Old 10-26-2012, 09:39 PM   #251
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: How about some pics of Static Dropped C-10's
Originally Posted by MDc10 View Post
I understand that, but im new to bags. I need to lower the truck first right? As far as the crossmember, do I put bags on first then work my way down from there? Just trying to find my starting point.
Thanks, Mike
Bags are just an air spring.
If you want to lay frame,... you have to start that plan from the beginning.
Otherwise you will be spending your money twice.
If you want it low,... I would do a 5/7 static drop.
Laying frame will put you in a completely different price range.
What is your budget?
Keith
Convert to disc brakes.
Old 10-26-2012, 09:43 PM   #252
lolife99
lolife99's Avatar
MDc10,... if you want to lay frame,... look at these threads.
They will show you the amount of work and money it takes to get these 73-87 trucks on the ground.
http://www.porterbuiltfabrication.co...2-73-87-Trucks
Keith
Old 10-29-2012, 08:41 PM   #253
MalibuVLX
Who ever lowered it heated the springs and bent them. Has anyone seen this, or done this? I know it makes for a rough ride.
I would guess this is the same person who takes the torch and heats the front coil sprins til it sits as low as he wants, but comes back later after things cool to see it is 2" lower than he wanted.
MalibuVLX is offline   Reply With Quote
Old 10-29-2012, 09:05 PM   #254
RustyBillet
Wow, that is scary... I've never seen that done to springs before.
RustyBillet is offline   Reply With Quote
Old 10-30-2012, 10:48 AM   #255
big_al_71
big_al_71's Avatar
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-04-2012, 04:51 PM   #256
1971sierragrande
1971sierragrande's Avatar
MDc10,We just put a shackle, hanger kit on my buddys 80' and it had the rear of the spring done the same way. Dangerous!!!! replaced the springs and it rides great now.
1971sierragrande is offline   Reply With Quote
Old 11-13-2012, 08:39 PM   #257
fatgump
fatgump's Avatar
5/7 drop or so, 15" rallys
fatgump is offline   Reply With Quote
Old 11-16-2012, 01:52 AM   #258
ivorton74
ivorton74's Avatar
Finally got a new computer so I can post my pics now. Here's my 74 finally lowered. Ebay flip brackets and 2 coils cut. I'm thinkin 4.5/6 drop. Truck is sittin on bump stops. Am goin to get the front bump stops cut off and remove the rears and get some air shocks for the rear. Also needs an alignment...has a slight camber. Runnin on 235/75s and no rubbing at all. Rides a bit bouncy but not too bad.
ivorton74 is offline   Reply With Quote
Old 11-16-2012, 02:03 PM   #259
s11sean11
my 62 almost finished
s11sean11 is offline   Reply With Quote
Old 11-17-2012, 12:34 PM   #260
502ms
502ms's Avatar
This is hot
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 11-17-2012, 02:37 PM   #261
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by 502ms View Post
This is hot
Agreed! I love how slammed the 60s trucks look with their flat wheel openings.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-20-2012, 01:19 PM   #262
statiC10
statiC10's Avatar
About a 6/8 drop on 28" tires.
2000 Camaro SS M6.
'81 C10 6/8 drop.
http://farm9.staticflickr.com/8489/8...41d04a64_z.jpg
statiC10 is offline   Reply With Quote
Old 11-22-2012, 03:25 PM   #263
502ms
502ms's Avatar
Talking Re: How about some pics of Static Dropped C-10's
Yes!
I'm thinking one of these is on my "to get" list
Best Regards,
Leon M.
Old 11-24-2012, 11:25 PM   #264
INSIDIOUS '86
INSIDIOUS '86's Avatar
6-8 drop 3" springs and spindles up front. Rear flip with "2 shacke. With 245/50/16 and 295/50/16.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-25-2012, 01:01 AM   #265
HouldenCaulfield
what are the specs on your 62 Sean11? How did you get it this low?
HouldenCaulfield is offline   Reply With Quote
Old 11-25-2012, 05:48 PM   #266
gearys 5600
gearys 5600's Avatar
COOL truck !!
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 11-29-2012, 02:43 PM   #267
s11sean11
thanks guys and it does not have dropped spindles but the cross member is raised and we kept the torsion bars in the back there is a big notch and air bags but with no compressor or tank heres the build lots of pictures here http://67-72chevytrucks.com/vboard/s...d.php?t=478965
Old 12-06-2012, 10:44 PM   #268
ivorton74
ivorton74's Avatar
sid...are those wheels coys or what are they?
Old 12-07-2012, 10:45 AM   #269
69Villa
69Villa's Avatar
some pics from this SEMA show that just passed idk if bagged or not but they r low
1969 Chevy C10 (Project)
2011 GMC Sierra (Daily)
U.S. Army 91B (wheeled vehicle mechanic )
Finally back from afghanistan
Stationed in Fort Riley Kansas
69Villa is offline   Reply With Quote
Old 12-07-2012, 11:44 AM   #270
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Nice
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 12-07-2012, 12:34 PM   #271
ZUBZ
ZUBZ's Avatar
Originally Posted by RINC View Post
1st Post !
Here is me fathers 71 C-10 with what we believe are 68 front end an bed.
255 60 15 fronts, 275 60 15 rears
Rear frame is notched an the truck rides like a caddy. Far from the ride harsh ride I get from my lowered VW Bus.
Lovely truck and oh so loving the split window. I own a 75 Baywindow, 75 Split window bus (13 window) although they dont regard them as German buses as they were bits and pieces of Brazil and German buses but assembled in South Africa and also a 66 beetle...
ZUBZ - C10 "GUS" - JOHANNESBURG, South Africa
My 1970 C10 Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542560
ZUBZ is offline   Reply With Quote
Old 12-26-2012, 08:44 PM   #272
Low down and dirty
Low down and dirty's Avatar
Here's my 68 .............. 5" drop springs in the rear . not sure about the front. I cut 2 coils off the springs. I have new 3" drop springs from CPP for the front , but haven't got them on yet. I think once I put the new springs up front , it will probably sit higher. Might have to go with new drop spindles to get it back down.
68-Chevy c-10 Short Step
66-Plymouth Sport Fury
00-Chevy silverado 1500
Low down and dirty is offline   Reply With Quote
Old 12-26-2012, 09:28 PM   #273
shawno72
C/10 junkie
shawno72's Avatar
Looks good^^
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-26-2012, 10:54 PM   #274
fastcam1
Young gun
fastcam1's Avatar
^^^^^^I 2nd that!
67 SWB Custom "JANE"
http://67-72chevytrucks.com/vboard/s...d.php?t=554024
Northwest C10's
http://www.facebook.com/#!/groups/Norhtwestc10s/
Cameron sparks
fastcam1 is offline   Reply With Quote
Old 12-31-2012, 10:02 AM   #275
fatgump
fatgump's Avatar
Before and after
