07-16-2011, 11:33 PM | #251 |
Still plays with trucks
Re: Bolt in steering rack
Great product. Thank you very much for putting the money and effort into producing it.
I have run rod ends on the street for years in trailing arms, panhard bars, A-arms & Cal-Trac bars. The best thing you can do is put on a set of grease seals even with a teflon or kevlar lined rod end that doesn't need greased. It will keep the water & road grime out of the rod end and make them last longer. I have used this product and liked them. http://www.sealsit.com/rodend.asp Pretty inexpensive too.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
07-17-2011, 06:41 PM | #252 |
Thanks for the reply Rob... hope you had a good time, cant wait to get my rack!!
8.1l 496 4l80e |
07-18-2011, 03:35 PM | #253 |
Rob,
Can you please give an opinion on your R & P fitting with Porterbuilt lower control arms and swaybar.
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler 1968 Chevy c10 shorty Stepper (Patina LS project) 1967 gmc custom Long Box (Farm Truck Project) |
07-18-2011, 03:57 PM | #254 |
The arm is OK, I'm not sure about the sway bar. Our rack kit puts the tie rod end under the spindle, so you may need to call Nateon this one.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
07-18-2011, 08:03 PM | #255 | |
07-20-2011, 02:17 PM | #256 |
What kind of rack is used? How available are replacement parts such as inner tre's and boots? Looks like a great addition, definitely getting the wheels turning...
Check out my build thread for my '63: http://67-72chevytrucks.com/vboard/s...49#post4806049 |
07-20-2011, 03:37 PM | #257 |
It is a US manufactured rack. No problems with replacement parts or service parts. The Tie rod ends are available all over. So long term maintanance is a non issue. thanks for the interest.
07-20-2011, 04:53 PM | #258 | |
They seal even better and protect the whole thing, not just the bearing area. http://www.sealsit.com/rodendboots.asp
07-26-2011, 03:28 PM | #259 |
UPDATE Well, we're a bit behing schedule, but we are making good progress. We decided to make a change to the rack mounting, using a machined billit mount instead of a strap clamp. Thats the goos news, the bad news is we have to make them, and have a urathane isolator custom made. Thats the bad news. The isolators will take another two weeks, we just got a first article sample, and it's good, so now we just have to wait. The best part is, we aren't going to raise the price because of this. We did it for safety, and to make the install easier. So, if you have one on order, be patient, give it a few more weeks. Thanks.
07-29-2011, 08:38 PM | #260 |
Rob, what led to the change? Did an issue present in one of the test trucks?
07-30-2011, 04:30 PM | #261 |
Not really. We just got back from a 20 road trip back to Des Moines and Columbus, and we stopped in at 19 shops. I always look to see what tools are being used, and how things are done at shops when we stop in. The first thing I always notice is the instructions, mostly still folded up in the box. Another thing that got my attention was the popularity of 3/8 drive air impacts, and battery/electric impacts. Now, I have these tools, but I don't use them a whole lot on assembly. So, all the way home I thought about this. The strap clamps on the rack are to be torqued to 40 in/lbs. (not very much), and if over torqued, can compress the slide bushing in the rack. The more I thought about it, the more that the posibility of a problem seamed too high. So, I wanted to solve the problem, before there was one. None of the test trucks have had an issue, but we were schooled by our rack builder on the internal workings of these racks, and what we could, and could not do. This seams to be the right thing to do. Steering performance is the same, but the posibilty of any problems is reduced. We think thats worth a few weeks lead time.
07-30-2011, 07:38 PM | #262 |
Good idea to make it more fool proof. It will be worth the little extra wait to get a better designed clamping system that will prevent accidental damage to the rack.
08-27-2011, 11:00 AM | #263 |
Hows the progress coming on the racks Rob?
08-27-2011, 11:03 AM | #264 |
8.1l 496 4l80e |
08-28-2011, 06:41 PM | #265 |
We are waiting on the last puzzle piece, the rubber isolator for the billit clamp. We are expecting these this coming week. Had to have them made. We have 25 kits ready to go as soon as the isolators show up.
08-28-2011, 07:18 PM | #266 |
Excellent cant wait I feel like a little kid waiting for christmas!
8.1l 496 4l80e |
10-11-2011, 12:29 PM | #267 |
alright all you guys that purchased let us know how this upgrade is. I still want to move to the rack and pinion but budget has been tight. Let us know your initial thoughts from the driving standpoint.
Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
10-11-2011, 11:06 PM | #268 |
so Rob hows the progress comming on the racks i have one preordered looking forward to getting it an by the way i receved the panhand bar fit well but had to cut a spacer for to fill the gab between the c-notch an frame. i have a cnc lazar so the spacer was no problem but something you might concider for all the bolt on guys.
10-12-2011, 03:38 PM | #269 |
DON'T SHOOT !!!! I know I'm behind on shipping these out. We are really trying to send them out 100%, so that everyone is really happy. No limit has a reputation of sending out 'poor' instructions, I know it, so we're just finishing up the final details. We are including fitting specs, pressure specs, bolt torque specs, warrantee service info, ...... . It's all in the details.
10-12-2011, 03:41 PM | #270 | |
10-26-2011, 09:27 PM | #271 |
Rob,
any updates on the kits Thanks Dillon
________________________________ 1972 SWB stepside pro tour build thread http://67-72chevytrucks.com/vboard/s...d.php?t=452840 |
10-28-2011, 01:43 PM | #272 |
FINALY We are boxing today, shipping today and monday. Thanks for waiting. BTW, introductory pricing is now over. Congrats to those who got a great deal.
10-28-2011, 03:23 PM | #273 |
A guy with a truck
Yay and boo. Ready to hear some feedback on the kits from members, but sorry I missed out on the deal...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-28-2011, 05:45 PM | #274 |
Garage wrench
x2
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
10-28-2011, 06:33 PM | #275 |
Truck and auto performance nut
x3
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
