Old 09-12-2011, 01:55 AM   #251
litew8
litew8's Avatar
Re: Rebuild on a shoestring.....continued
Originally Posted by VA72C10 View Post
Kinda thinking of buying both and making a nice lwb, a nice swb, and parting out the rest of it....we'll see how cheap I can get everything
in this economy - lwb for payload is where it's at
I really want to have the joy of restoring a truck from out west one day
Check the Midwest! A lot closer.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 09-12-2011, 09:22 AM   #252
gcburdic
Restoration Virgin!
gcburdic's Avatar
Yeah, but did it have lwb sides cut down and not finish welded
It wouldn't be project if we did everything understood, but truthfully since you have a guy that can weld....heck, you can weld...this could be the perfect time to finish it up!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 09-12-2011, 09:43 AM   #253
68 TT
Still plays with trucks
68 TT's Avatar
I am looking at a swb truck and a lwb locally for different reasons...the swb has a perfect bed on it and the lwb is rust free and has lots of new parts with it. Kinda thinking of buying both and making a nice lwb, a nice swb, and parting out the rest of it....we'll see how cheap I can get everything
Sounds like a good plan. Hope it works out money wise so you can get them both.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-13-2011, 03:38 AM   #254
VA72C10
VA72C10
VA72C10's Avatar
Well, got pics on my comp but need to download them...tried the member gallery and having issues pulling them up after downloading them...and photobucket's not working right now....
I used the twisted wire cup on my grinder to clean up the floor pans. I am going to seam seal it tomorrow if I get time and then once that sets I will primer and paint it with undercoating...
...I got in some parts from CPP and once again have some issues....got a manual tilt column since I'm a big guy and a tilt is nice with the big wheel...and the column in there was a three on the tree with the shifter removed since it's now floor shift...won it on ebay for a really good deal IMHO- 275 shipped but it didn't come with the wiring adapter it was supposed to and has a chip in the powdercoat and scratches (inside the nice packaging so it was like that when they shipped it) I got a nice used power steering shaft and rag joint coming I will paint up and then will install after paint. Also got my power steering pump, power steering gearbox (New one) and power brake booster with the brackets on it dug out of my storage containers.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-13-2011, 03:51 AM   #255
heeroyue2002
fat old dude
heeroyue2002's Avatar
what your a big guy? as in tall right??? from the pix i saw you looked thin!
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 09-13-2011, 03:56 AM   #256
VA72C10
VA72C10
VA72C10's Avatar
what pics did you see
...6'2" and right now I'm at 271....after losing 9lbs over the last week and a half after I put myself on a diet....I will get down to 220...that's my goal weight and I got there before but then ate cheap processed food and junk food after I lost my job....not going to compromise on my health any more...
Old 09-13-2011, 03:59 AM   #257
heeroyue2002
fat old dude
oh really?
i just saw baby pix lol.
in may i lost 30 pounds. im always fat
Old 09-13-2011, 11:58 PM   #258
VA72C10
VA72C10
VA72C10's Avatar
Finally got the pics to work....where it sits now...
big ugly mirror holes welded up and primered
rocker finish ground and primered
wire wheeled passenger floor....still have to get underneath and raise up the floor a bit and I'll be grinding down the welds a bit also...
shifter hole closed up slightly...won't be seen now when shift boot is installed...
Driver's floor wire wheeled
Driver's rocker welded in and primered
He fabricated this piece custom and I think it came out NICELY
Radio removed....nice uncut dash. Going with radio delete...also removed the crumbled dash pad...
Old 09-14-2011, 12:07 AM   #259
VA72C10
VA72C10
VA72C10's Avatar
Here's the rally wheels I might be using as well as some of the remaining patch panels and some very nice door hinges...
Here's using my hood as storage (bucket seat brackets I was painting)
Here's the front view of the REALLY nice 70 grille...too bad the inner is broken in the bottom middle as it is nice otherwise in its' original color. Note that the lines go all the way to the end of the center bar into the headlight bezel area...the way they came from the factory...all repro's and NOS available have that dark black rectangle on either end instead...
BONUS-truck came with good T3 Headlights (I'll remove and sell later and put some nice regular halogens or possibly some newer style assemblies with HID's that I've had for a while but never installed....)
Old 09-14-2011, 12:12 AM   #260
VA72C10
VA72C10
VA72C10's Avatar
Here's the CPP tilt....
looks really nice when first unwrapping...
but...CHIP in the powdercoat
and scratches...
and I knew it came with the wrong style connector but it was supposed to come with a converter in the box to our style but it didn't...
Old 09-14-2011, 12:15 AM   #261
VA72C10
VA72C10
VA72C10's Avatar
We'll see how they take care of it...thankfully it was through ebay and paypal so that will help a little bit.....seems they respond better that way...
Hope to have some time tomorrow to work on it....got a lot going on right now and need to work hard to sell a lot of parts as I haven't had much side work lately...
Old 09-14-2011, 12:24 AM   #262
heeroyue2002
fat old dude
oh i found a couple set of those t3 lights in my garage. are they any good?
Old 09-14-2011, 12:28 AM   #263
VA72C10
VA72C10
VA72C10's Avatar
I've sold a clean, working set for 75 for a pair and I have like 10 other nice halogen sealed beam lights I can choose from
Old 09-14-2011, 12:36 AM   #264
heeroyue2002
fat old dude
oh dang thats tight.
Old 09-14-2011, 11:10 AM   #265
68 TT
68 TT's Avatar
Hope that works out. I ended up having to do a credit card charge back because pay pal couldn't get my money back from a seller who never sent the items he was paid for. So now pay pal thinks I owe them money, yea right.
Old 09-14-2011, 01:39 PM   #266
VA72C10
VA72C10
VA72C10's Avatar
On individual sellers it's not as guaranteed, but with a big ebayer like cpp, they don't want issues so they seem to take care of issues through there fairly quickly....at least that was my experience in the past...had an issue with a steering wheel they took care of fast but when it came to an order I placed directly with them they took a couple months to get the part I needed and only after around 15 phone calls....
Old 09-14-2011, 02:00 PM   #267
68 TT
68 TT's Avatar
That is definitely one big benefit of dealing with a larger company who can't just change their name & bank account and move on to the next victim when they get too much bad feedback.
Hope it doesn't take 15 phone calls to get this issue taken care of.
Old 09-14-2011, 06:29 PM   #268
VA72C10
VA72C10
VA72C10's Avatar
Hopefully not. sent the pictures today after they responded to my message on ebay asking for them...
Old 09-14-2011, 07:41 PM   #269
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
lookin good! Step by step is how we get em done. sorry to here about the tilt troubles. hope it get worked out quickly for you.
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 09-14-2011, 09:32 PM   #270
VA72C10
VA72C10
VA72C10's Avatar
thanks. and it's not the end of the world on the tilt, but I'm definitely not paying good money for something that's damaged when it arrives...(and obviously was damaged before it left their warehouse) because the way it was packaged there was no possible way it was chipped or scratched inside that package...the outer box was perfect, inner box was perfect, main padding was intact, and there was a soft inner packaging around it that was sealed I had to cut open.
Old 09-15-2011, 09:02 AM   #271
XxCHEVYMANxX
Yea, they can't even get away with calling that shelf wear. More like it fell from the shelf. On the plus side, you might have other things to work on untill another one arrives.
John
Facebook LoL
Old 09-15-2011, 12:27 PM   #272
treveiger
treveiger's Avatar
It's really coming along, keep it up!
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 09-15-2011, 02:16 PM   #273
camrycurt
camrycurt's Avatar
Please excuse my ignorance, but what are T3 headlights? Is that a special type of sealed beam bulb?
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 09-15-2011, 02:36 PM   #274
VA72C10
VA72C10
VA72C10's Avatar
They're just an older style sealed beam that's not available for sale any more (although some companies are making reproductions of them but I think they're like 200 for a pair if I remember correctly?) it says T3 in the glass as pictured. There may be more to the story but that's all I know
Old 09-15-2011, 02:38 PM   #275
VA72C10
VA72C10
VA72C10's Avatar
Nope...not gonna get away with "shelf wear" I do have plenty to work on...and not enough time. Column won't go in until after the engine is painted, and engine bay and interior are painted too...so it'll be a while still...
Thanks!
