Old 03-25-2010, 02:58 PM   #251
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Air Ride Install - '69 Chevrolet SWB Stepside
Man Doug... that is smokin'!
Shh.... Shh... Shhhhhhhhhhhhhhhh gotta love it!
On my next truck, guaranteed!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-25-2010, 06:47 PM   #252
ibad57
ibad57's Avatar
what did you use for bump blocks in front?
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172
ibad57 is offline   Reply With Quote
Old 03-25-2010, 07:02 PM   #253
lolife99
67-72 parts collector,…
lolife99's Avatar
Originally Posted by tcb-1 View Post
Kyle,
my tires are 225/55/17 or 8.86" cross section. I checked the clearance before I removed the bed and I room to spare when completely aired out. wanna buy them?!!
All,
Yep, I was trying to slow down the dump in the video. I plan on using exhaust fittings on the dump valves which will slow down the drop a bit. glad Keith (lolife99) discouraged me from running 1/2" line. talk about hitting hard!!!
I had a tank fitting that I noticed was leaking a bit the first time I fired up the compressor. since I built this system with ease of component removal in mind, it was a test to see how fast I could remove a complete valve setup and fix the problem. after 5 minutes, the leak was fixed. guess I did okay......
Doug,... a cheap fix it to use some "drilled" pipe plugs in your dump valves.
(Brass would match everything nicely)
Start by drilling one plug with an 1/8" drill bit,... and see how fast it dumps.
Increase drill bit sizes until you get the speed you want.
Then drill the other three plugs.
Super simple and clean.
Almost un-noticeable.
Keith
Convert to disc brakes.
Old 03-25-2010, 07:08 PM   #254
tcb-1
Nothing to see here.....
tcb-1's Avatar
Keith, that's why your a mod on the suspension forum! great idea!!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-25-2010, 07:11 PM   #255
tcb-1
tcb-1's Avatar
no bumpstops on the front. the Dominator bags have built in stops in them, don't know about Firestone, Slam Specialities, etc. Keith, do you know?
Doug
Old 03-25-2010, 08:14 PM   #256
lolife99
lolife99's Avatar
The Slams are suppose to have internal bumpstops.
I had to install an external bumpstop on my lower a-arms to keep the tires off my inner fenders.
(my front 20's are approximately 27" tall)
Keith
Old 03-25-2010, 08:20 PM   #257
tcb-1
tcb-1's Avatar
that makes sense. mine are right under 27 and I have about a 1/4" to the inners. you've also got a bit more width on those meats of yours.
Doug
Old 03-25-2010, 08:39 PM   #258
kev2809
low n' slo
kev2809's Avatar
thats what she said...
lol, j/k...i had too
do you have a pic of this? ive heard of it but i dont think ive ever seen a pic. i have 1/2" line with 3/8" valves. i havent hooked it em up yet but wondering what i can do just in case they are to fast...
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 03-25-2010, 08:59 PM   #259
lolife99
lolife99's Avatar
No.
It's just a pipe plug with a hole drilled in the end of it,... to allow air to pass at a slower rate.
Keith
Old 03-25-2010, 09:13 PM   #260
tcb-1
tcb-1's Avatar
you install the pipe plug (that's drilled to your speed of drop) into the dump valve outlet. great idea. cheap, effective, and clean.
Doug
Old 03-25-2010, 09:36 PM   #261
lolife99
lolife99's Avatar
And I like the idea of using "allen" plugs.
No square or hex head hanging out of the valve.
Keith
Old 03-25-2010, 10:10 PM   #262
sourkraut
sourkraut's Avatar
looking good doug!
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 03-25-2010, 10:10 PM   #263
tcb-1
tcb-1's Avatar
ahhhhh, yet another good point. guess I'll be calling MSC tomorrow.
Keith, I have also seen the sintered metal exhaust fittings. have you ever heard how hey would work?? I'll get you a pic if you don't know what I'm talking about........
Doug
Old 03-25-2010, 10:59 PM   #264
lolife99
lolife99's Avatar
Yep,...I know what you are talking about.
We use them at work as vents in pump and valve cases.
I'm not sure how much they would restrict flow though.
(if any)
Keith
Old 03-25-2010, 11:01 PM   #265
lolife99
lolife99's Avatar
Doug,... Jegs also has black aluminum allen plugs.
(or blue, or red, or stainless)
The black 3/8" plugs sell for $3.99 a pair.
Keith
Old 03-26-2010, 01:26 AM   #266
kyull67
kyull67's Avatar
No thanks on the wheels Doug, I think mine will clear after looking closer! Can't wait to see what you do with it next.
kyull67 is offline   Reply With Quote
Old 03-28-2010, 10:04 PM   #267
tcb-1
tcb-1's Avatar
and so the bed floor raising has began. I knocked a ton of red Wyoming dirt out from between the floor boards. now I have design the floor structure and somehow remove the angle strips that were tack welded to the side panels.
stay tuned.....
Doug
Old 03-29-2010, 02:41 AM   #268
Jeffs70
Jeffs70's Avatar
awesome Doug looking great every little bit helps
How well does it work with just the one compressor? I see alot using Dual Compressors and I am guessing this is for heavy use? Since I wouldn't be using mine for heavy use 1 Compressor should work good?
Jeffs70 is offline   Reply With Quote
Old 03-29-2010, 08:21 AM   #269
tcb-1
tcb-1's Avatar
Jeff,
it takes my Viair 400c 1 minute 23 seconds to air the 5 gallon tank to 150psi. that is enough for 2 full up and down cycles, which is fine for me.
2 compressors would be nice, but imho, is not needed if your not doing anything crazy.
Doug
Old 04-10-2010, 05:33 PM   #270
Newtz67
Newtz67's Avatar
I really like the clean install you did! Looks great!
Newtz67 is offline   Reply With Quote
Old 04-10-2010, 10:59 PM   #271
project1968
project1968's Avatar
Subscribing to this thread....Really fantastic work.
project1968 is offline   Reply With Quote
Old 04-12-2010, 02:08 PM   #272
mexgrhd68
mexgrhd68's Avatar
niced work,keep it up, and more pics please!!
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks )
54 caddy 62 series 4 door(younger sons ride, aka 54caddy )
70 caddy 2 door, 89 chevy silverado stepside(older sons rides )
mexgrhd68 is offline   Reply With Quote
Old 04-13-2010, 07:03 AM   #273
big_al_71
big_al_71's Avatar
Doug you have done such an amazing clean job. I cant wait to see the truck finished..keep up the awesome work!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 04-13-2010, 09:00 PM   #274
bw4sale
bw4sale's Avatar
Been away from the board for a while and just saw this. Your truck has always been one of my favorites. Did you say you're selling the wheels that were on there? (Sorry if it's a stupid question. Just kind of skimmed the post and mostly looked at the pics ) Can you tell me about them and what you want for them? I might be interested. Thanks.
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
Old 04-13-2010, 10:05 PM   #275
tcb-1
tcb-1's Avatar
Brent,
From my add over on the for sale posts:
"Decided to go yet in another direction. So, I’m selling (5) rims, tires, and center caps. That means you have an identical spare!
(5) NEW 17” x 7.5” on 6 x 5.5” bolt circle 2007-2008 Toyota FJ Cruiser rims
(5) NEW General Tire Altimax HP tires 225-55-17 (still has writing on center tread)
(5) NOS 89-94 Chevrolet center caps
-Tires have been mounted and high speed balanced
-The rims have been painted in HOK 2 stage gloss gray (have touch up paint)
-The rims and tires have less than 50 miles on them, total
-The tires are not blemishes
-No patches, never flat or under deflated
You will need to purchase double threaded lug nuts and the lug nut covers (sold on Ebay) to mount the center caps.
$625.00 picked up or delivered within 100 miles of Kansas City. I have shipped rims and tires before on this forum and the lowest I have found is Forward-Air. I can get a quote for actual shipping costs from Kansas City International Airport (KCI) Forward Air Terminal and will deliver there for free"
really had no takers on that price, which I'm loosing money on, but.......
Doug
