#251 |
Re: Rustbuket 67 build "Georgia"
Looks like they did a great job on it! Happy for you man. Now go and get some primer on it ASAP
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
#252 |
That's a great way to start!
#253 |
Still Learning
Congrats on the new truck and frame! Nice
Posted via Mobile Device |
#254 |
Nice project man I like how u took the top off it I would be scared as crap to do mine lol but I think it will be a real nice ride when u finish keep up the good work man
#255 |
67cheby
![]() Join Date: Sep 2008
Looks clean !
#256 |
it's crazy how clean that blasting gets it.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
#257 |
VA72C10
![]() Join Date: Mar 2008
frame looks great! might as well's got you....
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#258 |
Frame looks nice! I love the way you have the fenders hanging on the wall.
I don't think I will get trapped by the "Might as Well do..." thing. I would be scared to remove everything from the frame. Awesome job you are doing. |
#259 |
You have any pictures for us yet of primer and paint??
#260 |
Not yet buddy, Bought some PPG Omni (cheapo) Epoxy primer. Cost me $125 for a gallon with a bottle of catalyst and an inline filter for my spray gun. Going to use it on the body also. Doing some research about compatibility etc.. Apparently with Omni line you have only 3 days (at 70 degrees) to topcoat it. I was thinking top coat with farm and implement paint from tractor supply or maybe Eastwood chassis black. Something that I can touch up easily. Any suggestions?? Do I need to use a sealer after prime and before "paint"? Duh I don't know.
The frame has not been touched by my sweaty hands only rubber gloves and was only handled by forklift at the blasting yard. I am wiping it down with prep all wax and grease remover so it does not flash rust. I also have to do a few modifications and repairs to the frame before priming and painting. I am NOT a painter but I do have a gun (porter cable PSH1 1.5 and 2.0 fluid tips), the only paint I have done is the slicksand applied to the pass bedside. In doing that I had a friend who paints walk me through it. So if anyone has advise or criticism let me have it!
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#261 |
i use a sealer when i paint body panels, but i wouldn't on a frame. i for sure wouldn't need to use sealer if using implement paint. that paint is some tough stuff. i probably wouldn't spray once it hits 105*. i'm not positive if that's hot enough, but i do know if you paint in a spray booth while you have the heat on to high, your spray will start to dry before it hits the panel causing little bumps.
#262 |
the eastwood chassis black is some good stuff. i used on my last 2 cars. they have bare metal prep for blasted metal i used as well.i put it on with an ordinary spray bottle and wiped it off with a towel just like eastwood said to. it took more time than just spraying on some por 15 etching primmer, but it came really good. im doing an experiment with it right now to see how durable it really is. ive had a blasted piece of sitting outside for 2 weeks that i put it on and it still has no signs of rust.
but anyways, you really need to get something on it pretty fast because blasted metal will rust faster than anything ive ever seen. i little drop of sweat will start pitting in just a few days. i normally use por 15 but ive been looking for cheaper alternative that looks more like factory. if you use por 15 it sprays through a 2.3mm gun just fine. the eastwood chassis black did just fine trough a 1.8mm gun just like most primmers. it didnt do that great in a 1.0mm touchup gun though. the slick sand will spray though a 2.3mm as well. you dont need a high dollar gun either.
is it done yet? |
#263 |
Still Learning
I've been using that omni on my body panels, I really like the results I have been getting with it.
#264 |
Too bad you aren't closer or I would give you some of the ProSpray jet black that I used as I had a bunch left over.
#265 |
From what I have read, you might want to get a cheap disposable paint gun for POR-15; I would not use it in a gun you want to keep.
#266 |
instagram "footbraker67"
Its pretty cool To know there's someone else on this board from mustang OK with a passion for these old trucks, can't wait to see this one cruising the streets. Good lucknon the build man, it's looking good
1967 lwb, bigwindow, factory air (converted to Vintage Air), custom option,4.5- 6 drop, TBI injected 355, 700r4, 5 lug, daily driver. 1967 Chevelle Malibu Drag car, 355, brodix heads and intake, powerglide, 10.82 @ 123 mph 1966 chevelle malibu, Street/strip, 355, spare parts from my other chevelle, 12.82 @104 mph 1968 lwb parts truck |
#267 |
defiantly.i don't think ild load up my sharps or devilbis guns with it, but i would never call a gun disposable. i use a $40 2.3mm automart gun heavy primers. it's actually a pretty nice gun for the money. i've used it several times for slick sand and bed liners as well as por 15 and it's never given me any trouble unlike the $700 sata that, according to all the reviews, was supposed to gods gift to spray guns. they really are great..... if you have a $14,000 rotary screw compressor and a refrigerated dry air system. that pos cant lay color without runs no matter what i do and unlike my other guns, you just barely bump the air adjustment and it pulses like nothing ive even seen. i just mailed it back for the 3rd time today for a refund..ok sorry bout the sata rant it just came out.
is it done yet? |
#268 |
Nice work Dan. I look forward to your progress.
#269 |
Nice progress man.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
#270 | |||||||||||
Hey where did all you people come from?
![]() Quote:
Thanks MJ! Why thank you sir! Quote:
Thanks Mike! Yes it is, Thanks to some dude named Daniel I got a sweet deal too ![]() Yep, got that right! Quote:
![]() Yes finally Quote:
![]() Quote:
Thanks man! Thanks Billy! yours is looking great too. especially those new wheels. OKAY - So I am using TSC farm and implement paint, with their primer as well. pics coming up.
#271 |
Pics of TSC farm and implement primer on the frame...and cutting out the crossmember for the exhaust. 4.5" hole saw bit( actually bought a new one the red one was dulllll). I will be welding in sections of 4.5" pipe for reinforcement.
#272 |
More..
#273 |
Then we have a little frame issue, I plan on cutting out the bad section and welding in this piece that I made at work. There are two large dimples and the horizontal flange is bent down quite a bit. There are similar dimples is the top of the frame as well but nowhere near as bad as these. My neighbor thinks this was caused by an old frame repair machine and it makes sense but I really have no idea what could have caused this. The damage looks a lot worse in person. What do you guys and girls think about my repair idea??
#274 |
And I got a new Hobart auto darkening welding helmet and a new bed floor from my buddy suspect
#275 |
![]() Join Date: Oct 2011
Looking good my friend,, looking good!!
Wade ![]() , JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!! , Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570 Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro |
