Old 09-30-2011, 05:29 PM   #251
VA72C10
VA72C10
VA72C10's Avatar
Re: Project: "Home Grown"
welded would look cleaner...you could plug weld the bolt holes then weld the edge and grind smooth...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-30-2011, 07:37 PM   #252
PBFAB.COM
PBFAB.COM's Avatar
Originally Posted by creepdogg View Post
Yeah, I will need to replace the Ball Joints, they are brand new but the wrong year for my new Spindles, go figure, I will likely sell em on the board.
The lowers are a pain to press out with that tapered ball joint cup.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-03-2011, 08:26 AM   #253
creepdogg
Any suggestions? I was thinking of maybe heating the control arm?
creepdogg is offline   Reply With Quote
Old 10-03-2011, 11:51 AM   #254
PBFAB.COM
PBFAB.COM's Avatar
I wouldn't heat the arms... might have to make a tapered block to use?
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-03-2011, 12:23 PM   #255
creepdogg
I think we may try an air hammer on it, will likely destroy the ball joint but oh well.
Old 10-03-2011, 05:13 PM   #256
creepdogg
Does anyone know how to tear down these damn arms? I want to get them powder coated a different color but I cant seem to see how to get the shaft out of the arm? I am thinking it was likely pressed in originally?
Old 10-03-2011, 06:11 PM   #257
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Nope, the shafts are threaded on both ends. put the shaft in a big vise and unscrew the ends
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 10-03-2011, 06:14 PM   #258
PBFAB.COM
PBFAB.COM's Avatar
We disassembled a set about a year and a half ago to make delrin bushings for them so they would be compatible with the Dropmember... the bushings are in there pretty tight. They will eventually come out with a lot of effort and even more patience.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-03-2011, 08:48 PM   #259
creepdogg
Did u use a press to get them out? I called thorbros today and the guy said if i could get em apart I likely wouldn't get em back together. This is not want I wanted to hear. I don't want my arms black, although it may work.
Old 10-04-2011, 09:32 AM   #260
creepdogg
Looking at the break down photos of these arms it would seem that all I need to do is press them out one end, remove the bushing and repeat, maybe I should grease them up to get them to slide easier? I wonder if a little heat would help out as well?
Old 10-04-2011, 09:34 AM   #261
creepdogg
What was a good deal is now turning in to a PITA!
Old 10-04-2011, 10:00 AM   #262
67cheby
67cheby
67cheby's Avatar
i would try to cool them rather than heat them, stick them in the freezer for a couple of hours and try it ?? it wont cost anything to try maybe it will work maybe not?
67cheby is offline   Reply With Quote
Old 10-04-2011, 10:39 AM   #263
creepdogg
Hmm, that is a good idea, maybe it will make the poly a little more rigid and will stop it from gripping on the metal. I have a freezer here at work
Old 10-04-2011, 10:46 AM   #264
creepdogg
Or I just leave the damn things black, the cross member will be a charcoal, and so will the spindles, the arms could be black along with the frame. So it will kinda flow decent. Any thoughts?
I just don't want to destroy these arms to only for powder, plus I would save a few bucks not needing to powder them
Old 10-04-2011, 10:50 AM   #265
67cheby
67cheby
67cheby's Avatar
i think that would look fine !!
Old 10-04-2011, 10:55 AM   #266
creepdogg
Lookie what I found today!
http://cgi.ebay.com/ebaymotors/GM-12...#ht_500wt_1182
Wonder what it will go for
Old 10-04-2011, 10:57 AM   #267
creepdogg
Anyone know enough about rear ends, would this work in my rear end, mine is a 70 12 bolt.
http://cgi.ebay.com/ebaymotors/12-Bo...#ht_500wt_1182
Old 10-04-2011, 10:58 AM   #268
Rochlow
Me too.. (leave them black) Sorry to hear that the arms are a PITA.. I didn't realize that they were so difficult to tear down.
Rochlow is offline   Reply With Quote
Old 10-04-2011, 10:59 AM   #269
creepdogg
Not your fault man! I bet I can still get em apart, just don't want to make it a nightmare, besides once inner fenders are installed, who will really notice the arms anyways?
Old 10-04-2011, 11:01 AM   #270
Rochlow
and once they are apart.. How hard will they be to get back together..
Old 10-04-2011, 11:05 AM   #271
PBFAB.COM
PBFAB.COM's Avatar
We didn't care about the bushings or the shafts in our case, as they weren't going to be re-used in our application. It was a bit of work. One of the bushings didn't survive. And we ended up cutting the cross-shaft in pieces on the second arm to save time.
I would recommend to leave them as is, rather than risk damaging something that they aren't "currently" building anymore. Black will flow just fine with the chassis.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-04-2011, 11:07 AM   #272
creepdogg
Yeah, I think it makes most sense, I will rock these until the next itch when I go for a drop member, at that point I will just get your arms, and with the correct wheel centering Now to just get that damn lower ball joint out, but I bet that will be easier! Although still hard.
Old 10-04-2011, 11:12 AM   #273
creepdogg
What is everyone's favorite brand to use for ball-joints? I was thinking of using Moog.
Old 10-04-2011, 11:22 AM   #274
creepdogg
Xmas from UPS today ! CPP Tubular motor mount perches.
Old 10-04-2011, 12:21 PM   #275
gcburdic
Restoration Virgin!
gcburdic's Avatar
TRW is made by Moog as well....check Rockauto.com for deals....there's a 5% discount code available...just google for it
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
