04-05-2014, 01:51 PM | #251 |
Hollister Road Co.
Re: 1949-50 3100
We have the LED in it
04-05-2014, 11:08 PM | #252 |
Re: 1949-50 3100
nice mod, hopefully keeps retards from rear ending yah.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
04-05-2014, 11:47 PM | #253 |
Hollister Road Co.
Re: 1949-50 3100
04-11-2014, 04:35 PM | #254 |
Hollister Road Co.
Re: 1949-50 3100
We are frenching the headlights and had to replace a section that was very thin from rust.
The repair piece is shaped tacked in read for welding. Frenching the light is fairly easy you just need to make sure the opening is round and flat to accept the new light bucket. This is a Hagan #4050BS kit |
04-11-2014, 07:25 PM | #255 |
Re: 1949-50 3100
nice work on the 3rd brake light forming
i so wish i had added one on truk
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-12-2014, 06:35 AM | #256 |
Re: 1949-50 3100
Just scrolled through from the beginning of the thread. Looking great! Although I'm a little nervous now about what we might find when we get ours apart for a full resto some day
I'll look forward to following along from here... Very cool! |
04-12-2014, 10:35 AM | #257 |
Hollister Road Co.
Re: 1949-50 3100
04-12-2014, 10:36 AM | #258 | |
Hollister Road Co.
Re: 1949-50 3100
You never know what you'll find after you sand blast. |
09-26-2014, 01:28 PM | #259 |
Re: 1949-50 3100
Any updates on this one?
09-26-2014, 01:37 PM | #260 |
Hollister Road Co.
Re: 1949-50 3100
Its in the paint shop now should be back in two weeks or so.
12-12-2014, 06:58 PM | #261 |
Hollister Road Co.
Re: 1949-50 3100
This is back on the work board, the cab and sheet metal comes back from the paint shop first of the week. This truck is a whole lat of red. I'll post pictures the parts arrive.
12-18-2014, 10:49 PM | #262 |
Hollister Road Co.
Re: 1949-50 3100
we have the cab back and its very red. Next week we start finishing the inside with sound deadener, insulation, AC and wipers along with a new harness
12-18-2014, 11:26 PM | #263 |
Re: 1949-50 3100
I love it!! A lot of work in that cab!
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
12-18-2014, 11:55 PM | #264 |
Re: 1949-50 3100
Looks great...
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
12-19-2014, 12:27 AM | #265 |
Re: 1949-50 3100
Mmmm, nice and bright...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
12-19-2014, 05:31 PM | #266 |
Hollister Road Co.
Re: 1949-50 3100
Thanks all, The odd thing is the owner is color blind.
01-07-2015, 03:51 PM | #267 |
Hollister Road Co.
Re: 1949-50 3100
Well with the Holidays over and UPS delivering again we started the insulation and wiring on the cab. The insulation is a little different than the usual shredded recycled rag fiber. This is made from recycled plastic bottles, Polyethylene terephthalate, and called Eco-fil. The brand is Thermozite and is has a single or double sided foil. I got tired of wrecking my scissors on that cloth fiber product because it had a lot of trash in the fiber like aluminum bits and copper wire snippet pieces. The Thermozite is nice clean fiber no trash and cuts easily.
The outside firewall insulation is 1/4" Thermotec fiber glass filled double sided foil. Next is the AC and column and drop it on the frame |
01-07-2015, 05:09 PM | #268 |
Re: 1949-50 3100
looking good, I'll look into that stuff. I need some for my headliner and back wall. I just used the rubber base stick on stuff for my floor. Found a place made in the USA.
01-07-2015, 07:22 PM | #269 | |
Hollister Road Co.
Re: 1949-50 3100
On the headliner they recommend a high temp spray for the Thermozite insulation. |
01-23-2015, 04:42 PM | #270 |
Hollister Road Co.
Re: 1949-50 3100
A little more progress on this. AC is installed mufflers and pipes fabed up. We used S10 hanger rubber with 3/8 rod bent into a J hook welded one side to a bracket on the frame and the other to the muffler.
01-24-2015, 01:04 AM | #271 |
Re: 1949-50 3100
looking good
01-24-2015, 11:13 AM | #272 |
Re: 1949-50 3100
Nice...Jim
01-24-2015, 11:20 PM | #273 |
Re: 1949-50 3100
Looks really good! Is the AC a Vintage Air Sure Fit unit?
01-25-2015, 09:10 AM | #274 |
Re: 1949-50 3100
Looking Good
1950 3100 5 window |
01-25-2015, 08:16 PM | #275 |
Hollister Road Co.
Re: 1949-50 3100
thanks guys ,,, yes it a VA unit.
We plumbed the fuel lines, filter yesterday and will button up the e brake and brake lines this week then drop the cab on it and start assembling the front sheet metal. This should start moving quickly now, it needs to be done by mid to end of February. I have another 50 project that just came in to make it a daily driver. |
