Old 09-06-2013, 12:40 PM   #251
bloodybigblock
bloodybigblock's Avatar
Re: project: 3/4 ton dropped
If you convert than let me know. I need your spindles
bloodybigblock is offline   Reply With Quote
Old 09-07-2013, 11:07 AM   #252
bloodybigblock
Hey, what center cap do you have over the steelies?
Old 09-07-2013, 11:17 AM   #253
79 blue monster
79 blue monster's Avatar
i was going to use the centercaps of the newer 8 lug hd wheels.
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP
http://67-72chevytrucks.com/vboard/s...d.php?t=518625
1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972
79 blue monster is offline   Reply With Quote
Old 09-07-2013, 06:58 PM   #254
bloodybigblock
can u get a better pic of them? I was curious to see what theyd look like.
Old 10-09-2013, 11:27 PM   #255
79 blue monster
Its Been a while since I've been on here so I have a lot of pictures and updates. I started wet sanding and buffing out a side of the truck and almost finished with the help of my dad. I bought gm front and rear bumpers from a guy that bought them new in 1990 so there really clean yet.
Old 10-09-2013, 11:34 PM   #256
79 blue monster
Old 10-09-2013, 11:43 PM   #257
Billy81
Billy81's Avatar
Looks like it's coming out really nice.
Billy81 is offline   Reply With Quote
Old 10-09-2013, 11:49 PM   #258
79 blue monster
This is the big update... since my 454 block was cracked I picked this Cadillac 500 up for half nothing.
Block: hot tanked, crack checked, ridge reamed, honed, new freeze plugs
Heads: hot tanked, crack checked, new guides, reground seats
New water pump, cloys timing chain, rings. full gasket/seals set. the pistons/bearings were like new yet. Used same cam, but I plan on getting a different one later down the road. I took my Chevy turbo 400 tranny and swapped all the rebuilt parts into my Pontiac 400 case. To mount it I had to cut the firewall and move the tranny up an inch. the front mounts I just flipped passenger side to driver, and driver to passenger. drilled new holes for the mounts and I was done. The engine is almost done, just a few things left and then its going in.
Old 10-10-2013, 12:00 AM   #259
79 blue monster
some more
Old 10-10-2013, 12:03 AM   #260
79 blue monster
the engine as it sits now
Old 12-15-2013, 04:28 PM   #261
mickeykreg
mickeykreg's Avatar
Got any updates? Your truck is major inspiration. I totally dig the long and low look.
I'm so close to dropping my 1 ton...i think the only thing holding me back right now is that it's 12 degrees outside.
'80 SRW C35 - 355/700R4/4:11/2.5-3/DD
'77 Cheyenne K5 - Roller cam 355/NV4500/205/4:88's/35's/DD
rust repair on the '77
http://67-72chevytrucks.com/vboard/s...d.php?t=740291
mickeykreg is offline   Reply With Quote
Old 12-16-2013, 09:05 AM   #262
79 blue monster
i got the engine in and put a new set of wheels on. i started puting my doors back together but ran into some small issues.
Old 12-16-2013, 09:16 AM   #263
79 blue monster
Old 01-31-2014, 10:31 AM   #264
manimal
manimal's Avatar
This is a SWEET truck! Need more info on the Caddy swap! PICS!
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 02-28-2014, 07:16 AM   #265
Theoriginalsilverado
Hey man!
I'm 15 and I have a 1975 C20 Camper special! Just like you, except mine is a 350 motor. I plan on dropping it, but I don't want to have to cut a notch out of my frame or do too much welding. Even dropping the back 1 or 2 inches would be good. Or maybe I should go for the frame notch? It's just a little scary to me.
Any suggestions or advice? I love your truck by the way. I think you've made a lot of us jealous
If It runs like a Chevy, it probably is!
Theoriginalsilverado is offline   Reply With Quote
Old 02-28-2014, 09:07 PM   #266
Hankster
Hankster's Avatar
Originally Posted by Theoriginalsilverado View Post
Hey man!
You could do a flip kit with out a notch, I know people who have done it.. It will probably just sit on the frame/bump-stops.
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 04-22-2014, 12:03 AM   #267
79 blue monster
Got it out of the corner, time to finish it!
Old 04-22-2014, 12:09 AM   #268
79 blue monster
Hey man!
I say do the notch only if your dropping it 4-5in. And from what I've seen its just as strong as not cutting the frame. But if you just drop it 1-2in then the notch is just a waste of money. your rear end wont even come near the frame.
Old 05-26-2014, 11:23 PM   #269
79 blue monster
took some time and made myself a one of a kind grille and got the door panels done
Old 05-26-2014, 11:25 PM   #270
79 blue monster
Old 05-27-2014, 02:01 AM   #271
Billy81
Billy81's Avatar
Pretty awesome looking grill..
Old 05-29-2014, 06:01 PM   #272
Hankster
Hankster's Avatar
Looking good man!
Current Build
Old 07-30-2014, 03:27 AM   #273
nheller76
nheller76's Avatar
hey man haven't herd anything form ya in a bit hows it going?
Faith and Patience with my truck, that is what i pray for every day!
See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013
nheller76 is offline   Reply With Quote
Old 07-30-2014, 08:42 AM   #274
79 blue monster
yeah i havent been on here in a while. The truck is close to being done but still needs some things. I had it running and driving for my graduation so that was pretty cool. I bought a brand new set of wheels for it but tje backs are to wide, so ill have to get a narrowed rearend. Im just running it with slicks on steelies for now till i can afford a rear end.
Old 07-30-2014, 08:44 AM   #275
79 blue monster
ill try to get some more pics up soon
