Old 06-11-2012, 02:16 PM   #251
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Re: slamburban
glad to hear the rocovery is better than expected, still a shame about the truck but like mentionede before could been a lot worse for you and the burb, steel can be repaired
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 07-06-2012, 10:35 PM   #252
fredscarryall
fredscarryall's Avatar
Re: slamburban
the body shop told me it would be a month. they werent kidding.i think this is the first bodyshop i have ever used that stayed true to the finish date. should get it next week. then it goes back to charleys drop shop to get the garbage airbagit.com air ride system removed.i descided to switch to the ride tech system.then he will fab up sway bars front and rear
fredscarryall is offline   Reply With Quote
Old 07-06-2012, 11:09 PM   #253
jmedero
jmedero's Avatar
Re: slamburban
Glad to see your doing better man. Truck is looking
Good. Good call on the better air ride system.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 07-06-2012, 11:27 PM   #254
oldman3
oldman3's Avatar
Re: slamburban
Glad to see it coming together for you....Jim
oldman3 is offline   Reply With Quote
Old 07-07-2012, 02:44 PM   #255
xpickup
xpickup's Avatar
Re: slamburban
Glad you are doing better and the truck is getting fixed. I bought the 3 point belts for my panel after taking your advice on what you said about the 2 point belts up front.
Shannon
xpickup is offline   Reply With Quote
Old 07-07-2012, 11:13 PM   #256
fredscarryall
Re: slamburban
i hope alot more people convert to 3 point seat belts. i was really suprised that hitting someone at 35 mph made my arms useless, like wet noodles.
Old 07-08-2012, 12:40 AM   #257
OrrieG
OrrieG's Avatar
Re: slamburban
Glad to see progress on the truck and hope your are healing well. Since your accident my daughter and granddaughter were in one similar, but not as bad. Stopped at a light go hit from behind, pushed into the car stopped in front orher, then bounced back into first one that hit her again. One in back was going 20, did not hit the brakes. Much to our surprise the air bags did not deploy and I drove the Kia home. Her and daughter were wearing 3 point belts, but both sustained neck, shoulder, back and arm injuries that kept them out of work and going to doctors for 3 weeks now. Just wanted to share, most accidents occur under 20 mph.
OrrieG is offline   Reply With Quote
Old 07-08-2012, 10:59 AM   #258
mknittle
mknittle's Avatar
Re: slamburban
yeah, and the things people do while driving is scary.I was a truck driver and saw a lot.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-08-2012, 09:03 PM   #259
ET56
ET56's Avatar
Re: slamburban
So glad you are doing good. This is a great project to follow along on. I was wondering what engine pulley system you are using(year and model) it looks like it would work great on my 56 for what I want to to. Thanks for any info you have.
56 Chevy Pickup, 66 Corvette
ET56 is offline   Reply With Quote
Old 07-09-2012, 05:11 PM   #260
99 to Life
99 to Life's Avatar
Re: slamburban
So glad to see this thing back on track. So was it better to have others do it and have it paid for, or do you think it would have been better to take the cash and do it yourself? Just curious. I hope your health is doing better too.
I'm just curious on how they value this stuff, did they get you aftermarket fenders etc? What insurance covered you?
can't wait to see this beauty back on the road.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 07-09-2012, 05:46 PM   #261
tantrumpipeline
Re: slamburban
glad to hear you're doing better and the trucks being repaired, this build really created a desire for one of these rigs one day
20 Duramax tow pig
52 short project
Old 07-10-2012, 01:30 AM   #262
fredscarryall
Re: slamburban
i got the serpentine system off a 1993 caprice classic for $125 from a wrecking yard. when you get one make sure you get everything including the water pump (because its a reverse flow) make sure you also know the fan blade is reverse but still pulls air in the right direction so get that. get the smog pump,a/c pump and alternator(because it a 4 year design only),power steering pump and lines.if you want to pull the power steering pulley you will need a special puller you can get at harbor freight because you cant get to the powersteering pump off till you remove the pulley. just to let you know all the bolts are metric and i used american bolts to bolt it to the block. you will need to buy a smog pump bypass pulley at summit for $30, if you dont want a/c summit also makes a a/c bypass pulley for $30.if you want a/c vintage air makes a bracket to convert the ugle R4 compessor to a sanden 508 for $60. here are some pictures of the bypass pulleys. its alot of work and will cost you a few hundred to get it to work. hope this helps you descide if its right for you.
Old 07-10-2012, 01:51 AM   #263
fredscarryall
Re: slamburban
as far as damage its come to $21,000 so far. just 40 hours alone went into replacing the side cowl, pulling the cowl out on the frame rack, repairing the sheet metal and repainting the firewall.but,i had know way of pulling the cowl myself.i could have saved myself about $2000 if i did the rest myself,but it would have taken me about 6 more months to finish it. my wife told me to take care of myself, recover from the accident and left someone else do the work.
Old 07-10-2012, 10:39 AM   #264
ET56
ET56's Avatar
Re: slamburban
Thanks for the reply on the pully system. This just might work for me. Take care.
Old 07-17-2012, 09:33 PM   #265
fredscarryall
Re: slamburban
i got the suburban back and put about 40 miles on it. decided to go with a chrome latch plate and installed a polished a/c compressor
Old 07-17-2012, 09:43 PM   #266
xpickup
xpickup's Avatar
Re: slamburban
fredscarryall, looks great and glad it is fixed again. I also hope you are recovering well.
Shannon
Old 07-17-2012, 09:54 PM   #267
fredscarryall
Re: slamburban
i also got some 3 point seat belts from brother truck parts.they where for the 47 to 54 trucks but installed just fine.i had a local saftey company put them in. it took them 4 hours to install all 4 and they said it was real easy.they are kinda expensive but i diffently recommend them if your going to install 3 points.the instuctions are easy to understand and it come with all the mounting hardware.they even have a youtube video on how to install them
Old 07-17-2012, 09:57 PM   #268
fredscarryall
Re: slamburban
tomorrow i going to have my electric exhaust kick outs installed.
Old 07-17-2012, 10:03 PM   #269
99 to Life
99 to Life's Avatar
Re: slamburban
21k goood gracious I'm sure your insurance company was pissed. So glad it is back to normal. Looks great.
Old 07-17-2012, 10:05 PM   #270
parkwood
parkwood's Avatar
Re: slamburban
So glad to see you are back on the road, both with your health and with the suburban.. It looks great..
parkwood is offline   Reply With Quote
Old 07-18-2012, 12:18 AM   #271
OrrieG
OrrieG's Avatar
Re: slamburban
Yeah and that does not include the medical bills, continued care for who knows how long, possibly loss of income depending on the situation. Expensive indeed but if you ever need it the premium costs start to look pretty inexpensive. Good to see the truck back in the stable and the upgrades.
Old 07-18-2012, 10:54 PM   #272
fredscarryall
Re: slamburban
had the exhaust kickouts welded in today. one of the next projects is making the oil pan a little shorter.tomorrow i'm putting in the radio
Old 07-26-2012, 12:01 PM   #273
STOUTE
Re: slamburban
Man just read every page very nice bulid. and sorry to see the damange
STOUTE is offline   Reply With Quote
Old 07-26-2012, 12:23 PM   #274
Ratpin
Ratpin's Avatar
Re: slamburban
Man, I just saw this about the accident. That is scary stuff. If nothing else I think your unfortunate experience has raised the awareness for the necessity of adequate safety restraints. Question though, Is there any added reinforcement there where the 3rd point of the seatbelt attaches to the roof? I would be worried it would just rip out if it's only mounted to sheet metal.
Let me know if you ever need any help with anything. I'm pretty local and would live to check out your burb sometime.
Ratpin is offline   Reply With Quote
Old 07-26-2012, 01:56 PM   #275
tantrumpipeline
Re: slamburban
Glad to see it back in action and looking sweet!! some pretty trick handy work for sure
20 Duramax tow pig
52 short project
