Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 01-26-2010, 12:09 AM   #251
scotts62
One day...
scotts62's Avatar
Re: My 93 Crewcab Build
Yeah i know..
i had an old Oriellys delivery Nissan truck that i lowered and put 6 lug chevy wheels on and a guy at the votech i went to had that truck and it didnt run, he gave me $500 and the 83 for the Nissan, i went over there to get it (only saw pics) and he had the distributor out in the floor board, turns out he was doing a tune up and pulled the distributor who knows and i just basically finished what he had started and drove the truck home and he wasnt too happy about that but titles were signed and it was too late.
It was red and was missing most of the interior, i went to pull-a-part and scrounged up all i needed and sold it for 4200 i think.. its been a few years back
Scott
93 crew cab build
Project 62
Old 01-26-2010, 12:15 AM   #252
highperf4x4
sometimes it works that way!
highperf4x4 is offline   Reply With Quote
Old 01-26-2010, 09:57 AM   #253
JohnC
JohnC's Avatar
I agree with Travis that was a pretty slick truck man! Now we just need to get you back over to the square body side.
JohnC is offline   Reply With Quote
Old 01-26-2010, 10:41 PM   #254
scotts62
One day...
scotts62's Avatar
maybe one of these days
Scott
93 crew cab build
Project 62
Old 01-27-2010, 03:42 PM   #255
TimE
Hey Y'all!!
TimE's Avatar
Aw heck, Scott, what difference would one more project make?
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 01-27-2010, 11:08 PM   #256
scotts62
One day...
scotts62's Avatar
um kinda like adding one more mouth to feed and getting a pay decrease at the same time
Scott
93 crew cab build
Project 62
Old 01-27-2010, 11:35 PM   #257
mcbassin
Still Learning
mcbassin's Avatar
That was a great looking truck! Sucks you had to sell. I have been there too.
Hows the manifold welding going? I had pretty good success welding a bung for the o2 sensor on the 86. I used a tig and stainless filler worked pretty good. Let me know if I can try to weld it for you.
mcbassin is offline   Reply With Quote
Old 01-28-2010, 02:40 AM   #258
highperf4x4
I'll let you know about some stuff you can try to weld for me!
Old 01-28-2010, 08:46 AM   #259
scotts62
One day...
scotts62's Avatar
Cool, well i tried to braze it up thats all i can say at the moment, i hope it works ok but we'll see
Scott
93 crew cab build
Project 62
Old 01-28-2010, 10:01 AM   #260
mcbassin
Still Learning
mcbassin's Avatar
No problemo! Just give me the heads up.
I tried to do weld up a inboard manifold last week with no success, then switched to braze....man it looked good but as soon as it cooled the crack got bigger than before. I think its just too thick to fix. I told my friend, your just going to have to buy a new one. Some of the cast metal can be welded, some can't just depends on the metal? Good luck! and don't forget pictures.
Old 01-28-2010, 03:54 PM   #261
scotts62
One day...
scotts62's Avatar
Damn had to bring up pictures....
I promise you,you dont want to see pics of my braze job
I ground the cracks out with a burring bit then used a rose bud and heated the manifold up nice and hot then switched to a brazing tip and got around the crack glowing red and used a nickel rod, it seemed to do the trick but i really dont want to have to do it again so ill probably buy a new one..
Scott
93 crew cab build
Project 62
Old 01-28-2010, 10:30 PM   #262
mcbassin
Still Learning
mcbassin's Avatar
I never thought about trying nickel it might have worked? who knows? brass sure didn't.
Old 01-28-2010, 10:51 PM   #263
scotts62
One day...
scotts62's Avatar
It looks as if it sealed it up, i dont know i may try it and see, it didnt take too long to take it off so it wont be as depressing as say my trans if it doesnt work
Scott
93 crew cab build
Project 62
Old 01-28-2010, 11:00 PM   #264
highperf4x4
Don't you normally use nickel for cast iron?
Old 01-31-2010, 02:34 AM   #265
wildmanaaron
Do you remember how much you had to move the hanger forward? I think there is roughly 18" difference right?
Well i got some stuff done on it today. Ground off some rivets and done some measuring, just have some clamps holding it close to where it needs to go for now.
wildmanaaron is offline   Reply With Quote
Old 01-31-2010, 11:22 AM   #266
scotts62
One day...
scotts62's Avatar
Nope same as you would have to cut and shorten your frame, 14 in
Scott
93 crew cab build
Project 62
Old 01-31-2010, 11:34 AM   #267
wildmanaaron
I need to go back and check my measurements again. I measured 93" from the center of front bed mount to the rear edge of the frame on my longbed and 75" on a shortbed frame at the junkyard. Of course there is 5" diff behind the rear shackle bracket between the two also.
Old 01-31-2010, 11:41 AM   #268
scotts62
One day...
scotts62's Avatar
There is 14in difference in a long bed and short bed, i measured exactly 14 out and put the brackets there and the wheel is centered nicely.
Now i cut about 18in off the back after i moved everything but the actual rear end movement is 14in.
Scott
93 crew cab build
Project 62
Old 01-31-2010, 12:39 PM   #269
mcbassin
Still Learning
mcbassin's Avatar
Actually, I use a stainless rod for cast when welding the tig and brass with when torching. But stainless has nickel in it so yes I normally use a nickel alloy.
Old 01-31-2010, 01:23 PM   #270
highperf4x4
Gotcha. Thanks for the info.
Old 01-31-2010, 11:50 PM   #271
wildmanaaron
I cut out 13" of the frame today.
There is 5" that has to come out behind the rear shackle bracket, so that would add up to 18".
Old 02-01-2010, 08:24 AM   #272
scotts62
One day...
scotts62's Avatar
I would cut another inch out otherwise the wheel will probably not be right in center of wheel well..
Scott
93 crew cab build
Project 62
Old 02-01-2010, 01:19 PM   #273
highperf4x4
x2
Scotty, where are the pics of the welded manifold? Did you think we would forget?
Old 02-01-2010, 09:11 PM   #274
scotts62
One day...
scotts62's Avatar
x2
going to get a new one more than likely, had someone on here offering to sell a couple but no reply yet...
Scott
93 crew cab build
Project 62
Old 02-02-2010, 10:50 PM   #275
scotts62
One day...
scotts62's Avatar
Well the trans i rebuilt for my 92 Xcab goes into reverse and drive not sure if it shifts yet because it doesnt have much gas and i dont feel like going to get any just to drive it and possibly get stranded in the cold... but maybe tomorrow
Scott
93 crew cab build
Project 62
