Old 08-26-2012, 10:12 PM   #251
99 to Life
99 to Life's Avatar
Re: 1948 Chevy / S10
shannon,
yeah I love them taillights. Seen em before on these trucks, def very sleek. Great mod, great metal work. How do they mount? They have some threads on the back or anything? Easy to get to??
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 08-28-2012, 12:42 PM   #252
xpickup
xpickup's Avatar
Chevette, Daze57, mknittle, oldman3, Thank you. Yes, it works well because hole sawing is always a pain. I always like little tricks to make things easier.
99 to Life, Thank you. I will take a picture of the buckets I made. As for the light I will tack a screw in it and the will be a lock nut on the inside of the fender. So it can be removed for changing the bulbs.
Shannon
xpickup is offline   Reply With Quote
Old 08-28-2012, 09:12 PM   #253
xpickup
xpickup's Avatar
99 to Life, here are the light buckets. It starts with 3.5 tubing and then gets a cap welded to the end. The outside holes are the mounting holes and the center hole is where the bulb wires come out. I tack it in the hole and square everything up and mark it with a sharpie marker then break the tack and use my trusty slitter wheel on the 4.5 inch grinder to cut it to the profile of the fender.
Shannon
Old 09-03-2012, 03:47 PM   #254
xpickup
xpickup's Avatar
I finished up the tail lights this weekend. So now I have a bunch of little things I am working on now. I finished the edges on the splash aprons and the radius on the running boards. So they are finished now also. Next is the inside filler piece on the roll pan to the raised bed floor. So keeping with the paneled theme I will panel it too. But that will be this week. I only did a small sample so I could see if my bend and step was right.
Shannon
Old 09-03-2012, 03:48 PM   #255
xpickup
xpickup's Avatar
more
Shannon
Old 09-03-2012, 04:18 PM   #256
seanery
seanery's Avatar
b!tchin' work!!
seanery is offline   Reply With Quote
Old 09-03-2012, 04:28 PM   #257
mknittle
mknittle's Avatar
The running boards look super.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-03-2012, 05:21 PM   #258
oldman3
oldman3's Avatar
That pickup is looking so good, nice work...Jim
oldman3 is offline   Reply With Quote
Old 09-03-2012, 07:23 PM   #259
99 to Life
99 to Life's Avatar
a@@ end is looking sexy
Old 09-04-2012, 10:17 PM   #260
xpickup
xpickup's Avatar
seanery, mknittle, oldman3, 99 to Life, Thank you all. Glad you all like it. I should have more pictures this weekend. I should be starting the inner wheel wells and a forward tilting hood.
Shannon
Old 09-05-2012, 01:11 AM   #261
Daze57
Daze57's Avatar
shannon
you are gettin that truck very dialed in - excellent skills and workmanship.
we have a bunch of very talented guys on this forum and i know we learn from others .
Daze57 is offline   Reply With Quote
Old 09-06-2012, 06:14 PM   #262
xpickup
xpickup's Avatar
Daze57, Thank you. I know I have learned a lot on here and I always willing to share how I do things. That is the great thing about this forum. Great forum and great people on it.
Shannon
Old 09-07-2012, 08:05 AM   #263
Larry Lindley
the golden hammer has struck again,very good work.
Larry Lindley is offline   Reply With Quote
Old 09-07-2012, 05:11 PM   #264
xpickup
xpickup's Avatar
Larry Lindley, Thank you. I do like my special golden hammer. Haha
I had off today so I worked in the garage for 5 hrs. I now have the drivers running board and splash apron all finished up and the filler piece for the roll pan. I used it to fill in because of the raised bed floor. So it is done also. I am moving front now . So next will be a few spots around the wind shield and then onto the inner wheel wells. I also have a picture of the pickup and the panel together. I am going to a car show tonight.
Shannon
Old 09-07-2012, 05:12 PM   #265
xpickup
xpickup's Avatar
a few more.
Shannon
Old 09-07-2012, 07:07 PM   #266
Daze57
Daze57's Avatar
your work is absolutely sick !!!!!!!!!!! in a good way !
Old 09-07-2012, 07:30 PM   #267
oldman3
oldman3's Avatar
Beautiful work as usual, those two rides together look outstanding, enjoy the show....Jim
Old 09-07-2012, 08:38 PM   #268
mknittle
mknittle's Avatar
Shannon
Lookin good! man I gotta get my bead roller powered.
Mark
My GMC build.
Old 09-07-2012, 08:41 PM   #269
99 to Life
99 to Life's Avatar
I know you mentioned blind spots while driving the panel, daaaaaannnggg I feel you. How about some trucker mirrors. I actually like them and they would help you out. Wish I had a power bead roller too. Great work
Old 09-16-2012, 10:25 PM   #270
xpickup
xpickup's Avatar
Daze57, Thank you
oldman3, Thank you, I thought it looked neat face to face.
mknittle, Thank you. The bad thing is I think I need to build a 36" deep bead roller. So I think I am going to have to do a rebuild. Powering was a great addition though.
99 to Life, Thank you. Yes it is the moving blind spot. I do have other mirrors but have not had the time to put them on. They are really nice, they have LED turn signals in the front of them. I do not like the way they mount so I will do it another way.
I started on the inner wheel wells today. I first started with some 2" strips and bent them so I could make a buck for them when rolling them and checking for the clearances. I used my stretcher/shrinker to make my radiuses. Then tacked them together when I was happy. Then used poster board for my sheet metal lay out. I cut it all out then did my bead rolling. I had the swap my dies top to bottom because I could not get the part through the throat of the bead roller. I need to make a bigger one! Then rolled it on the slip roller. It fits great. I need to finish the front and the back where it bolts the the rear upper part of the fender because it angles back. I use the stretcher to get it to fit the fender. I am going to make the panel a set hopefully soon also.
Shannon
Old 09-16-2012, 10:27 PM   #271
xpickup
xpickup's Avatar
more
Shannon
Old 09-16-2012, 10:41 PM   #272
bjcaldwe
bjcaldwe's Avatar
Those look fantastic.
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 09-16-2012, 11:19 PM   #273
BlueJeep
BlueJeep's Avatar
Oooh, I love the inner fenders!
Once again, great work and thanks for sharing!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 09-17-2012, 12:16 AM   #274
oldman3
oldman3's Avatar
Shannon, inner fenders look great, nice work....Jim
Old 09-17-2012, 07:10 AM   #275
Larry Lindley
Great work again,thanks for sharing.now make room for mine.
