Old 01-30-2018, 10:27 PM   #251
Joe Pass
Joe Pass's Avatar
Re: Lss3
Nice...that little block is tough to remove...I removed my chains and modified that area also....I'm always curious how you will finish it off.....Looks like your tig welding...nice
Joe
Joe Pass is offline   Reply With Quote
Old 02-07-2018, 10:39 PM   #252
69cunningham
69cunningham's Avatar
Re: Lss3
My belated Christmas present finally arrived. More details to come.
69cunningham is offline   Reply With Quote
Old 05-10-2019, 12:41 AM   #253
halfstep
Re: Lss3
Progress report?
Subscribed when you started - real nice build and great story.
Plan,design and execution all look excellent.
Did you ever finalize the battery relocation?
Good luck going forward.
halfstep is offline   Reply With Quote
Old 05-10-2019, 07:50 PM   #254
69cunningham
Re: Lss3
I’ve made a little progress, but not nearly enough considering how much time has passed. The battery mount has progressed. It is a bit different than my earlier plans.
Old 05-10-2019, 08:43 PM   #255
halfstep
Re: Lss3
Thanks for the follow up - and nice photo's.
Crazy ingenuity and workmanship on the battery mount.
Stepsides don't have quite the under body mount mount options as a fleetsides. Did you position it where you did because of the long wire run or for ease of access or both?
I'm thinking about behind the passenger seat with a Blazer flip seat base.
Old 05-10-2019, 10:23 PM   #256
69cunningham
Re: Lss3
I liked the weight distribution better putting it under the passenger stepside fender. There was plenty of room, but it was going to be a challenge running the cable. With the battery in the front location, using 1/0 cable, there shouldn't be appreciable voltage drop. It is also easy to get it in and out.
Old 05-10-2019, 10:58 PM   #257
halfstep
Re: Lss3
...and you cleaned up the engine bay - looks better, plus more air flow and intake options.
Old 07-13-2019, 08:14 PM   #258
69cunningham
Re: Lss3
Our family has a tough time last week. We lost our beloved friend Rocky.
I have made a bit of progress on the circuit breaker panel. It’s a bit overkill.
Old 07-13-2019, 08:42 PM   #259
Joe Pass
Joe Pass's Avatar
Re: Lss3
Sorry to hear.....
Old 07-14-2019, 05:42 AM   #260
SIXTY9
Re: Lss3
So sorry for your loss. I have been following your build and really like it.
SIXTY9 is offline   Reply With Quote
Old 07-14-2019, 12:04 PM   #261
nlped
nlped's Avatar
Re: Lss3
So sorry to hear about Rocky! I lost my dog last Monday and it sucks.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 07-14-2019, 09:10 PM   #262
69cunningham
Re: Lss3
Thanks for all the kind words.
Old 10-29-2020, 11:41 PM   #263
69cunningham
Re: Lss3
Here’s an update on some of my electrical work. The LS3 relay box is a challenge to safely mount. After seeing someone using a sheet metal bracket that attaches to the features on the lower box, I decided to machine something similar out of aluminum. This will allow the box to be bolted to the electrical panel shown previously. The panel will also hold the ECU.
Old 10-30-2020, 11:34 AM   #264
layinrocker65
layinrocker65's Avatar
Re: Lss3
Great attention to detail on this truck.
Where did you get your powder coating done? Looking to get a frame done around Santa Rosa.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 10-30-2020, 11:45 AM   #265
69cunningham
Re: Lss3
I had it done by Miller Powder Coating in Rohnert Park. http://www.gompc.com/automotive.html
They did very nice work.
Old 01-01-2021, 07:24 PM   #266
69cunningham
Re: Lss3
The circuit breaker panel got some updates. The LS3 computer is mounted on some custom standoffs so the fuel pump controller and relays can mount below it. The relay box has also been attached.
Old 01-01-2021, 07:28 PM   #267
Joe Pass
Joe Pass's Avatar
Re: Lss3
Nice update....Happy New year
Old 01-02-2021, 10:07 AM   #268
Wiekser
Wiekser's Avatar
Re: Lss3
subscribe...
Sander
All Ideas, advice, critisism is welcome. Nothing better to learn from.
______________
'72 C/20 http://67-72chevytrucks.com/vboard/s...d.php?t=809053
Wiekser is offline   Reply With Quote
Old 01-11-2021, 11:03 PM   #269
chetisimer
Re: Lss3
Originally Posted by 69cunningham View Post
Trackman-
Sorry it took so long to reply. The shifter base definitely sticks above the floor. I have a high hump cover, but have yet to cut the shifter hole in it. I may get around to it next week. I’ll add a picture when I do.
Hi Mr. 69c-ham,
Couple questions on your trans/shifter if I may...
Can you share the model of your Core Shifter?
Can you tell me how tall your handle is?
Your install looks great. Is there a reason you chose not to use the mid-mount for the shifter?
Thanks,
Craig
chetisimer is offline   Reply With Quote
Old 01-12-2021, 12:20 AM   #270
69cunningham
Re: Lss3
The Core shifter base is the Core / Hurst Shifter Base: Tremec T56 Magnum aftermarket Option D for 12"+ stick length. The website is https://core-shifters.com/collection...31458433892470 . This base angles the stick 14 degrees to the drivers side. The Hurst shifter is the 238 0085 that is 14 inches long. My earlier post shows a dimensioned drawing. I chose the mid mount location with the stock shifter base and my custom made stick. I assumed that stick would be used with the Core base, but it put it in the wrong position. The Hurst stick was perfect.
Old 01-12-2021, 08:17 AM   #271
chetisimer
Re: Lss3
Thank you for the quick response. I'm in the midst of figuring out my shifter/handle combo (T56 magnum in my '72/bbc) but, don't have it mocked up yet. In the meantime, I've narrowed the shifter options to D, E or F and will likely need to have the trans/seat installed to finalize the correct choice. Your input, with shift improvement (3.5" handle movement) is Very Helpful. Thanks for posting and sharing the details of your combo (I'll probably pester you with more questions as I get closer).
I'm planning to use the most forward shifter location ('inspection cover' location) on the Magnum (again, not mocked up yet). Is there a reason you didn't use that location?
Craig
Old 01-12-2021, 10:45 AM   #272
69cunningham
Re: Lss3
It was the natural evolution from originally using the stock base. It also made the angles work out better. If you use the same stick as I in the front mount, you will have to reach a lot further to get it into the odd gears. I think it will be less comfortable.
Jim
Old 01-12-2021, 12:47 PM   #273
chetisimer
Re: Lss3
Jim
Makes sense. Thanks again for sharing!
Craig
Old 01-12-2021, 06:11 PM   #274
69cunningham
Re: Lss3
A belated Christmas present just showed up from Mar K. The tailgate does not have provisions for chains. Although the original one is in pretty good shape, this one will save me a bunch of patching. I will be installing the hidden latches and links soon. I also got the template for painting the letters and some crossmembers.
Old 01-13-2021, 11:00 AM   #275
88Stanger
88Stanger's Avatar
Re: Lss3
nice build so far!
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
