Old 10-02-2013, 07:22 PM   #251
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: '66 Longbed 327 w/AC project
WOW!
The splash shields look awesome!
Fake flower greening clips? Are those the staple thingy's
Where do I get them? I was just gonna glue mine on, and/or safety wire them & twist them on the back side!
Those look fantastic!
Modges'66 is offline   Reply With Quote
Old 10-03-2013, 01:23 PM   #252
1963c-10
1963c-10's Avatar
Where did you get the mounting tabs for the splash shields? Holds them to the fenders? Paint is looking great as is the truck.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-03-2013, 03:51 PM   #253
McMurphy
McMurphy's Avatar
Originally Posted by Modges'66 View Post
WOW!
Yeah me too! Ditto to everything he just said !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 10-03-2013, 05:12 PM   #254
jayoldschool
Moderator
This truck is going to be completed before the old trim is mounted on my truck!
Keep it up, it's looking great!
jayoldschool is offline   Reply With Quote
Old 10-03-2013, 05:39 PM   #255
cortcomp
cortcomp's Avatar
Thanks guys!
For the metal panel mounting clips, i had another thread people helped with:
http://67-72chevytrucks.com/vboard/s...d.php?t=594044
and ended up getting 12 from classic (4 for the panel you see and 2 for the L-shaped bracket that i don't have on yet that goes across the top, per side:
http://www.classicparts.com/1960-66-.../#.Uk3hyiSkq2Z
Just put them in the hole with the parts line up and squeeze with pliers, and the other end opens and holds them together.
The metal staples you can get the correct ones from lots of vendors, they used them on gm cars forever. I used the correct ones on my 71 pontiac, but they were a PITA to do on the inner fenders...the staples are stiff and no length on the staple ends side to bend with pliers, so you need two guys to do them.
These are long and softer, so i just lined up the rubber and drilled in the existing metal holes with a tiny drill bit to pierce the rubber, inserted the greening pins, and bent them over one by one on the other side. When done, i trimmed the excess with side cutters, laid the panel on the bench and tapped them down a little more lightly with the hammer to be sure they were snug.
I found the idea from someone else on here actually, i just can't find the thread at the moment! After working with the original staples, i knew this was the way to go.
I got mine from Michael's craft store (they also sell the green krylon paint, satin jade, for the dash cluster metal case, and silver paint pens for doing trim work on other gauges i had...) I'm sure any craft store like that has them.
Anyways, look for fake flowers and styrofoam shapes and they're near there...here's a pic of them and the box. It was 1.99 for a box of $50. Usually like 12 staples is $6 from the resto-houses.
This forum really is a wealth of ideas, i'm just stealing them all to put into my truck
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 10-03-2013, 05:43 PM   #256
cortcomp
cortcomp's Avatar
AND found it, slorio was where i got the idea:
http://67-72chevytrucks.com/vboard/s....php?p=4309938
Old 10-03-2013, 08:55 PM   #257
Modges'66
Modges'66's Avatar
Totally Outstanding!
I greatly appreciate the info!!!
Old 10-05-2013, 01:46 PM   #258
McMurphy
McMurphy's Avatar
Dang .... Modges keeps beating me to it....
Sending the wife into town today to pick me up some as well since my outer fenders are getting closer to being the next project I tackle....
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 10-05-2013, 04:39 PM   #259
plainred65
plainred65's Avatar
Just found this thread, truck looks great!
plainred65 is offline   Reply With Quote
Old 10-05-2013, 08:56 PM   #260
cortcomp
cortcomp's Avatar
Thanks! I did the L shaped brackets that go above those with the same clips today and some inner fender seal, everything there is about done until i get the fenders on, and put the little top metal brackets on after that. Started work on the hood today too.
Old 11-25-2013, 08:59 PM   #261
cortcomp
cortcomp's Avatar
Had a chance to finish prepping the inside of the hood for 30% gloss black and get it sprayed.
Old 11-25-2013, 09:19 PM   #262
clemdaddy
clemdaddy's Avatar
looking fantastic and nice detail work.
all the time invested really shows off.
are you shooting single stage? very rich color... my next truck is going to be that green and white. beautiful.
clemdaddy is offline   Reply With Quote
Old 11-26-2013, 04:05 PM   #263
cortcomp
cortcomp's Avatar
Thanks and that hood underside is single stage centauri, no clear, 30% gloss mixed 8:1:2 per the can. The rest of the truck we are shooting in single stage centauri, little thinner on the paint than the 8:1:2, and using nason clear over it 2 coats, mixed per the can. I am happy with it. if shooting metallic, i wouldn't thin the paint any more than the can says, but i'd still use clear over (and i plan on doing that with a quick resquirt of my 66 catalina that someone did in nason metallic but the finish is pretty matte.) I didn't want to spray any clear under the hood because the 30% gloss is already pretty glossy compared to stock i feel. Paint jobber said that the hardender kind of counter acts the flattening agent, and temp, shooting conditions, etc can affect how flat it ends up being.
Anyways, you can tell as you're painting that it's a brown based black. I'm told there is a blacker pure black that you'd want to use on the outside of a car that apparently makes a difference?
Old 12-01-2013, 10:07 PM   #264
cortcomp
cortcomp's Avatar
Did the color on the hood today, and the second fender cover that we never did clear, and the windshield cowl panel...check it all out tomorrow, if no respray work done, then done with all panels except the bed!
Old 12-01-2013, 10:11 PM   #265
Phlebmaster
Phlebmaster's Avatar
Wow!! Very nice work on the paint. Subscribed...this is inspiration for my 64 GMC.
Keep it up!!
Thanks, Aaron
Life is about making dreams come true, stop dreaming and make life happen.
64 GMC Project MY_YOUTUBE_VIDEOS To keep an opened mind- speculation is devine.
Assumptions always lead to a dead end!
Phlebmaster is offline   Reply With Quote
Old 12-03-2013, 08:56 AM   #266
clemdaddy
clemdaddy's Avatar
that looks great... really smooth.
Old 12-03-2013, 12:12 PM   #267
cortcomp
cortcomp's Avatar
Thanks guys! I will be taking the bottom masking off later hopefully, doing some quick touch ups if any overspray got through, and then the fun (for me anyways) part begins: i get to start putting the parking lights in, new rubber and clips, wiring harness, etc to make the hood complete. I LOVE assembling with new parts.
Old 12-03-2013, 05:48 PM   #268
McMurphy
McMurphy's Avatar
I totally understand and can echo that statement about new parts and assembly !!
Probably going to do some of that today my own self.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 12-03-2013, 08:33 PM   #269
cortcomp
cortcomp's Avatar
I had filled the front panel seam with seam sealer and wiped it with a gloved finger. I wanted the crease to remain there so it looked normal, but not as deep as it is factory. I did the same on the fenders where the front black piece is spot welded to the white/green rest of the fender. I like the look and think it works well.
Also, did inside the nose holes with black and masked it off, looks like it came out well. I'm not a fan when they're just overspray of body color. They look good body color, or black, but just kind of off color overspray looks bad, especially on the front of the vehicle, one of the most looked at areas. I have some hand touch up to do in there, but it looks like the tape kept 99.99% out.
Old 12-07-2013, 07:25 PM   #270
cortcomp
cortcomp's Avatar
Started some assembly on the hood today and ran into some questions:
http://67-72chevytrucks.com/vboard/s...d.php?t=607123
Grinding off the pin allowed me to take the hing apart for paint. I made a new spring (2 actually) from a coat hanger, and found workable springs to replace the other ones in the latch setup. For the hinge pin in the latch, i found a simple locking pin that i took the wire off of, and i will drill a hole in the end once assembled and put a cotter pin through it. It won't be totally stock but clean, with clean lube, painted black and shiny springs should make it look new and work smoothly. Still confused on how/where some of the rubber pieces go.
Old 12-07-2013, 08:15 PM   #271
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
drool drool drool....that hood is a die for! lol!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-08-2013, 12:00 PM   #272
cortcomp
cortcomp's Avatar
Hey thanks! It's not perfect, i have some touch up to do around the lower lip and some orange peel i have to sand on the nose section...and there are some dirt specs i'll be cleaning up, but i appreciate the compliments! The photos always miss the flaws and make every piece come out perfect, but i know where all the problems are even if you guys don't catch them
Old 12-08-2013, 12:21 PM   #273
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Well it came out a heck of alot better then my hood did!!! lol! I won't tell you about it!
Old 12-08-2013, 02:46 PM   #274
cortcomp
cortcomp's Avatar
I finished doing the homemade latch today, i think one spring doesn't belong, think PO put it there because main spring broke. Coat hanger spring worked great! very firm!
Here's more on that, i STILL don't know where all the rubber in the kit goes
http://67-72chevytrucks.com/vboard/s....php?p=6407936
Old 12-08-2013, 10:11 PM   #275
jayoldschool
Moderator
Looking great, my friend. Can't wait to see the new trim on it!
