#251 |
Re: You guessed it, 1950 s10 swap.
Thanks guys, it is sprayed with stuff called raptor liner. Very nice stuff. I sprayed the underside of the cab and firewall with it too.
1954 Chevy 3100 5 window, bagged on s10 frame, 6.0 ls swap/4l80e Past build thread http://67-72chevytrucks.com/vboard/s...=531261&page=3 1949 3100 s10 swap 5.3. Instagram -@thejcates |
#252 |
Got the wheels back from coating today, and the tires on. The rear rims are a little too wide. Gonna have to swap my rear end with a 2wd to get the back wheels on. But got a pic of the fronts on!
#253 |
Looks sooooo good!
Some questions, since I might be getting the same sizes: Did you have spacers on the rear? Or just a 4x4 rear end? What BS did you end up going with? If you had known they would end up too wide, would you have gone with a different BS? Or would you have gone with a 10" for the rear? Did you have the room in the rear fender to use the 11"? I am planning on running aftermarket inner fenders- I'm wondering if I will run into issues at full drop- how close are yours to the inner fender? I am anxious to hear how it rides on the 20s with those thin tires. Do you have concerns about bending the wheels since they are all steel? |
#254 |
The rear end is a 4x4 with no spacers. Gotta swap a 2wd rear end in to make them fit. The rear rims are 20x11 with 4.5 back space. They should fit perfect with a 2wd rear. The front is 20x9 with 4.5 backspace. They fit perfect. I had to get a small tire to lay out with 20s. I have been using tires this small for a long time. Never bent a rim yet! Maybe ive been lucky.
#255 |
That's cool- I may go with a slightly larger tire if I have the room since I dont want to lay on the ground- just above it(In case I blow an airline)
#256 |
That looks so good with the rims.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#257 |
Looks so awesome! This truck keeps getting better and better. How long did it take to get them? Thinking about pulling the trigger and doing 20x9 on all fours. Do you think the 20x9 with the 4.5 backspace will work on the rear with no tubs? I have an explorer rear end.
#258 |
Thanks guys! 20x9 with 4.5 would worl on mine with the 4x4 rear. I dont know the specs of a 8.8 rear tho. They took about 2 weeks to get after ordering. But that was raw metal wheels
#259 |
#260 |
Me either, hope to have that happen this weekend.
#261 |
Rims are awesome! Like to have that style on my build. Like a little more side wall though
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
#262 |
Looking forward to seeing all 4 on the truck
#263 |
![]() Join Date: May 2007
those look crazy on there!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#264 |
#265 |
![]() Join Date: Mar 2007
Looks great. You don't mess around.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#266 |
I like a lot. Is that a picture of license plates or real license plates?
#267 |
Thanks guys, and those are all real plates.
#268 |
Man that thing looks great!
my 54 s10 build |
#269 |
What tire size? Looks soooo good.
#270 |
Tire size up front 20x9 245 35 20. Out back 20x11 285 30 20
I wanna ask you guys for an opinion on my truck real quick. This truck had aftermatket fog lights installed when I got it. I took them off and havent put them back on, but ilI am considering puttig them back on. Whatbyall think? ![]()
#271 |
#272 |
I kinda like the fog lights.
#273 |
Never seen them mounted on the fender before..
Have always seen them mounted on the bumper valance,but I happen to LOVE the look with the fog lamps! I have a pair myself but have went a different direction with the front bumper so I don't know if I will use them. Mark..
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#274 |
I like them.
#275 |
Personally like it more without them. Thanks for the tire sizes. Going to do 20x9 square here soon.
