Old 08-20-2016, 09:49 PM   #251
murd969
Re: 56 Chev Garage build
Good looking build. I like the work you're doing.
1956 Chevy 3100 C4 Suspension Build
Instagram: murd969
murd969 is offline   Reply With Quote
Old 08-23-2016, 09:15 PM   #252
Rude Dude
Rude Dude's Avatar
Cut some material off the front cross member were the motors mounts attached so that rack and pinion clears when installed, will box it in tomorrow.
Rude Dude is offline   Reply With Quote
Old 08-24-2016, 10:04 PM   #253
Rude Dude
Rude Dude's Avatar
Capped the trim out frame almost ready for body filler
Old 08-25-2016, 11:09 AM   #254
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-27-2016, 01:44 PM   #255
Rude Dude
Rude Dude's Avatar
Had some scrape steel decided to make some motor mounts the yellow steel is 1/4 plate the supports are 3/16 and tube is 7/8 od. I made the same mounts that I used on the 56 truck and built some for my neighbor he is been running it for almost 12 years now.
Old 08-27-2016, 01:50 PM   #256
Rude Dude
Rude Dude's Avatar
Now the welding starts made the mounts a bit long for future trimming
Old 08-29-2016, 08:32 PM   #257
Rude Dude
Rude Dude's Avatar
Here is a pic of the mount I built for the 56 small window
Old 08-29-2016, 08:41 PM   #258
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice mounts!
ChuckDriver is offline   Reply With Quote
Old 09-13-2016, 06:14 PM   #259
Rude Dude
Rude Dude's Avatar
Moved the last rear cross member back to get a better fuel tank selection option and repainted the frame with rustoleum hammer black paint. I like this stuff after it cures in this hot sun in Arizona it like powder coating. The frame still needs paint touch up on opposite side waiting for it to dry top side then I will flip it over.
Old 09-13-2016, 09:33 PM   #260
Baldeagle SR
Rude dude I used a tank for a 55 chevy coupe. This might help http://67-72chevytrucks.com/vboard/s...d.php?t=576185 . Frame looks real nice. Rich
Baldeagle SR is offline   Reply With Quote
Old 09-13-2016, 10:34 PM   #261
Rude Dude
Rude Dude's Avatar
Thank you for the suggestion I appreciate it!
Old 09-14-2016, 08:06 AM   #262
Kim57
Kim57's Avatar
Frame looks good.
I used the same paint on mine.
Kim
My build thread
Old 09-14-2016, 12:42 PM   #263
ptc
ptc's Avatar
Rudy, frame looks great! Does the hammer finish still look hammered after applying it with a brush? or did you spray it?
Nice job!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 09-14-2016, 02:59 PM   #264
Rude Dude
Rude Dude's Avatar
The first time I painted it I used a small foam roller laid pretty good, after I welded the cross member in I used cheapo brushes from home depot really didn't see a difference. If you cant decide use the small roller doesn't leave brush bristle in paint. I used two quarts first time this time I only use one quart and it still has the hammer look to it. What I like it is cheap on the wallet and I can always touch it up unlike powder coating.
Nice job!
Old 09-14-2016, 03:27 PM   #265
ChuckDriver
That looks very nice!
Old 09-14-2016, 05:25 PM   #266
slammed57
slammed57's Avatar
coming out nicely...keep weldin her up
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 09-14-2016, 07:43 PM   #267
Dan in Pasadena
Dan in Pasadena's Avatar
Rudy, all,
Here's a couple photos of what I've done with Rustoleum Hammer finish paint. I opened up the entire back of my little 18x18 garage and installed a structural steel frame in place of the back wall. The wide flange beam I found on Craigslist and was an oddball forest green but badly scratched up. I did NOTHING, nada, zilch, zero in prep. I rolled it on with a .79 cent foam roller from Home Cheapo. I messed up because you're supposed to recoat (if you're going to) within I think two or four hours. I forgot and the label says if you don't do it in that time to wait like 7 days or something. So I waited. This stuff is HARD when it's cured. Two coats like I did it is ridiculously hard and uniform. Been on there 4-5 years now and has been bullet proof.
Closeup of the texture:
Obviously that is the silver hammer finish. Since I had good luck with it I decided to try the black but in their spray can. I don't think it's truly black; it's more like dark gray to me. I found a little stool standing out with someone's trash. I did a relatively quick buzz with my palm sander and later put an eBay old fashioned gasoline sticker on it. This was going to be in my garage but my wife actually liked it! And it's in our living room, God knows why but it is.
Before (Yes, very crappy looking):
After:
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 09-15-2016, 08:02 AM   #268
Rude Dude
Rude Dude's Avatar
Dan the frame was already painted over a year and a half, I just repainted it cause I welded the mustang 2 cross member. It has been outdoors and held up real good and matched good way cheaper than powder coating.
Originally Posted by Dan in Pasadena View Post
Rudy, all,
After:
Old 09-18-2016, 09:20 PM   #269
Rude Dude
Rude Dude's Avatar
Mated cab to frame and installed the rear end. I slide the frame from the bottom up not to bad it worked.
Old 09-26-2016, 09:15 PM   #270
Rude Dude
Rude Dude's Avatar
Welded vent area patch it was damaged push in 1/2 inch and rusted at the bottom.
Old 09-26-2016, 09:31 PM   #271
Kim57
Kim57's Avatar
Repair looks good.
Kim
My build thread
Old 09-26-2016, 09:34 PM   #272
Rude Dude
Rude Dude's Avatar
Thanks Kim, still needs finish grinding
Originally Posted by Kim57 View Post
Repair looks good.
Kim
Old 09-29-2016, 06:38 PM   #273
Rude Dude
Rude Dude's Avatar
Passenger side complete on repairing cab vent
Old 09-29-2016, 10:30 PM   #274
Kim57
Kim57's Avatar
That came out real nice.
Kim
My build thread
Old 10-06-2016, 10:13 AM   #275
ptc
ptc's Avatar
Looks good Rudy - you keeping the vents operational? or did you cut all that junk out? if you need some side panels and vent covers I have a complete set thats not in too bad a condition.
