 AM   #260
69ChevyCST
Being a fabricator I was a little hesitant to buy something I could make myself with a little effort. I received my adapter bracket (powder coated) in the mail and was very impressed with the quality of the bracket. Packaging, weld and powder coat quality was second to none. Thanks for supplying a quality product!
James McGrew
Owner
Madison Street Hot Rods
1969 CST Short Bed - (LT4/4L60)
1974 Chevelle Laguna S-3 (406/4-Speed)
1970 Olds 442 (455/4-Speed)
1935 Chevy 3-Window Coupe (Stock)
69ChevyCST is offline   Reply With Quote
Old 08-23-2017, 10:57 PM   #261
Captainfab
60-66 Nut
Thank you for the compliments and I appreciate the purchase
Old 08-30-2017, 11:37 AM   #262
beaterku
beaterku's Avatar
I'm interested in this bracket. It makes for a very clean setup. I do have a question. I have a factory tilt column that I bought from Kevsclassics. Looking at where the shift arm is in relation to the center-line of the brake push rod, an 8" dual booster might be a tight fit.
Can anyone confirm that an 8" dual booster such as the Inline Tubing unit http://r.ebay.com/dYzdyl will fit with the factory tilt column shift arm?
Thanks!
beaterku is offline   Reply With Quote
Old 08-30-2017, 11:19 PM   #263
Captainfab
60-66 Nut
From what info I have received from a couple past customers, you must use a booster that is smaller than 10" in diameter. If it were me, I would go with a 9-9.5" diameter dual diaphram booster.
Thanks!
Old 09-27-2017, 11:23 PM   #264
Mikem_72
Captainfab,
Received my bracket today, thank you for the speedy delivery and a beautiful product. I'll post pictures of it installed after paint. Thank you again!!
-Mike
1970 C10 Stepside 350/700r4
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632707
Mikem_72 is offline   Reply With Quote
Old 10-11-2017, 04:48 PM   #265
Mikem_72
Originally Posted by Mikem_72 View Post
Captainfab,
Finally got everything mounted, thanks again Captainfab!!
-Mike
Old 10-12-2017, 12:16 AM   #266
Captainfab
60-66 Nut
Thanks for posting a couple pics.
Old 10-17-2017, 11:55 PM   #267
Captainfab
60-66 Nut
All of my booster brackets now come with slotted booster mounting holes to also accept aftermarket universal boosters with the 2-3/8" x 2-3/8" center to center mounting studs.
Old 11-28-2017, 04:36 PM   #268
gringoloco
A guy with a truck
gringoloco's Avatar
PayPal sent for powder coated bracket. Thanks!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-29-2017, 12:55 AM   #269
Captainfab
60-66 Nut
PM sent
Old 12-28-2017, 09:24 PM   #270
rob32472
Pay pal sent
rob32472 is offline   Reply With Quote
Old 12-29-2017, 12:19 AM   #271
Captainfab
60-66 Nut
Payment received for a powder coated standard '67-'72 booster bracket.
Originally Posted by rob32472 View Post
Pay pal sent
Old 01-10-2018, 01:04 AM   #272
Captainfab
60-66 Nut
I am officially notifying everyone that I will be on vacation from 02-05-18 thru 02-13-18. I will do my best to get all orders built and shipped before I leave, if placed by 01-31-18. Orders placed while I am gone will be built and shipped in order of receipt of payment once I return. Thanks for understanding.
Old 02-18-2018, 11:42 PM   #273
Cheyenne1970
Hello I would like to purchase an adapter bracket, how much would it cost for a powder coated one shipped to 92870?
Cheyenne1970 is offline   Reply With Quote
Old 02-19-2018, 01:01 AM   #274
Captainfab
60-66 Nut
The price is Exactly the same as in post #1 of this for sale thread........$77.65
Old 02-19-2018, 01:06 AM   #275
Cheyenne1970
Sorry I forgot ask about the hydroboost mount plate as well
