12-06-2014, 12:49 AM | #251 |
Re: Serpentine belt conversions
Sounds good,
If you PM your PayPal info, I can give you my shipping address... |
12-06-2014, 07:55 AM | #252 |
I did not buy a system from you. I got it on the forum from another member and it did not come with a water pump. The brackets are identical to the ones on my other truck and they came off a 92 Caprice. So I ordered a pump for the same car. On my truck that is running there is enough room to get the belt on and off without removing the fan pulley but not on this one. The one that works fin is a 400 and the the one that is not is a 307. Perplexing.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
12-07-2014, 12:45 AM | #253 | |
"Junkyard Dog"
Thanks,Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
12-07-2014, 04:50 AM | #254 |
Yes pulleys are identical sizes.I know in this pic that the belt is running wrong but this is the system on the running truck. I dont have a pic of the one that is too close yet.
01-02-2015, 09:22 PM | #255 |
Have any small block kits available? no AC. Shipping would be to 28138.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
01-02-2015, 11:27 PM | #256 |
"Junkyard Dog"
Yes, Do you need the AC delete pulley or just without a AC pump? Thanks, Tom
01-03-2015, 09:08 AM | #257 |
Sadly, (tragically come spring), I would need the delete as I do not have AC yet.......
01-03-2015, 11:54 AM | #258 |
"Junkyard Dog"
225.00 with the delete pulley (new). The cost on the pulley and the value on the pump are equal to me so the cost is the same. 75.00 shipping. Thanks, Tom
01-03-2015, 03:54 PM | #259 |
If you don't mind me asking- What are the part #'s for the water pump and crank pulley. I may need to purchase them from you.
01-03-2015, 08:46 PM | #260 |
OK, thanks. I just have to decide if I want all that on the front of my engine. I'd like the serpentine setup and to get PS but look under the hood of our 5.3 yukon, see all that stuff and think "ugh."
01-04-2015, 12:40 AM | #261 | ||
"Junkyard Dog"
Thanks, Tom
01-10-2015, 03:58 AM | #262 |
The reason for asking part #'s is that I have pulley's but they almost touch each other. I don't want to buy them and have the same problem. Everything is good on my 400ci but my 307ci is almost touching making it very difficult to install the belt as I would have to remove the pump pulley to even get it betwenn the two. PERPLEXED!
01-10-2015, 04:18 AM | #263 |
JJzepplin
I have all the part # from Gm but can't seem to post the picture with all the numbers. I'm new to this forum have up loaded the picture with all the numbers in the Gallery but can't seem to post it here. I have not installed one of these on my truck but plan to do it. Here is the part numbers and a link Description GM Kit # 12497698.........88 to 95 C/K trucks with SB This deluxe serpentine belt drive system with air conditioner includes all the components to install on small-block Chevrolet engines. The bolts, nuts, spacers, and braces are included with the following major items: 10055800 - Secondary Air Injector Pump Bracket. 88894005 - Water Pump Kit 10129569 - Idler Belt Pulley Bracket 10055879 - Crankshaft pulley 10463172 - Generator Assembly (Reman.) 12117361 - Generator connector (with lead) 10055798 - Drive Belt Tensioner Assembly 10085752 - Belt (fan, water pump, A/C pump, and generator) 10105212 - Generator & Power Steering Bracket 26010328 - Power Steering Pump 14102096 - Power Steering Pulley http://paceperformance.com/i-6255268...-with-air.html Does not include reverse rotation fan or fan clutch, or electrical connector for A/C compressor - order connector seperately # 12101937 Note: The compressor in this kit is shipped dry. 6 Oz of PAG 150 oil need to be added when used with R134A refrigerant or 6 Oz of 525 oil added if using R12 refigerant. Total system oil capacity is generally 8 Oz so if system is dry, an additional 2 OZ of oil should be added to the accumulator, evaporator etc. http://www.chevrolet.com/content/dam...m-12497698.pdf |
01-11-2015, 01:51 PM | #264 | |
"Junkyard Dog"
Thanks, Tom
01-11-2015, 01:59 PM | #265 |
Tom,
Ok, I can give U my email address also. I was trying to upload pictures here but failed. Steve |
01-12-2015, 06:22 AM | #266 |
Thanks guys. I sure appreciate your help. I will go out there today and check it out. I might have to take you up on that deal.
01-26-2015, 11:12 PM | #267 |
Hello:
I'd like a SBC setup. No AC compressor, but AC delete pulley if you can supply that. PS pump with inverted flare fitting. Cleaned up but not detailed. Shipping to 30303. Can you tell me if you still have parts, and what total and shipping would be? Thanks, Mark |
01-27-2015, 02:01 AM | #268 | |
"Junkyard Dog"
02-01-2015, 08:01 PM | #269 |
Hello,
I am interested in a sbc kit. What would shipping be for 53149 Thanks |
02-02-2015, 01:30 PM | #270 |
Pm sent
1969 C/10 swb, 350, powerglide (daily driver) 2005 CRV (wife's ride) |
02-03-2015, 09:25 AM | #271 |
pm sent
02-03-2015, 11:12 AM | #272 |
What water neck are you guys using to clear the alternator?
02-03-2015, 01:57 PM | #273 |
45 degree with 360 degree swivel housing.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
02-03-2015, 10:11 PM | #274 |
Can I get a price for one for a BB without A/C
Does your key work all your lock or would you like a locking glove box or would you like a New OEM Locksets for your truck? Locksmith building his first C10 1968 Chevrolet C10 SWB Step side |
02-04-2015, 02:54 AM | #275 |
Tom, payment sent, and pm sent with ship-to address.
