Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 08-22-2012, 10:07 PM   #251
gringoloco
A guy with a truck
gringoloco's Avatar
Re: D52 Caliper Rear Disc Brake Brackets
Just be sure it matches your piston- shallow or deep- and you should be good to go. Stock disc/drum combo valve can be gutted for use with disc/disc...
gringoloco is offline   Reply With Quote
Old 08-22-2012, 10:08 PM   #252
CSoliz
Torn between 66 and 78
CSoliz's Avatar
Cool. I was going to pick up the prop valve you have suggested. Thanks for all the help Capt. I will be ordering real soon, probably within the next week.
CSoliz is offline   Reply With Quote
Old 08-27-2012, 03:59 PM   #253
gringoloco
A guy with a truck
gringoloco's Avatar
Received my brackets the other day--they look great! Well packaged and BEEFY. Gonna look great in satin black powder.
Thanks again!
Also, if anyone is looking for a set of rotors for this swap, I have some for sale cheap here:
LA Premium Rotors for CaptainFab D52 Rear Discs
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
Old 08-27-2012, 10:13 PM   #254
Captainfab
60-66 Nut
That's a smokin' deal on those rotors.......
Thanks again!
Old 09-13-2012, 10:18 PM   #255
MyC-Dime
Hey Capt, Would it be possible to use a line-loc unit as a parking brake with the either caliper? I would think you could, any thoughts..
MyC-Dime is offline   Reply With Quote
Old 09-13-2012, 11:08 PM   #256
Captainfab
60-66 Nut
Using a line lock or a Mico lock has been done many times. It does work but it is not legal in those states that require an e-brake. It has to be a mechanical e-brake to be legal.
Old 10-10-2012, 06:35 PM   #257
Mb72build
Mb72build is offline   Reply With Quote
Old 10-10-2012, 06:36 PM   #258
Mb72build
How about a complete drum to disc conversion kit for my 72 c10 rears? Got em? Price? Thanks
Old 10-11-2012, 12:17 AM   #259
Captainfab
60-66 Nut
I have never sold a complete conversion, just the brackets. It just seems pointless to be to pay the shipping on the rotors and calipers, etc. which are heavy, when you can just take the parts list down to your local auto parts store and pick them up.
Old 10-21-2012, 09:05 PM   #260
Slammed '87
Slammed '87's Avatar
just found this thread, read it all, yeah imma need a set of these bad boys!
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough!
Slammed '87 is offline   Reply With Quote
Old 10-21-2012, 11:21 PM   #261
Captainfab
60-66 Nut
PM sent.....
Old 10-26-2012, 02:47 PM   #262
bigchopz
bigchopz's Avatar
capt I'm running 15" ralley rims 15x10 4.5 backspacing will your bracket work for me.
1983 Chevy C10 Brown Bomber
1991 Chevy Astro V8
2006 Cadillac STS Need I said more
1998 Suzuki Gxsr Stetch & Low
bigchopz is offline   Reply With Quote
Old 10-26-2012, 03:33 PM   #263
Captainfab
60-66 Nut
The 15 x 8 Ralley wheels will fit, so I would assume that your 15 x 10's would also.
Old 11-22-2012, 11:23 AM   #264
Rider79
Do these fit a 79 c10 10 bolt ?
Rider79 is offline   Reply With Quote
Old 11-23-2012, 12:35 AM   #265
Captainfab
60-66 Nut
Yes, these will fit all truck 12 bolts from '64-'82 and the truck 10 bolts from '80-'87
Old 11-28-2012, 02:58 PM   #266
Gooker928
Do you make plates for a 63 c10 5 lug conversion?
Gooker928 is offline   Reply With Quote
Old 11-28-2012, 11:44 PM   #267
Captainfab
60-66 Nut
Any of my 3, 5 lug rear disc brake brackets will work with the 5 lug conversions on the original 6 lug differentials. However if your '63 has the original 12 bolt, they will not work for you. This is because the '63 12 bolts have pressed on backing plates. Therefore there is not a flange welded to the axle tube that the backing plate bolts to. The best option for disc brakes on a '63 12 bolt will be a weld on caliper bracket.
Old 11-29-2012, 06:12 PM   #268
Gooker928
Sorry I forgot prices were on first page of thread.
I want to send a money order.
Can you send me the info on where to send?
Old 11-29-2012, 11:23 PM   #269
Captainfab
60-66 Nut
PM coming your way......
Old 12-12-2012, 10:22 PM   #270
1972BackInBlackC10
1972BackInBlackC10's Avatar
just out of curiosity i dont know anything about the cadillacs but if the rear calipers work would the rotors not work as well since they should be the same thickness as the astro rotors or would there be a back space issue since its a car? what about the master cylinder as well since it should be a disc/disc setup
sorry not trying to pick your brain just trying to see if theres more options
1972BackInBlackC10 is offline   Reply With Quote
Old 12-13-2012, 12:16 AM   #271
Captainfab
60-66 Nut
Yes the Eldorado rotors could have been used when designing these brackets, but I was wanting to use a rotor that could be found in a wrecking yard. The Astro/Safari vans are fairly plentiful in the wrecking yards. The '76-'79 Eldorado's are not. I know that new rotors are not that expensive, but sometimes a guy needs to be resourceful. Also the long term availability of the Eldorado rotors may be hard to predict. The Astro/Safari rotors are slightly larger in diameter than the Eldorado rotors.
The Eldorado master cylinder should work just fine with most GM boosters. If you happen to find an Eldorado in a wrecking yard, grab the proportioning valve also.
Old 12-13-2012, 09:32 PM   #272
Greywolf200
I picked up all the Eldo parts at PullAPart but have been holding off because I want to retain my 6-bolt pattern. A bore and sleeve at White Horse and they'll be better than new.
Jack Byrd
'70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4
'76 Airstream Argosy MH(want a longer one), 454CID, TH400
Greywolf200 is offline   Reply With Quote
Old 12-14-2012, 04:35 PM   #273
True 67
captanifab,
Are these still avalaiable?
True
True 67 is offline   Reply With Quote
Old 12-14-2012, 11:34 PM   #274
Captainfab
60-66 Nut
Yes they are......in fact I just got another order of laser and plasma cut parts for them earlier this week.
Originally Posted by True 67 View Post
captanifab,
True
Old 12-15-2012, 06:52 PM   #275
gringoloco
A guy with a truck
gringoloco's Avatar
Was there ever a solution to the pad rubbing the rotor hat issue? Mine are scoring pretty hard...
-Chris
