Old 02-20-2012, 03:00 PM   #251
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Camshafts..
Get off the dang computer and go start the dang thing!
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-20-2012, 10:21 PM   #252
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Camshafts..
I broke the fitting that screws in the head for the mechanical water temp guage.
I think its 5/8 male npt and 5/8 female compression does that sound righte?
and should I prime the oil system? I dumped the lucas/penzoil in it today
-Set valves
-Drop in dizzy @ #1 compression
-Install carb
-Install the rubber line that splices in the fuel filter (rotten becuase crappy corn gas, its less tan 6 months old!)
-Top off raditator
-Prime oil system
-Fix cracked water temp guage fitting @ block
Thats about it guys...I just need something to prime the oil system with and get the piece I broke!!!
Cant wait to get it sucessfully broken in and driving it
John
1999 Toyota Tacoma 4x4
Old 02-21-2012, 08:30 PM   #253
oldblue1968chevy
Re: Camshafts..
Well its ready to fire other than I have a fuel filter for 5/16 line and I need 3/8.
So im waiting on that, pouring some gas in the carb for a quick fire and triple checking my work and making sure everythings tight etc
I CANT WAIT TO DRIVE IT AGAIN!!!!!!!
I used 10-30 penzoil with the lucas zinc additive. After break in im putting valvoline vr1 30wt in with a carquest filter
John
Old 02-21-2012, 08:31 PM   #254
oldblue1968chevy
Re: Camshafts..
DID I MENTION I CANT WAIT! I hope my cam selections better this time than it was with the thumpr!!!!!!!!
John
Old 02-21-2012, 09:14 PM   #255
sleepertruck72
sleepertruck72's Avatar
Re: Camshafts..
Dont forget to do a video ! I wana hear it
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 02-21-2012, 09:24 PM   #256
oldblue1968chevy
Re: Camshafts..
Of breaking in or running etc lol
It wont sound as good as the old thumpr but im hoping it makes me grin bigger Im stoked I cant wait!
If any of you guys have national geographic channel turn it on la street racers and doomsday preppers is on. some big motors and crazy burnouts lol
John
Old 02-21-2012, 09:39 PM   #257
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Camshafts..
I think you should wait and drag this out a little longer!!! Maybe Santa Claus can read the oil gauge while you prime!!! LOL
It's like the Heinz ketchup commercial....."Anticipation....it's making me wait....."
prostreetC-10 is offline   Reply With Quote
Old 02-21-2012, 11:33 PM   #258
oldblue1968chevy
Re: Camshafts..
Santa?...
I'll keep ya posted ricky boobie
John
Old 02-22-2012, 12:04 AM   #259
litew8
litew8's Avatar
Re: Camshafts..
zzz... zzzz... zz.. oh, huh? wha, what? are we there yet?
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 02-22-2012, 12:32 AM   #260
sleepertruck72
Re: Camshafts..
[QUOTE=oldblue1968chevy;5203995]Of breaking in or running etc lol
A video of getting her sideways like ProstreetC-10 does in his videos Put the thumper cam under your rear wheel, floor the throttle and watch it fly (just kidding)
72 C20 Longbed
05 1500 Z71
Old 02-22-2012, 01:26 PM   #261
oldblue1968chevy
Re: Camshafts..
Good and bad news
I got it running!
The manifolds started to glow cherry red in about 1 1/2 minutes!
The timings at 10* btdc (rotor points at #1) when slot in balancer is at 10*btdc
I never had the t-stat out I just left it in intake it worked when I drove the truck into the garage.
I had a BAD exhaust leak. Going to try to fix that too before I re start the truck.
Water pumps about 2 years old.
HELP WHATS GOING ON?!?!?
Ps, it got up to about 230*
John
Old 02-22-2012, 02:05 PM   #262
kevinh
Re: Camshafts..
dude been followin your post, your manafolds are glowing red right? your valves are adjusted too tight and holding the valves open back em off a little should do the trick.
kevinh is offline   Reply With Quote
Old 02-22-2012, 03:02 PM   #263
GASoline71
GASoline71's Avatar
Re: Camshafts..
Ignition timing being retarded to much will do that too...
Were you able to run it for at least 20 minutes at 2,000ish RPM's?
Gary
Old 02-22-2012, 03:51 PM   #264
oldblue1968chevy
Re: Camshafts..
No. I had to cut it off. It was 230* 2 minutes in!!!!
Lunati instructions said if you have to alter something kill it let it cool and try again.
Its gonna be good this time.
Setting timing @ about 12* btdc (was at about 4*..)
And fixing the exhaust gasket I blew out.
I sure hope its the timing too retarded
John
Old 02-22-2012, 04:11 PM   #265
oldblue1968chevy
Re: Camshafts..
Should I leave the T stat out? I worked 1 week ago, its relatively new I dont see why it wouldnt work..
John
Old 02-22-2012, 04:36 PM   #266
nobull2
nobull2's Avatar
Re: Camshafts..
get a big fan and put it in front of your truck and leave the raditor cap off, and run it. I bet it has air in the cooling system, add water to it as the t sat opens.
nobull2 is offline   Reply With Quote
Old 02-22-2012, 04:49 PM   #267
prostreetC-10
My Carbon Footprint
Re: Camshafts..
Dang........
Old 02-22-2012, 04:58 PM   #268
oldblue1968chevy
Re: Camshafts..
Wouuld 2-5* btdc timing make it glow red?
Im at about 10-12* btdc with enough room to go to about 14* btdc
Should I try again? Im scared I cant afford/or have time to wipe this cam out lol
John
Old 02-22-2012, 05:15 PM   #269
nobull2
nobull2's Avatar
Re: Camshafts..
yes 4 deg will make it run hot
Old 02-22-2012, 05:23 PM   #270
oldblue1968chevy
Re: Camshafts..
230* hot
Okay guys im going over it again
ALSO, I didnt have an air filter on it at the time (so i could acess dizzzy easily) that probaby leaned it out a little too i guess
keep tips comming laptop is on table next to truck for updates
John
Old 02-22-2012, 05:45 PM   #271
oldblue1968chevy
Re: Camshafts..
One more thing. (The motor wasnt running long) the water in the radiator was touhcable?
John
Old 02-22-2012, 06:04 PM   #272
oldblue1968chevy
Re: Camshafts..
Everythings goin good got 5 more min on break in then puttin vr1in
John
Old 02-22-2012, 06:19 PM   #273
prostreetC-10
My Carbon Footprint
Re: Camshafts..
Are you saying you got it lit again?? No more heating problem?
Old 02-22-2012, 06:24 PM   #274
oldblue1968chevy
Re: Camshafts..
Just finished the break in with speeding updown like lunati instructions said all went well this time!!!
I''ll miss the thumpr idle though lol this sounds like a s stock prius compared to the thrumpr
John
Old 02-22-2012, 07:04 PM   #275
litew8
litew8's Avatar
Re: Camshafts..
speeding updown...
yep yep
