Old 05-09-2011, 06:19 PM   #251
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: How to: Ruin a perfectly good C10
Gringoloco,... I have a repair panel for the "visor area" of your cab, that I don't need,... if you are interested.
Like this one:
http://www.topbananaparts.com/servle...y-inner/Detail
Keith
Convert to disc brakes.
Old 05-09-2011, 09:11 PM   #252
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Ouch, Gotta hate those hidden gremlins!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 05-09-2011, 11:27 PM   #253
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by VA72C10 View Post
Gotta love hidden surprises....and STUPID PO's
Wheeeeeee!!! Actually, it's not too bad- I've definitely seen worse- it's just that it was so easily preventable...
Originally Posted by RatRod68 View Post
damn man. Sorry to hear that
Meh, no biggie. I knew the visor rust was there and had a good idea there would be some surprises behind the windshield gasket.
Like this one:
Thanks for the offer I have had one sitting here for a few years waiting to be installed. Finally got around to it today...
Yup- just glad it wasn't worse
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-09-2011, 11:47 PM   #254
gringoloco
A guy with a truck
gringoloco's Avatar
Well, after removing the offending metal and cleaning up any signs of any sort of rust, then liberally coating it with rust inhibitor, I set to work on trimming the patch panel to fit. This little project is anti-fun. Between working overhead and the compound curvature of the area, it becomes an extreme pain to install the patch. After MUCH trimming, fitting, trimming, fitting, trimming, and fitting, I finally got it tacked-in place and looking decent. Did I mention, "what a pain"? I have to give kudos to Tri-Plus on the patch panel- it is a quality piece- the perfect shape with plenty of extra to trim for fit, and heavier gauge metal than stock
-Chris
Old 05-10-2011, 12:40 AM   #255
lolife99
lolife99's Avatar
Man,... you do good work!
Keith
Old 05-10-2011, 12:45 AM   #256
VA72C10
VA72C10
VA72C10's Avatar
very nicely done!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-10-2011, 09:43 AM   #257
gringoloco
A guy with a truck
gringoloco's Avatar
very nicely done!!!
Thanks fellas! It's not perfect, but waaay better than before...
-Chris
Old 05-10-2011, 11:13 AM   #258
mcbassin
Still Learning
mcbassin's Avatar
Wow! nice work on the rust repair! I love the PO conversation. No matter what year model bed they change it too, the original always looks better. Not a fan of interchanging beds unless it's 67-72. It's hard to believe that some shops do the things they do.
mcbassin is offline   Reply With Quote
Old 05-10-2011, 12:06 PM   #259
Slick67
Sofa King Crazy!!
Slick67's Avatar
^^ x2
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 05-10-2011, 02:29 PM   #260
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by Slick67 View Post
^^ x2
Thanks guys You should see the 'seam sealer' they used. I can't tell you how much blue silicone gasket maker I've dug out of nooks and crannies on this truck- they went crazy with it!
-Chris
Old 05-10-2011, 10:23 PM   #261
gringoloco
A guy with a truck
gringoloco's Avatar
Today I managed to get a patch cut, formed, and welded in for the gaping hole in the windshield frame. Once this was in, I applied liberal amounts of seam sealer to the four windshield seams, as well as a few other areas that were in need of some sealant. Also finished welding the visor area patch (you can clearly see the relief cut I had to make to get the curves to align properly), spent a BUNCH of time grinding it smooth, then applied some epoxy primer. A skim coat of filler and it will be ready for some color
-Chris
Old 05-10-2011, 10:53 PM   #262
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Impressive - and quick too. An average body man would have milked that for a few weeks.
Zoomin is offline   Reply With Quote
Old 05-10-2011, 10:54 PM   #263
LONG 2B LOW
LONG 2B LOW's Avatar
Wow! I have the same harbor freight gun and I could not get it to lay down that good as a matter of fact it ruined all my previous prep work!! Congrats on the success, what brand of paint are you using? Do you have any painting advice? I'm in the middle of rebuilding my 99 silverado after I rolled it and all that's left is paint.
Liking the build though it looks great keep up the good work
LONG 2B LOW is offline   Reply With Quote
Old 05-10-2011, 11:19 PM   #264
gringoloco
A guy with a truck
gringoloco's Avatar
Haha- no doubt- and charged out the wazoo! I was thinking today as I was grinding my welds that it would take a LOT of money for me to do this to someone else's truck... Thanks for the positive comments
I am using Hot Rod Flatz from TCPGlobal. It is a single stage urethane. I have read where guys have a hard time getting this gun to lay clear. I did very little for gun set-up other than tweak the pattern and volume a little; it does seem to like a little more inlet pressure than other HVLP guns- around 50 psi. Also, try thinning if your paint is thick- my poly primer was spraying a little dry due to the viscosity (a bigger tip would likely fix this), but the color lays out like a dream. Good luck with your rebuild...
-Chris
Old 05-11-2011, 09:24 AM   #265
Slick67
Sofa King Crazy!!
Slick67's Avatar
That really came out great!
Old 05-11-2011, 10:25 AM   #266
Bennett68C10
Bennett68C10's Avatar
Wow, nice job looks great
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-11-2011, 11:44 AM   #267
dougminton
dougminton's Avatar
Much nicer looking now.
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 05-11-2011, 04:57 PM   #268
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks all! I'll be much happier when it's all blue again, but with NO rust, which should be soon...
-Chris
Old 05-11-2011, 09:17 PM   #269
steppside69
steppside69's Avatar
Just read through your build, SWEEEEEEEEEET!!!!!!!!!!!
I hope i can ruin my truck half as nice.
Eric
69 chevy stepside (project)
2006 Silverado Z71 Ext. cab
2005 Saturn VUE (wifes dd)
steppside69 is offline   Reply With Quote
Old 05-12-2011, 12:34 AM   #270
gringoloco
A guy with a truck
gringoloco's Avatar
Eric
Thanks! Good luck with yours
-Chris
Old 05-12-2011, 12:49 AM   #271
gringoloco
A guy with a truck
gringoloco's Avatar
So, the day started out not so great, as the epoxy primer I shot yesterday decided not to cure. Instead of being a nice, hard surface to start body work on, I had a gummy mess. I spent the better part of the morning cleaning that up and making a run to the paint store. Once that was out of the way, I started the body work on the visor area, and got it in a coat of poly primer for final wet-sanding before color...
While I was waiting for primer to dry, I got the bedside braces in- they had to be dropped the same amount as the 'body lift'- don't worry, I'll clean them up and paint them... I also used the extra body filler and primer from the visor area to do a little work on the bedside splice. It will require a little more work before paint, but is most of the way there
-Chris
Old 05-12-2011, 01:06 AM   #272
gringoloco
A guy with a truck
gringoloco's Avatar
...and since the visor area was ready for paint, I decided to go ahead and shoot it The blue I had mixed is juuuuuust slightly different than the color that was on the truck, but since it's inside and will not see sunlight, I don't think it will matter too much. I did my best to blend it- heck, I'm probably the only one that will be able to tell anyway...
Also got the clear sprayed. It did not lay down perfectly, partly due to shooting upside-down, mostly due to me being in a hurry, but that's ok, as it matches the rest of the orange peel
-Chris
Old 05-12-2011, 08:14 AM   #273
legendary
legendary's Avatar
Awesome
This encourages me to go get started on my build....which is in the garage looking at me right now
Best Regards,
Leon
1970 C/10 LWB Cummins Turbo - Build in Progress
Many other toys as well...
legendary is offline   Reply With Quote
Old 05-12-2011, 09:15 AM   #274
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by legendary View Post
Awesome
Glad I can be of help, so get to it! I'm about to...
-Chris
Old 05-12-2011, 10:33 AM   #275
67cheby
67cheby
67cheby's Avatar
HOLY SMOKES.....your going so fast your making me DIZZY !!
67cheby is offline   Reply With Quote
