Old 12-08-2013, 01:26 AM   #251
tll74
"Junkyard Dog"
tll74's Avatar
Re: Crossing over, the 65 rebuild.
Lookin good John... ya gota drive this down when its done. BTW how did the 383 hold up in the donut fest?
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
Old 12-08-2013, 02:14 AM   #252
NEWFISHER
NEWFISHER's Avatar
Man, that 383 is thirsty. I made 3 trips over to the Shell station just to keep up with Dan! I'm glad I disconnected the speedo cable and parked it back inside so the guy who owns it doesn't find out heheheh....J/K!
NEWFISHER is offline   Reply With Quote
Old 12-08-2013, 08:07 AM   #253
Low Elco
Good lookin' work! Anxiously awaiting Monday's progress!
Low Elco is offline   Reply With Quote
Old 12-08-2013, 12:26 PM   #254
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Same here! Can't wait to see the progress! Nice air ride suspension.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-08-2013, 04:01 PM   #255
NEWFISHER
NEWFISHER's Avatar
Old 12-08-2013, 05:22 PM   #256
NEWFISHER
NEWFISHER's Avatar
So far eveything fits and works well. The ebrake portion of the rear calipers will interfere with the bed side on full drop unless I modify some pockets at the wheel well area. I ran the pressure switch in the cab for the compressor to keep it dry and all lines are now ran. Got the 2" blocks installed and now working on upper shock relocators, did I mention I hate huck bolt rivets? Getting closer
Old 12-08-2013, 09:17 PM   #257
1Bad 37
1Bad 37's Avatar
Nice work!
Pardon my ignorance, but what's a huck bolt rivet?
1Bad 37 is offline   Reply With Quote
Old 12-08-2013, 10:14 PM   #258
NEWFISHER
NEWFISHER's Avatar
Those factory frame rivets that they assembled everything with to speed up production. Some refer to them as a huck bolt. They are just large pain in the a$$ rivets that don't torch well, hard to get a grinder in tight spaces or you have to listen to an air chisel to remove them. I will do a frame off someday and just peel them off that frame just to win the battle.
Old 12-08-2013, 10:16 PM   #259
1Bad 37
1Bad 37's Avatar
Gotcha, THOSE things! THOSE things are a pain!
Old 12-08-2013, 10:24 PM   #260
NEWFISHER
NEWFISHER's Avatar
Sway bar clearanced and won't interfere with collapsed bag
Rear blocks in and starting to layout stainless brake lines
Rear disc brake caliper ebrake assembly and running cables
Loosly running cable and transfering to stainless cable to yoke at trans area
If all goes as planned I should be aired up and driving it tomorrow! Whoop whoop
Old 12-09-2013, 08:29 AM   #261
bj383ss
bj383ss's Avatar
Awesome! So does the new ebrake just hook up to the old or is it all new to the handle under the dash?
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 12-09-2013, 09:08 AM   #262
Low Elco
Great work! Looks Good!
Old 12-09-2013, 11:29 AM   #263
NEWFISHER
NEWFISHER's Avatar
Bret
Thanks guys!
The Ebrake cables from the drums get thrown away. The new calipers have their own cable and then a "jumper" cable to make up the difference in length from the really long originals that tie together just under the trans tailshaft at the ebrake yoke. From there forward, it's the same. Only change is where the split under the center of the truck and go left/right. New jumpers to shorter shielded cables to the new calipers.
I was shorted a jump cable and the other must be for a long bed as it's about a foot too long. I ran to the hardware store and picked up some stainless cable and ring style crimps to adjust length and then lock them down to size. should work fine.
Old 12-09-2013, 12:15 PM   #264
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
WOWZA! Even a sway bar! lol! Nice work!
Old 12-09-2013, 04:05 PM   #265
NEWFISHER
NEWFISHER's Avatar
The trips to the parts store for fittings, nuts and bolts etc are killing me
Old 12-09-2013, 04:21 PM   #266
G&R's57GMC
G&R's57GMC's Avatar
Looking GooD !
Oh and ...
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 12-09-2013, 11:05 PM   #267
NEWFISHER
NEWFISHER's Avatar
Thanks, Happy HO HO to you too!
Here's some random pic's of todays progress. Everything under the truck is done. Master cylinder in, all lines ran and bled. Ebrake functions, all air lines protected and ran to the cab, compressor wires ran into the cab. Other than putting the wheels on it in the morning, I am set to roll it back from the lift , open the drivers door and start mounting the manual switch gauge panel, plug the lines into it, run the power wire and gauge lighting wires. Cross my fingers and try it out! Good news it warmed from -10 to 18 today and the roads are getting beat down enough that a slippery slammed test drive ( with lots of doughnuts) should happen around lunch time.....wish me luck!
The next one I do, I will remove the cab and bed to expose the frame....it would have been waaaaaaaaay easier. For those thinking of bagging, disc braking, master cylinder upgrade etc. just pull the cab and bed. The bed has to come off anyway to notch, the cab isn't much longer and it will make for a much cleaner and quicker install, especially if you are doing a tilt column , wiring etc like I started doing in the beginning a couple months ago. Should have just blown it all apart then.
wow, crappy pic's I will get some better ones tomorrow. Must be brake fluid on the ol' cell camera
Old 12-10-2013, 12:00 PM   #268
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
AYE! I'll be praying for the OTHER drivers!! HAHAHAHHAHAH!!!! Just kidding! Yup! Have fun on them ice roads! Doughnuts are never tiring!
Old 12-10-2013, 01:49 PM   #269
hotrodred
hotrodred's Avatar
Waiting...waiting..And then? And then? haha
Jon Carr
hotrodred is offline   Reply With Quote
Old 12-10-2013, 09:28 PM   #270
NEWFISHER
NEWFISHER's Avatar
DONE!
Took a little longer than I expected with chasing brake fluid leaks, running some clean wires and a relay, parts store trips, in dash air gauge, test fitting panel etc. It's all the little things that kill a day. I tell my wife " I'm quick and good at framing a house, but it takes me 10 times as long to do molding work".
Here are some ride height and a full up shot followed by the manual gauge/paddle panel and the air tank pressure gauge.
Full up
It did warm up again to 25 degrees today. Working behind the curtain in the background gets a little chilly, maybe that's why I move fast?
Old 12-10-2013, 10:27 PM   #271
LT1 Burb
LT1 Burb's Avatar
Awesum dude, looks great
LT1 Burb is offline   Reply With Quote
Old 12-10-2013, 10:30 PM   #272
Bomp
Bomp's Avatar
Great Job
Bomp is offline   Reply With Quote
Old 12-10-2013, 10:39 PM   #273
Ta2Don
Ta2Don's Avatar
Very Nice!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 12-10-2013, 11:25 PM   #274
likaroc13
Rollin' Old Skool
Looks good with the bags! Man, you work fast.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 12-10-2013, 11:52 PM   #275
G&R's57GMC
G&R's57GMC's Avatar
Lookin' Goood
So how many doughnuts did you do on your test drive ?
Glen & Jane's Rides
