Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 07-05-2012, 11:30 AM   #1
98GMCSierraGuy
Re: My 88 buildup on a tight budget
Yeah man wouldn't want to get you locked out sorry
98GMCSierraGuy is offline   Reply With Quote
Old 07-05-2012, 12:07 PM   #2
benoit454
Chris
benoit454's Avatar
it's alright I didn't know about it either. until that had happened.
as for the build going to try a CTS and see if that fixes the flooding crap. might solder my rad and see if I can fix it.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 07-09-2012, 07:49 PM   #3
benoit454
Chris
benoit454's Avatar
started having fuel problems so i removed the TB for a rebuild and clean, dropped the tank to clean it and my sending unit is junk due to rust so I have to change it.
Chris
GIT R DONE!!!!!!
Old 07-10-2012, 05:17 PM   #4
benoit454
Chris
benoit454's Avatar
started shaving the Tb down for some ultimate tbi mods.
Chris
GIT R DONE!!!!!!
Old 07-10-2012, 05:56 PM   #5
benoit454
Chris
benoit454's Avatar
and the tank removed yesterday.
you can easily see the one twisted/broke line, the other two are broke loose from the sending unit, not to mention at the end my gas hand woul dbouce and drop lower then it should and stay and such, so hope a new sending unit fixes all of that.
Chris
GIT R DONE!!!!!!
Old 07-11-2012, 03:42 PM   #6
benoit454
Chris
benoit454's Avatar
I think i'm done with the tb smoothing now lol..
I also ordered my sending unit for the tank.
Chris
GIT R DONE!!!!!!
Old 07-12-2012, 12:58 PM   #7
75ChevyGuy
GM Parts Guy
75ChevyGuy's Avatar
Wow that came out nice! How long did it take from start to finish? Did you just use a rotary tool?
1975 Chevrolet C-10 Custom Deluxe (DD/WIP)
1989 Chevrolet C1500 reg cab stepside (Winter Truck)
1977 Harley Davidson XLH 1000 (Summer Cruiser)
75ChevyGuy is offline   Reply With Quote
Old 07-12-2012, 04:08 PM   #8
benoit454
Chris
benoit454's Avatar
it took me over the course of 2 days off and on, maybe 4-6 hrs if that total but ONLY because of me doing the end by hand using sand paper.
I used a big grinder to knock off the ridges, then used a grinding stone in an electric drill to rough it out. After that is was just that, ROUGH so I used some 80 by hand, then some 150, wet sand 220, then wet 320 and that is what you see.
Chris
GIT R DONE!!!!!!
Old 07-15-2012, 10:50 PM   #9
benoit454
Chris
benoit454's Avatar
bought my tbi rebuild kit today, have to get some cleaner and do it all tho.
Chris
GIT R DONE!!!!!!
Old 07-18-2012, 06:21 PM   #10
benoit454
Chris
benoit454's Avatar
sending unit came in today, hopefully I can get it put in and the tank back in the truck sometime this weekend or sometime in the very near future at least.
I also have to clean and rebuild the TB, I already have the kit, just gotta get some cleaner.
Chris
GIT R DONE!!!!!!
Old 07-23-2012, 05:14 PM   #11
benoit454
Chris
benoit454's Avatar
cleaned and rebuilt my Tb and then painted my tank as well...
Chris
GIT R DONE!!!!!!
Old 07-23-2012, 07:50 PM   #12
benoit454
Chris
benoit454's Avatar
got more pics and removed my gas tank crossmember/ support. I'm going to paint it tonight or tomorrow and hit the tank with a 2nd coat same time.
Chris
GIT R DONE!!!!!!
Old 07-29-2012, 06:23 PM   #13
benoit454
Chris
benoit454's Avatar
put it all back together and got it running this weekend, washed it, bled the brakes and set the toe. Now I have to try and fix my radiator and tint my windows, then get my door lock rod clips in and fix the stupid handles.
Chris
GIT R DONE!!!!!!
Old 09-16-2012, 10:56 PM   #14
benoit454
Chris
benoit454's Avatar
wow it's been quite some time since I posted.
I fixed the lock rod clips and such, put the interior all back together. I also patched up the leaking rad heater hose nipple, solder, then jb weld so I'll hope it works for now.
The biggest issues was my brakes. I could NOT get a pedal, when the truck off I could get maybe half pedal after pumping, but once running they'd hit the floor and set the brake light. I fought and fought those stupid things. I already had new calipers, pads, shoes and wheel cylinders, and when replacing the parking brake cables I tore a boot on one cylinder, so it got replaced and new hardware kit installed on both sides, as well as new front hoses up front when i rebuilt the front end.
I tore the entire brake system apart, cleaned and blew thru it all with my compressor, ended up changing both rear axle hard lines, no go, changed the master cylinder, still nothing, changed the proportioning valve, nothing.
As most of you know I did away with the RWAl abs crap too, well found out that fitting was leaking, it had a groove in the top for some reason and was leaking down thru the threads. I changed it with a new one, didn't help, so now I was down to one last thing, the rear brake hose. It must have been it, changed it and got a better pedal, drove it around in front of the house some doing emergency stops forward and back to adjust the rears out more and now it's much better.
I think I had a combo of 3 things, one the prop valve, but ONLY after I took it apart, since it started leaking afterwards.
2 the fittings having a nick in it.
3 the rear line swelling inside making it shut off somewhat.
I haven't had it out on the road yet but sometime this week I hope to. First time in months it'll be driven, well besides in and out of the yard.
Chris
GIT R DONE!!!!!!
Old 09-17-2012, 01:50 PM   #15
Dub_X
Professional Crow Bar Tosser
Dub_X's Avatar
Sounds like you've been having some issues there Chris! Besides your brake issues, any new paint updates?
Dub_X is offline   Reply With Quote
Old 09-17-2012, 02:43 PM   #16
benoit454
Chris
benoit454's Avatar
none, everything got put on hold for it.
I haven't had any extra cash to get anything so I wasn't able to buy the rest of my paint stuff, much less paint anything.
I most likely won't have anything paint wise until next spring since it's soo late in the year now.
Chris
GIT R DONE!!!!!!
Old 09-17-2012, 08:04 PM   #17
Dub_X
Dub_X's Avatar
Ah alright. Well either way, can't wait to see it man
Old 09-29-2012, 10:31 PM   #18
benoit454
Chris
benoit454's Avatar
been drving this thing around again, been doing good.
Chris
GIT R DONE!!!!!!
Old 10-11-2012, 07:06 AM   #19
bufmatmuslepants
Junior Member
Can you get an installed pic of your massaged throttle body? I would be slightly concerned that the spray of the injectors would be getting out of the TB due to you taking off those tabs, but perhaps the suction is enough to keep the fuel going straight down to the blades.
1979 K10 reg cab short bed 33x12.50s - GONE
1988 4x4 reg cab long bed 337k miles - GONE
1995 Z71 GU6 G80 F44 ext cab short bed 149k 305/70/16s - GONE
1995 NZZ GT4 2dr Tahoe 3" lift 14 bolt sf 155k 305/70/16s - GONE
1994 Z28 M6
1995 Z71 GT4 G80 ext cab short bed 215k GONE
1997 GT4 G80 Yukon 4 door leather, sunroof 168k miles GONE
2003 Avalanche Z71 GT4 G80 165k miles
bufmatmuslepants is offline   Reply With Quote
Old 10-12-2012, 08:45 PM   #20
benoit454
Chris
benoit454's Avatar
they sporay downward anyways so it's no worry on the fuel coming out, plenty of ppl have done the same mod.
Chris
GIT R DONE!!!!!!
Old 02-12-2013, 02:07 AM   #21
71red
71red's Avatar
Wow, you really have brought this truck a long way!!
Great job!
Keep it goin!
71red is offline   Reply With Quote
Old 02-15-2013, 03:17 AM   #22
chevy88
chevy88's Avatar
Lots of hard work done here, keep it up.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 02-15-2013, 11:50 AM   #23
Dub_X
Dub_X's Avatar
Any uh, updates on this ol' beast?
Old 02-16-2013, 03:30 PM   #24
benoit454
Chris
benoit454's Avatar
nothing, just got some spring hangers in the mail for my future SAS other then that nothing at all.
I've been working on our house, have tons left to do then start on my garage, then maybe get back to buying the rest of the paint supplies so I can paint it. Also got leads on most of the sas parts as well, so it's a toss up which will be first, paint or SAS. Most likely paint because it already doesn't fit in my garage door lol.
Chris
GIT R DONE!!!!!!
Old 02-17-2013, 03:04 PM   #25
Dub_X
Dub_X's Avatar
I'd go with paint
