03-29-2012, 06:23 PM | #251 |
Re: 1967 Chevy CST aka "the loud truck"
do you need 3/4 ton or 1/2ton?
03-29-2012, 06:41 PM | #252 |
Um I guess 3/4 cause I am 8 lug, sorry to sound dumb but what's the difference
Posted via Mobile Device |
03-29-2012, 07:11 PM | #253 |
3/4 ton had about a 7'' diameter on the back and 1/2 ton is about 10'' inches 1/2 ton uses nubs on steel wheels and pushes over those. 3/4 ton has a ring around the back which goes into the hub area of the rim and pushes over 3 or 4 clips. becuase of this ring on 3/4 ton hubcaps, it makes it 7'' inches in diameter and impossible to use for a 1/2 ton rim.
03-29-2012, 08:49 PM | #254 |
Idk what size I got so maybe I can tell in the pics u send
03-31-2012, 01:19 AM | #255 |
ok was actually busy on the 67 today... problems before today: passenger door was hitting the fender right at the lower body line with the trim, sill plates not installed no wire hot wire to the distributor, driver door wasnt adjusted well, door jambs were dirty cab door latch mechanisms were rusty and not painted since 67 so today I:
drilled the three holes in the tin for the tach to screw into cleaned the door jambs and installed new ( not new but ones from my other 67 cab that i cleaned and painted a while ago) cab door latch mechanisms ( for lack of a better term) adjusted the passenger door had to take the passenger door off to adjust the hinges so i sanded the door where the hinges bolt and primered and painted. screwed the sill plates through the new carpet into the floor nicley. installed the plenum valve?? into the cowl sanded primered and painted the fresh air vent for the passenger side. and now time for pictures and less talky talky lol |
03-31-2012, 01:21 AM | #256 |
oh and to add a couple things: 1 yes i am taking the fresh air vent back out to clean the rust off the kick panel lol and 2 i did screw the 2 screws back in to hold the bracket for the A/C... uhh... breather thingy lol
03-31-2012, 05:50 PM | #257 |
Looks good
03-31-2012, 08:56 PM | #258 |
looks very nice so far I will keep an eye on your progress
04-06-2012, 03:29 PM | #259 |
thanks nick and tinkermc! well glad you like it! havent done anything but let her get some sun light and finally have outside time lol
04-07-2012, 12:19 AM | #260 |
Junk Yartist
nice pants
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
04-07-2012, 04:41 PM | #261 |
hehe love star wars still
well i havent done much..... but i did clean the garage and found ( well i found last month and then lost it right away the same day) the older style hazard knob for the column, and installed it before i could lose it again so now my column has everything i want it to. |
04-09-2012, 02:24 AM | #262 |
well i finally figured out what i did wrong to the shifting linkage..... MAN AM I STUPID!!!!!! i put the transmission manual lever on backwards.... so now i put it on right and its shifting beautifully!!!! its perfect! also a buddy of mine races stock cars and stuff so he came by and told me that what wire i have to run to the distributor and how i run it and what gauge wire it should be, so i ran the wire and now i just need to put a battery in and start it up and see if she'll fire up! also started body work on the passenger bed side... fun stuff also got the screws for the sun visor hooks and got the plugs for the 3 point seat belt hole.
04-09-2012, 10:21 AM | #263 |
Junk Yartist
Wait, is that an air pressure gauage next to your oil pressure gauge?
04-09-2012, 05:06 PM | #264 |
you know im not really sure.... the vacuum gauges look-a-like.... but either way its not gonna be used... probably gonna use a 73+ style clock..
04-20-2012, 02:39 AM | #265 |
ok so ive done some things to the 67, i have installed the cigarette lighter/light wire i have cleaned up the wiring and retped the engine harness with new electrical tape. ive gotten the 3 point seat belt plugs for both sides, and ive bent and modified bed braces to work for my fleetside... for some reason i cant ever find wood floor fleet side ones.... so now the passenger bed side is looking way better.. still very $hitty . i have also made a little dude out of some engine parts just for fun just a nice desk ornament
04-20-2012, 11:00 PM | #266 |
Nice! The little dude rocks!
04-28-2012, 02:02 AM | #267 |
thanks newt!!! hey guys whacha think about this dealer emblem on my tailgate? yes or no?
04-28-2012, 04:15 PM | #268 |
Yes! i love those old tags, i got a set from sharpie that i plan to put on my gate
Cam 1972 Chevy C/10 "Custom Cruiser Project" Build Thread 1961 Olds Super 88 (Daily) 1966 Chevy Corvair 500, "Marigold" SOLD 2005 Subaru Outback Wagon DEAD 2008 Pontiac G8, New Winter/Daily |
04-28-2012, 04:45 PM | #269 |
thats 3 yes and 2 no's so far lol. those are cool! they should look good!
04-29-2012, 09:32 AM | #270 | |
You've accomplished alot with your '67 and I love the trim and hubcaps. Keith |
04-29-2012, 10:39 PM | #271 |
thank you lil hoodlum! oh and yes i did look into it... they also still use the little kid in the ball cap for advertisement to! but i didnt know they are the biggest in texas.... thats awesome! well i wet sanded the bed and reprimered it, looks much better! need to throw a black coat on to see how it blends in now.(well actually i just need to get this thing painted.. its probably pretty ugly) and i did accomplish something major...... SHE RUNS!!!! she fired up for me NOOOO problem! still sounds MEAN and LOUD lol. heres some pics!
04-30-2012, 09:35 AM | #272 |
nice work! congrats on the fire up too!
04-30-2012, 11:35 AM | #273 |
thank you cameron! i pleased with the bedside but it still looks bad lol but im proud of it firing up, it didnt hesitate at all. just turned the key for a second and then blup blup blup blup blup! only really loud.
05-04-2012, 01:20 AM | #274 |
well i have some pictures of what i have all done to the 67 latley.
on a side note i have being shipped to me, 75 corvette spark plug wires, so now i can start it up with out having to worry about my spark plugs wires getting fired because there touching the ram horns so i will get those tomorrow morning and install those. and then i should just be that much closer to driving it! so if anyone is wondering what is stopping me still, its: registration and getting a title, the front and rear windows not in and its the exhaust. other then that.... im road worthy. my brakes need a little attention... i honestly dont know really whats up with them.... i think i may need to put teflon tape where they connect to the propeortionung valve.... somewhere somehow its pissing brake fluid on my inner fender and its quite irritating i also checked the oil, its good but it says add a quart, while i was messing with the dipstick i decided to paint the dipstick handle chevy engine orange and the stem semi gloss black... also i installed the A/C canister on the radiator support. enough jibber jabber here are some pics |
05-04-2012, 01:22 AM | #275 |
more
